Author Topic: whats the real name of this fitting??  (Read 5413 times)
Offline tygrant
« on: December 17, 2008, 06:42:27 AM »
Ok im ordering  new SS brake line and i need a banjo up top but whats the name of the fitting used to connect to the the "hard" brake line that then connects to the caliper?? i need the correct name of it so i dont order the wrong one! thanks guys
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
eldar
Re: whats the real name of this fitting??
« Reply #1 on: December 17, 2008, 06:51:30 AM »
Are you particularly attached to using that hard line? If not, why not just take the line all the way to the caliper.
Offline tygrant
« Reply #2 on: December 17, 2008, 07:06:11 AM »
well i guess i could. the hard line is nice because im not running a front fender so i bent it to keep the line from rubbing, with a semi flexible ss line I will run the chance of rubbing on the tire... im not super familiar brake line fittings, but could i run the ss line into the caliper??
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
eldar
« Reply #3 on: December 17, 2008, 07:13:24 AM »
Well a stainless would be a hard line, do you mean a BRAIDED line? I have a braided and while I do have a fender, I do not think it would rub if positioned good.
Offline my78k
« Reply #4 on: December 17, 2008, 07:27:32 AM »
I thought it was a "thingymajiggy" otherwise known as a "whatchamacallit"
Sorry I can't offer a real answer... :-[  There is no name listed in my service manual
Dennis
Offline moham
  • .fnord.
« Reply #5 on: December 17, 2008, 07:29:23 AM »
But would a
also be a hard line? it seems (somewhat) obvious he means a ss braided line.
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline tygrant
« Reply #6 on: December 17, 2008, 07:39:13 AM »
yes, a semi flexible ss braided line, i want to connect it to the 12 inch or so long hard line that connects to the caliper
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline tbpmusic
« Reply #7 on: December 17, 2008, 07:48:49 AM »
The fiche calls it "Pipe, Front Brake".
bill2
"If you can't fix it with a hammer, then it's an electrical problem"
Bill Lane
 '71 CB450 Mutant/ '75 CB200/ '81 CM200/ '71 C70M
eldar
« Reply #8 on: December 17, 2008, 07:55:49 AM »
Well with as often as people misunderstand things, I figured it was best to be sure. I figured it was but some may not have.
« Reply #9 on: December 17, 2008, 07:58:39 AM »
i think the proper name would be , "metric brake fitting"  just go to an auto parts store , they'll know what your talking about
« Reply #10 on: December 17, 2008, 08:46:35 AM »
Most fittings wont, fit that is as the threaded nut used by Honda has a different number of TPI to the "standard" metric fitting.
Also the female end it screws into is rarely threaded all the way down so the male nut that is threaded all the way down wont tighten up.
Having said all that if you buy from a decent supplier and tell them you want to use the original Honda steel pipe they should supply with fittings that work
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #11 on: December 17, 2008, 08:48:49 AM »
I think that spiegler has a list of fittings with pictures to help you identify.
spwg
Offline dusterdude
« Reply #12 on: December 17, 2008, 12:48:24 PM »
no they wont.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #13 on: December 17, 2008, 01:09:17 PM »
You tell em mark ;D ;D ;D ;D ;D ;D
Sam. ;)
Offline tbpmusic
« Reply #14 on: December 17, 2008, 01:30:17 PM »
As far as I know, that part is still available from Honda, less than $10.
Try BikeBandit.....
bill2
Bill Lane
« Reply #15 on: December 17, 2008, 09:12:39 PM »
You want an AN adaptor to 10mm x 1.25 pitch in a female form if you want to run the steel (cant figure why you would)
To run into caliper and out from mc you need a male AN adaptor, same thread.
 Check the thread and pitch that was a guess, the second sentence was referring to a single line that has no brake swich or banjo, if you want to run a cleaner setup and you bars permit
Offline Mach-5(50)
    • ryan barr photography
« Reply #16 on: December 17, 2008, 11:16:03 PM »
no they wont.
you are partially right. i assume you say that because of experiences at schuck's, autozone etc.....
from a counterman's perspective a "metric brake fitting" can refer to a lot of things. are you connecting male to male? male to female? do you need to adapt 2 different sizes?
dusterdude...i am certainly not trying to make this personal. as a general rule, if you can take parts and pieces with you, it helps ensure you leave with what you want. from my experience, most people don't know what they want.
tygrant...using stainless braided right to the caliper is not a bad idea. it eliminates any additional leak points.  you can use zipties to keep things out of the way of the tire, or if you want to get fancy you can use adell clamps, or an insulated clam, (commonly used for wiring) to keep things a little more sanitary.
i am not sure about the AN part. i didn't see where it was mentioned that the stainless braided line tygrant is using is an AN type line. i don't see a need to convert. AN has its own sizes and threads, neither metric or sae.
just my 2 cents, from what i have read.
later,
ryan
later, ryan
The more adults I meet, the more I want to help kids.
i used to be drunk and dirty,
now i am clean and sober.
http://www.ryanbarrphotography.com
Offline bert96
  • past ride
« Reply #17 on: December 18, 2008, 02:44:47 AM »
You need this one,
http://www.z1enterprises.com/detail.aspx?ID=3382
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline tygrant
« Reply #18 on: December 18, 2008, 06:27:03 AM »
I am not against running the SS line right into the caliper... i am eliminating the pressuer switch and want to run one SS braided line... the hard line is bendable and i can bend it around the fork and keep the rest of the line off the tire. i suppose i could rig it up with a ss line into the caliper so that it wont touch...
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline Mach-5(50)
« Reply #19 on: December 18, 2008, 08:46:01 AM »
what stainless braided hose are you planning to use? do you have it yet?
eldar
« Reply #20 on: December 18, 2008, 10:50:03 AM »
Run the 1 line and thats it. The steel hose is how old? Plus then you add another connection point which could fail. One hose will minimize chances of leaks.
Offline crazypj
  • I'm brill, me
« Reply #21 on: December 18, 2008, 11:52:16 AM »
You need this one,
 That doesn't work right because the caliper has a male end as well. (although if its to screw onto hard line to connect SS line itr is correct)
 To connect the line you need a 90 degree brass adapter to make it work. (it looks a bit like this <>  to mate the flared ends)
PJ
Personally, I don't bother, make my own
PJ
Offline bert96
  • past ride
« Reply #22 on: December 18, 2008, 12:07:12 PM »
 I bought this fitting when i install my SS brake line and it work perfectly.
Offline tygrant
« Reply #23 on: December 18, 2008, 12:35:02 PM »
i just called z1 and the helped me out, i think i am going to keep the hard pipe and the end and buy that fitting with one of their SS hoses. hopefuly this front brake over haul will work!!
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
wornknobby3
« Reply #24 on: December 18, 2008, 04:08:13 PM »
i'm using the AN-3 set-up w/ the stock degree AN-3 banjo from master to SS braided hose to pressure switch to SS braided hose to a male adapter which screws in my caliper having 10mm x 1.25 thread pitch and AN-3 style on the outside for the hose to screw to. nice clean look w/ out hassle of hard line.
