SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
moving the kickstand ?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: moving the kickstand ? (Read 2179 times)
rustrocket92
Mad Fabricator
Hot Shot
Buster is in the Lab!
on:
June 04, 2009, 09:35:40 AM »
I am almost ready to paint my 76 cb 750 cafe racer project and have run into a snag. the bike when i got had an old beat up set of drag pipes on it. I took the drags and made them into 1 pipe on each side with turn outs. So it actually has like a 4 into 2 exhaust. There is a problem that i wasnt expecting thou. The left side pipe is hitting the kick stand when in the down position. So i need to move the stand about 3/4 inch in. My question is should I keep the kick stand mount at the same angle ? will the kick stand need to be longer ? shorter ? Thanks for the help.
Logged
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Sheik Yerbouti
Likes the warm feeling but is tired of all the dehydration.
Hot Shot
Re: moving the kickstand ?
Reply #1 on:
June 04, 2009, 09:57:10 AM »
Looking forward to seeing the answer to this. I have a 4-2 system as well and it's causing me problems with both the kick stand and the center stand. Maybe mounting a narrower center stand or something?
Logged
rustrocket92
Mad Fabricator
Hot Shot
Reply #2 on:
June 04, 2009, 10:02:21 AM »
The center stand was easy i just removed it and the mounts. As for the kickstand I all ready fabbed a plate to weld on so I can weld the kickstand mount farther in but I am just wondering about the angle. Should i leave the mount at the same angle?
Logged
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
kabuki
Guest
Reply #3 on:
June 04, 2009, 10:29:28 AM »
Ideally I think you would want to increase the angle and run a slightly longer stand to end up with the same point of contact and bike lean angle when parked. IMO
Logged
rustrocket92
Mad Fabricator
Hot Shot
Reply #4 on:
June 04, 2009, 12:34:10 PM »
That is what i was thinkin also.
Logged
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
rustrocket92
Mad Fabricator
Hot Shot
Reply #5 on:
June 04, 2009, 04:32:39 PM »
No more suggestions ?
Logged
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
hapakev
Your Standard
Hot Shot
Reply #6 on:
June 04, 2009, 06:54:22 PM »
I dont know about you, but my 78 cb750f leans like a Big Dog! I wouldn't mind if it sat up a little straighter, although maybe a tiedown holding your bike at the right angle would help you to spot weld it.
Logged
Smoking Jack
1978 CB750F(ish)
rustrocket92
Mad Fabricator
Hot Shot
Reply #7 on:
June 04, 2009, 07:03:16 PM »
Thanks man I never really thought about that.
Logged
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
hapakev
Your Standard
Hot Shot
Reply #8 on:
June 04, 2009, 07:25:06 PM »
you got it!
Logged
Smoking Jack
1978 CB750F(ish)
754
Really Old Timer ...
Reply #9 on:
June 04, 2009, 07:59:54 PM »
Not sure about 75.6.7.. but 78 F has the stand further back.
Logged
Kelowna B.C. Canada
rustrocket92
Mad Fabricator
Hot Shot
Reply #10 on:
June 05, 2009, 09:22:26 AM »
Ok well we will see what happens tonight and will post pictures of the results later.
Logged
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
