Author Topic: What's the secret of the Master Link clip?  (Read 2056 times)
Offline Johnny5
    • CB350F build thread
« on: April 30, 2009, 02:48:01 PM »
My gosh I think Im going to go crazy. Got my new sprockets and chain today. Sprockets went on in 5 minutes. Chain, 2 hours and still working on it. No matter how much I squeeze with my vice grips, c-clamps, I cannot get this freaking clip on the masterlink. Im squeezing it on both ends and still no success.
Any tips before I convert my bike into a shaft drive?
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline Toxic
Re: What's the secret of the Master Link clip?
« Reply #1 on: April 30, 2009, 02:54:19 PM »
needlenose visegrips on each end to set the link
when you see the grooves in the posts you know the clip will work
then the clip should slide on
it is directional so the tails face away from the direction of rotation
it shouldn't be that hard
best of luck
Offline texaninseattle
  • lots of protein in my
  • OHH Canada
« Reply #2 on: April 30, 2009, 02:57:08 PM »
sometimes it just depends on the chain....I got a cheap jc whitney chain and it was real headache...then i replaced the masterlink with a little better quality one and it slipped right on
1978 Cb550k(Sold)
emgo pods
mac 4-1
105 mains
stock pilots
needles set 1 step richer than stock
IMS 2 turns out
1982 Suzuki GS850g
Offline Johnny5
« Reply #3 on: April 30, 2009, 03:02:40 PM »
Toxic,
"Shouldnt be that hard?" hahaha I know. I helped my friend last year with his chain and it only took a few minutes.  I think Texaninseattle is onto something since this is a JC Whitney chain...
I'll just keep working at it.
Thanks guys.
1971 CB350
1973 CB350F
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #4 on: April 30, 2009, 03:04:48 PM »
Depends on your chain.
My 530 requires a press to put on a clip and a master link.
ev0lution7
« Reply #5 on: April 30, 2009, 03:06:40 PM »
You have to be a "chain master" it takes years of school'n to be the master of the chain ;)
on a serious note:
I had some trouble with mine so i bought a rivit type link... only i didnt have a chain rivit installer... so i ordered one... (i have a 630 chain) so as soon as it arrived my master link just went on with no probelm :) i think i scared it by ordering the tool :) ;)
OH ya i did have to get a PRESS its a "C" clamp looking thing but instead of being a regular bolt it has a HOLE in the end of the bolt... to go round the rivit with the notches in it :)
Offline Scrubs
« Reply #6 on: April 30, 2009, 03:14:38 PM »
I always hate this job. try heating the plate up.
ev0lution7
« Reply #7 on: April 30, 2009, 03:56:25 PM »
DONT heat the plate up on a O-ring or X-ring chain....
you need the special tool i think Parts-N-More or Z1 has it it was well worth it...
it helps to have the right tools for the job it makes doing it later easier and knowing that you have the right tool for the job makes you feel good and not like your doing it half assed
http://www.mikesxs.net/products-7.html?category_id=7.1
there its on that page
PN# 35-0081
also might want to look at some of those other tools mike has some KILLER selection of jap tools made just for cycles not auto tools that we are making work on our bikes...
« Last Edit: April 30, 2009, 04:11:04 PM by ev0lution7 »
Offline Kevin D
  • SE Michigan
« Reply #8 on: April 30, 2009, 04:00:04 PM »
Heres from the Diamond chain FAQ describing master links, sounds like you have a press-fit side plate:
Slip-fit, the most common and most popular, are provided for general chain applications and allow the easy slip fit assembly of the cover plate over the pin ends. This slip fit construction does not have the same integrity found in the assembled chain and can reduce the chain's working load capacity by as much as 30%.
Press-fit connecting links are provided when the integrity of the connecting link needs to be equal to that of the base chain. This design utilizes pitch holes in the cover plate that are smaller than the chain pins, requiring the user to press the cover plate onto the pins before installing the spring clip or cotter. While more difficult to install this type of connection provides the greatest load carrying capability.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Johnny5
« Reply #9 on: April 30, 2009, 04:21:48 PM »
How are the presses different from a c-clamp? I really torqued the crap out that c-clamp. There's gotta be a big difference in tools. I'll have to order a press.
1971 CB350
1973 CB350F
Offline mikeb4
  • Building and riding and building ....
    • Mikeb4's website
« Reply #10 on: April 30, 2009, 04:22:21 PM »
on a serious note:
+1 ... I fought for so long buying the Motion Pro chain tool because of the price but so glad I finally did, it's expensive but solves the entire problem.  I also went to rivit style masters only ... easy to install and more durable.
1978 CB750K CR750 Replica
1995 CB1000F
1994 Sportster Bobber
1977 CB750SS Cafe'
1999 ZRX
ev0lution7
« Reply #11 on: April 30, 2009, 04:24:12 PM »
the tool from mike is only $5 it was well worth the $$$$ (or $) its basicly a "c" clamp only the back side has a "divit" and that bolt has a HOLE in the center for the link to go through... my chain went on NO PROB!!! with that $5 tool.... heck i coudlnt even make one for that kind of money!
Offline Johnny5
« Reply #12 on: April 30, 2009, 04:42:48 PM »
Is this tool for the rivot style master link?
1971 CB350
1973 CB350F
ev0lution7
« Reply #13 on: April 30, 2009, 05:26:25 PM »
YUP!!!
its for the master link rivit the kind that looks like it goes on easy but doesnt (its actually tappered)
MY X-ring RK chain (630 88link) had that style master link...it came with a regular master link (straight rivit type) but i wanted my chain to be removeable... sorta.... it removes just with some elbow grease... i still have the rivit link but i dont like those.
Offline martino1972
  • and still a expert welder,period...
« Reply #14 on: April 30, 2009, 05:40:40 PM »
 :D :D :D :D :D :D :D :D :D :D :D :D :D
Marti, I want you to know, I like you an awful lot, but guys have said far less and left wearing their drinks on their shirts.
http://forums.sohc4.net/index.php?topic=36933.0  (my bobber)
ev0lution7
« Reply #15 on: April 30, 2009, 05:47:51 PM »
shaft drive= SUCKIE
BELT drive... now thats an idea i would like to see on the 750 if it breaks you can stop by any harley shop and get a "temp" belt to get you home....
Offline Johnny5
« Reply #16 on: April 30, 2009, 05:52:11 PM »
Man, speaking of belt drives. I love the one on my Kawi cruiser. Quiet, almost maintenance free. Good stuff.
1971 CB350
1973 CB350F
Offline kghost
« Reply #17 on: April 30, 2009, 05:54:13 PM »
YUP!!!
No its not...that tool will not do a Rivet master link.
Its for the press fit Master clip chains
Stranger in a strange land
Offline mikeb4
    • Mikeb4's website
1995 CB1000F
1977 CB750SS Cafe'
1999 ZRX
