Author Topic: Bearings on a GL stem  (Read 863 times)
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
« on: October 09, 2009, 09:36:07 AM »
Anyone know if the bearing measurment for the tapered bearings will be the same from a 75 cb750k to the GL front end? Not sure if the washer/spacer would be the same?
jim
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
Offline ColinMc
  • There aint no pickle like a super pickle...
Re: Bearings on a GL stem
« Reply #1 on: October 09, 2009, 09:58:39 AM »
I know when I put the GL stem in my 76 cb750k frame, I used the CB750 tapered bearings and they fit fine. I used the washer that came with the bearing kit...and everything works great...well as great as it can work sitting unfinished in my garage lol. I'll double check this info when I get home though.
1976 CB750K - Cafe Project...taking forever
1984 Honda MB-5 - MB-8 conversion in process
2001 Ducati 748 - Built 996 motor sleeper
Offline JS550
  • IAFF local 1307
« Reply #2 on: October 09, 2009, 11:41:20 AM »
Just curious which washer? Thick or thin?
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #3 on: October 09, 2009, 12:09:00 PM »
when i did mine......my bike is a 76 cb750f.....i used a 76 gl1000 front end......i had to use the top bearing from the gl1000 and the bottom from the cb750....i have heard there a few minor differences in the triple tree year to year on the cb750s.
MATT
