Author Topic: the difference between bad shocks and bushings or bearings?  (Read 1279 times)
Offline the technological J
  • deliciouso!
« on: September 28, 2009, 09:13:00 PM »
at high speeds long swooping bends especially down hill and to the right my  78 550 k will start to weave from th eback end the other day i was doing around 80 and while leaning around a bend (big bend)the bike really started wobbling... so bad i almost broke traction and laid her down... i laid off the throttle but momentum carried me longer than normal... its also done at 105 on a straight away.. but i wasnt as concerned i was gonna lose it... how can i pin point if its the shocks bushings or rear bearings?...
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline mystic_1
  • 1970 CB750K
Re: the difference between bad shocks and bushings or bearings?
« Reply #1 on: September 28, 2009, 10:22:05 PM »
Put bike on centerstand.  Grab swingarm near the end and try to move swingarm from side-to-side.  Any movement = bad bushings.
Spin the rear wheel.  Sound like a box of rocks?  Bad bearings.
Grab opposing sides of rear wheel and try to twist wheel relative to swingarm.  Any movement = bad bearings.
Testing shocks requires shock disassembly of the shock.  If they're the stockers, replace them.
mystic_1
- John Augustus Shedd
Offline Bluegreen
« Reply #2 on: November 10, 2009, 11:14:36 PM »
I have a 73 cb500 and am thinking about replacing the rear shocks because they are original and are probably worn. But this is my first bike so I have nothing to compare it to. Anyway, I was hoping somebody could point me in the direction of some good shocks or at least have some tips for what I should be looking for. I also wiegh about 155 lb. not sure how much of a difference it makes.
