Thanks two tired,i sort of thought it should have too. As for gauge im not sure its heavier than the standard wire
No such thing as standard wire. They all have gauge ratings. Stock was about 8 gauge, I estimate. This was fine for the length used in the stock bike. If you have increased the distance or length of the wire then you may have to go to 6 GA.
Don't neglect the starter motor return path. The motor needs two high current paths connecting to the battery posts. Both the POS path and the NEG path are equally important.
Anyway, to isolate the solenoid, just lay something thick and metallic across the big posts of the solenoid. If the motor spins, the solenoid isn't making a good connection between those posts when activated.
According to the battery specifications, the battery you chose should have enough juice to turn the motor. Not as long as the proper battery, and don't expect it to last as long as the stock one. But, it should spin it over for a short while if it has sufficient charge.
