Author Topic: Race frames...  (Read 41350 times)
Offline Ricky_Racer
Re: Race frames...
« Reply #75 on: February 17, 2010, 04:40:38 PM »
kos, rudi
do you know what is the rake in those frames?
TG
62.5°, TG.  8)  RR
Offline moham
  • .fnord.
Re: Race frames...
« Reply #76 on: February 17, 2010, 08:44:35 PM »
Does anyone know if you had a Honda frame built out of chrome moly tubing, the same specs as stock, would it be much stronger/better?
the primary benefit of chrome-moly is that it is stronger, and thus thinner wall tubing can be used and it will be lighter. the heat affected zone from welding will be brittle, and the entire piece will need to be "normalized" or uniformly heat-treated then re-hardened. bicycle frames are commonly brazed and TIGed without heat treatment, but i wouldn't trust a motorcycle frame not to develop fractures form the heat affected zones.
I'm also considering (somewhat) a frame build. Re-read a little of mec's egli build and he stated he used ST37 (apparently a german/euro term? is this what is known as A283 in the states?) for the frame. Also stated he used tig to weld. Any reason you can't mig with similar starting materials?
Anyone want to take a stab at this and enlighten a lesser experienced but amply motivated novice builder? My question stems from my limited knowledge of material thicknesses and what welding scheme is more advantageous...also, perhaps someone could point up a source for starting materials...?
mo.
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline rudi
Re: Race frames...
« Reply #77 on: February 17, 2010, 09:08:00 PM »
Rake of the Frame are 62° and the Frame it is stamped to "0" which means "..the Frame is 100% straight an inside the possibel zero Center Line. And it is true : This EGLI is the best one which I ever drove : No strange Reaktion like "following Street groves "and so on........
Offline kos
    • m3racing.com
Re: Race frames...
« Reply #78 on: February 18, 2010, 06:35:52 AM »
Makes it 28 degree steering head angle. about same as stock Honda CB750.
KOS
220...221, whatever it takes.
Offline turboguzzi
Re: Race frames...
« Reply #79 on: February 18, 2010, 09:07:06 AM »
28? very typical seventies, no?
makes you think how things changed since the seventies..... running about 23 in my stock framed racer now!
Offline GEORGES
Re: Race frames...
« Reply #80 on: February 18, 2010, 10:27:20 AM »
Rudi, your EGLI frame is beautifull !!! my impossible dream it's to find one ! nickel finition ?
Offline kos
    • m3racing.com
Re: Race frames...
« Reply #81 on: February 18, 2010, 02:18:47 PM »
Here are my much promised pictures of full on Egli.. with real Egli bodywork. Front fender I made from Honda DOHC CB750F Supersport, cut down. Forks are Honda CB750F2 or CB750 DOHC Supersport 1980. Complete Yoshimura engine with cr gear box and  Yosh handbent pipe.  Lockheed brakes calipers front and rear with Morris magnesium wheels. Rear disc is alloy with Harry hunt sprayed plasma coating.
Built and restored at M3 Racing.
KOS
Offline kos
    • m3racing.com
Re: Race frames...
« Reply #82 on: February 18, 2010, 02:20:08 PM »
More pics of Egli wheels.
KOS
Offline turboguzzi
Re: Race frames...
« Reply #83 on: February 18, 2010, 03:02:14 PM »
kos, in what class where you running it?
Offline kos
    • m3racing.com
Re: Race frames...
« Reply #84 on: February 18, 2010, 03:31:01 PM »
Over here in AHRMA it is called Formula 500, that is why we had those old mikuni smoothbores on it, as they at the time did not allow CR Specials. After the race at Mid Ohio we got rules changes to allow CR Specials.
Nice bike, handled well and it did sound good!
KOS
Offline rudi
Re: Race frames...
« Reply #85 on: February 18, 2010, 09:24:45 PM »
Yeas of course the Frame is Nickel plated. And a very important Hind / Information : All this Frames are Handbuild (of Course!) by using Brass Solder (I hope that my English is OK...) that means : The Nickel could not been stripped down in Chemical Bath tubes !!! because the "Acid" will took also the Brass Solder and the Frame fall apart !!!! it happens to a Frame from my Friends and the Troubel after this Accident are tremendous....
The shown USA EGLI 500 is gone and here in Germany . A Friend of me bought it via EBAY and I assiste him to bring on the Road under German Law . The Wheels are not Org. EGLI because at this Time (early 70th) they are not finish /availabel because Mr. EGLI just start his carrier.
Offline mec
Re: Race frames...
« Reply #86 on: February 19, 2010, 02:12:14 AM »
can you tell me your fork clamp offset?
you are racing 18" wheels, right?
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline turboguzzi
Re: Race frames...
« Reply #87 on: February 19, 2010, 04:27:37 AM »
mec
I am running Cagiva C9 125 triple clamps with (from memory) about 15mm less than stock offset, I will check in the evening.
TG
Offline Howell
  • Honda the power of dreams
    • CB500 classic racing
Re: Race frames...
« Reply #88 on: February 19, 2010, 11:06:37 AM »
We also have now 23 degrees on our new build Cb500 racer.
See the design of the yokes and the real ones.
Our wheelbase is 1400 mm.
« Last Edit: February 19, 2010, 11:10:24 AM by Howell »
You meet the nicest people on a Honda
Offline turboguzzi
Re: Race frames...
« Reply #89 on: February 19, 2010, 11:33:10 AM »
yes, more or less about there too Howell
just measured 28mm offset in my triple clamps
Offline Howell
Re: Race frames...
« Reply #90 on: February 19, 2010, 11:45:59 AM »
Hi TG,
As you can see on the drawing we have a offset of 25mm.
Offline mec
Re: Race frames...
« Reply #91 on: February 19, 2010, 12:02:33 PM »
28mm offset, 23°, 18" wheel results in 103mm trail.
this is a very modern design. the same as my duc rr16 :) (except the wheel diameter, however)
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline turboguzzi
Re: Race frames...
« Reply #92 on: February 19, 2010, 02:27:06 PM »
mec
rr16? get out of here!!!!!
Offline mec
Re: Race frames...
« Reply #93 on: February 20, 2010, 12:30:49 AM »
mec
its a 4cylinder, i will have a look, maybe its a sohc too?? :)
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline Howell
Re: Race frames...
« Reply #94 on: February 20, 2010, 12:07:56 PM »
« Last Edit: February 20, 2010, 12:09:45 PM by Howell »
leephilpot
Re: Race frames...
« Reply #95 on: May 29, 2010, 09:22:08 AM »
Dunno if it'll help but my father in law built that moriwaki bike from scratch when he worked for gordan pantall.
Offline turboguzzi
Re: Race frames...
« Reply #96 on: May 29, 2010, 10:33:39 AM »
Hei Lee,
Wow, welcome, some introduction :)
was reading the story on that kawi in classic bike the other day,
some photos from your "family album" will be welcome....
cheers
TG
traveler
Re: Race frames...
« Reply #97 on: June 05, 2010, 08:23:49 AM »
Here is my early Dresda frame.
Gr Ed..
Sorry to interject....but this Dresda pic is absolutely lustworthy!
~Joe
