Author Topic: GOT THE BIKE!!!!  (Read 4392 times)
Offline OldSchool_IsCool
  • Really feeling like an
Re: GOT THE BIKE!!!!
« Reply #50 on: May 05, 2009, 03:21:26 PM »
( and may need to get a new battery after all, i let the little B&D charger that I bought go for about 3hr and it still wasnt fully charged...anyone know how long this should take?)
Taking its own sweet time to charge is a good sign.  The nearly dead battery that charges in an hour or two are the ones you need to worry about.  Giver 'er over night
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline OldSkool
« Reply #51 on: May 05, 2009, 06:15:19 PM »
Well done!  Based on your symptoms (needing to hold throttle open to start/run, won't idle, 1&2 not firing) sounds to me like your carburetor slow jets are clogged.  :)
mystic_1
I would agree here, I think a carb rebuild would be an excellent idea.
Online Don R
« Reply #52 on: May 05, 2009, 08:50:05 PM »
The reason for putting your hand ver the carb while turning it over is to maker a suction that will pull fuel through the needle valve and could clear an obstruction. I ran lectrons on our Jr dragsters which had a finiky needle and seat. I used this trick several times to clear a leaking carb after starting it and finding fuel leaking from the overflow. ;D
Offline cudjo
  • CUDJO
« Reply #53 on: May 06, 2009, 05:17:15 AM »
Ok :)
the battery charged after a a day on the charger!
next step is to get the carbs off and clean em up. have not received my manual yet so I will wait for that unless some one can give me a step by step on how to remove?
Offline mystic_1
  • 1970 CB750K
« Reply #54 on: May 06, 2009, 05:37:25 AM »
cb750fbomb linked you to a place to get manuals back on page 1:
There are free manuals in the FAQ section. You should just start reading the FAQ section. I have read and read FAQs just to absorb it all.
http://forums.sohc4.net/index.php?topic=426.0
Link is to the Manuals FAQ.
mystic_1
- John Augustus Shedd
Offline cudjo
  • CUDJO
« Reply #55 on: May 06, 2009, 05:42:38 AM »
mystic_1
sho nuf did...thank you sir
