Author Topic: moving the kickstand ?  (Read 2181 times)
Offline rustrocket92
  • Mad Fabricator
  • Buster is in the Lab!
« on: June 04, 2009, 09:35:40 AM »
I am almost ready to paint my 76 cb 750 cafe racer project and have run into a snag. the bike when i got had an old beat up set of drag pipes on it. I took the drags and made them into 1 pipe on each side with turn outs. So it actually has like a 4 into 2 exhaust. There is a problem that i wasnt expecting thou. The left side pipe is hitting the kick stand when in the down position. So i need to move the stand about 3/4 inch in. My question is should I keep the kick stand mount at the same angle ? will the kick stand need to be longer ? shorter ? Thanks for the help.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Sheik Yerbouti
  • Likes the warm feeling but is tired of all the dehydration.
Re: moving the kickstand ?
« Reply #1 on: June 04, 2009, 09:57:10 AM »
Looking forward to seeing the answer to this. I have a 4-2 system as well and it's causing me problems with both the kick stand and the center stand. Maybe mounting a narrower center stand or something?
  • Mad Fabricator
« Reply #2 on: June 04, 2009, 10:02:21 AM »
The center stand was easy i just removed it and the mounts. As for the kickstand I all ready fabbed a plate to weld on so I can weld the kickstand mount farther in but I am just wondering about the angle. Should i leave the mount at the same angle?
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
kabuki
« Reply #3 on: June 04, 2009, 10:29:28 AM »
Ideally I think you would want to increase the angle and run a slightly longer stand to end up with the same point of contact and bike lean angle when parked.  IMO
  • Mad Fabricator
« Reply #4 on: June 04, 2009, 12:34:10 PM »
That is what i was thinkin also.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
  • Mad Fabricator
« Reply #5 on: June 04, 2009, 04:32:39 PM »
No more suggestions ?
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline hapakev
  • Your Standard
« Reply #6 on: June 04, 2009, 06:54:22 PM »
I dont know about you, but my 78 cb750f leans like a Big Dog!  I wouldn't mind if it sat up a little straighter, although maybe a tiedown holding your bike at the right angle would help you to spot weld it.
Smoking Jack
1978 CB750F(ish)
  • Mad Fabricator
« Reply #7 on: June 04, 2009, 07:03:16 PM »
Thanks man I never really thought about that.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline hapakev
  • Your Standard
« Reply #8 on: June 04, 2009, 07:25:06 PM »
you got it!
Smoking Jack
1978 CB750F(ish)
« Reply #9 on: June 04, 2009, 07:59:54 PM »
Not sure about 75.6.7.. but 78 F has the stand further back.
  • Mad Fabricator
« Reply #10 on: June 05, 2009, 09:22:26 AM »
Ok well we will see what happens tonight and will post pictures of the results later.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
