Author Topic: POR-15 & Fiberglass  (Read 1100 times)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
POR-15 & Fiberglass
« on: April 10, 2009, 10:10:01 AM »
How can I use POR on my fiberglass tank when the petcock is permanently mounted?
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
Re: POR-15 & Fiberglass
« Reply #1 on: April 11, 2009, 05:26:07 PM »
Can I assume based on no responses, that the answer is the one I already came up with..
I can't ::)
Offline Soos
« Reply #2 on: April 12, 2009, 03:06:06 AM »
can you plug off the petcock?
Other than that, dunno.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
fuzzybutt
« Reply #3 on: April 12, 2009, 07:42:45 AM »
not knowing what the outlet looks like from inside the tank i make this suggestion/question. the petcock must be rebuildable correct? can it be dismantled enough that you could put a plug of silicone into the hole before coating? whether it's a formed hard-ish plug or silicone from a tube that you squirt in then cut out when the coating is done.
