UPDATE!!
Uh, so it keeps pulling oil out of the side tank, until the tank is empty and the oil light comes on. Well, as I added oil, sure enough, OIL STARTED COMING OUT OF THE CRANK VENT (lower)!!!! So, the case is overfilled with oil, but the side case is empty and the oil light is on (I guess the light is triggered due to low pressure??). WTF?
? What is going on? What can I do to fix this?
Ok, this one's weird......I got my bike back, with rebuilt engine. I drove it a bit and there were some problems. I decided to check the oil, as the dummy light was on (but I figured it was just broken). Well, the reservoir was EMPTY. uh oh. So, I added 1 qt of oil. I ran it a bit.....again, red light and EMPTY. I added another 2 quarts of oil while running the engine......it ran the reservoir EMPTY angain!!! I now added ANOTHER 1/2 qt. of oil, for a total of 3 1/2 quarts ADDED to whatever was in there to begin with (if any). The tank is again EMPTY and the red light has come back on.
Now, I read that they take about 3.1 qts of oil, total. How is it that I have ADDED 3 1/2 qts and the tank is empty and the light comes back on. How is this possible? Where is it going?
Thoughts:
1) perhaps the '78 CB750 (f2 black motor) takes more oil than I think??
or
2) The oil is pumping into the crank case and simply overfilling for some reason?
Very confused.......
Can someone help me out? I hesitate to add any more oil to the crank case as I expect straight oil to come spraying out of the breather at any moment.
