Author Topic: best tire for wet road  (Read 2230 times)
Offline Serge
  • cb750f 1978
« on: October 28, 2005, 12:10:10 PM »
It is second time I skid my rear wheel on the wet road and went down. First time it was on the turn (no braking) and second time while braking on the straight (I tried to be really easy on the rear break but still). My knee still hurts and I as it does I am thinking that I probably need a new rear tire. After all it might still be cheaper then keep replacing turn signal and mirrors even if there will be no doctor's bills. ;) This is my first bike and I got it in the summer. I replace front tire which was cracked all around but I kept the rear one.
So, the question I have: what is the decent rear tire for 750f  to ride on the wet surface ?  I know that the skill  makes all the difference but at least I  will not blame a tire next time (knock-knock-knock).
Thanks a lot ! - Serge
if it ain't broken it does not have enough features yet..
Offline kyre
    • CB400F / 466 Build Thread
Re: best tire for wet road
« Reply #1 on: October 28, 2005, 12:12:18 PM »
I love my avons
CB400F / 466 Build Thread (currently in progress)
http://forums.sohc4.net/index.php?topic=105027.0
« Reply #2 on: October 28, 2005, 12:23:23 PM »
 I like my Metzlers.
Offline mcpuffett
« Reply #3 on: October 28, 2005, 01:14:36 PM »
dunlop TT100's are the ones for me  ;) mick in the wet uk.
MetalHead550
« Reply #4 on: October 28, 2005, 01:14:49 PM »
My Dunlops have been great, alot better than the cheapo vintage looking ones I got it with.  Is the rotation on the rear tire correct?  Should be an arrow pointing the direction the tire should travel when moving forward.  Wouldnt be the first time one had been mounted wrong.  The treads designed to channel water so if its going the wrong direction it could be causing you to hydroplane more easily.
Offline Kevin D
  • SE Michigan
« Reply #5 on: October 28, 2005, 05:00:33 PM »
Serge, the road is super slippery just after the rain begins. The oil floats to the top before it is washed off.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Uncle Ernie
« Reply #6 on: October 28, 2005, 06:27:18 PM »
Tips- avoid the middle of the lane (especially at intersections) because there is more oil from cars there.  Watch out for any kind of metel grate/ manhole cover.
Sounds like you have a tire that was made just after the invention of the word "round".  Any rubber product that old is not going to do any good whether it has tread or not.  Any of the top 4 or 5 manufacturers will be a huge improvement over what you have now.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #7 on: October 28, 2005, 06:32:32 PM »
In addition to the oil mentioned, after a prolonged dry period with vehicle tires abrading rubber particles all over the pavement, the first few minutes of rain, or a light rain, add a rubber slurry to the mix. Wait if you can, if you can't, take it easy.
Jim Shea
« Reply #8 on: October 29, 2005, 03:11:56 AM »
Serge,
I use avon roadrunners that seem fine in wet and dry. I try not to ride in the wet if I can as the bike does not like getting wet!  ;)
However, if you went down whilst braking in a straight line you need to get some tuition and check if your rear brake is grabbing or sticking!
When the rear wheel locks you have to steer in to the skid similar to the way you do in a car, in otherwise, provide a little opposite lock. I would not try this until you have been taught by someone, preferably on thier bike.
Jim.
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #9 on: October 29, 2005, 04:21:02 AM »
Lot's of rain in the UK...TT100'S for me also ....superglue on wet British roads  ;) sorry Steve and your pussy dry driving Avons   ;D
Me..  I don't go out in the wet mate  :o
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline Serge
  • cb750f 1978
« Reply #10 on: October 29, 2005, 08:13:37 AM »
Thanks a lot for all the replies!  It seems I can not detect yet when the tire just starts to skid. I practiced locking the rear tire on the dry pavement, but on the wet it just goes down to fast ..  -Serge
Jim Shea
« Reply #11 on: October 29, 2005, 08:16:10 AM »
I know the feeling, everytime I go out I test the brakes in the first few hundred yards, also I test the surface. Problem is the surface constantly changes, so caution at all times is the way, especially in the wet.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #12 on: October 29, 2005, 09:02:24 AM »
I'm with Steve. Sometimes you get caught out in it though when you don't expect it.
