Author Topic: What did you do to your bike today ?  (Read 3674311 times)
0 Members and 18 Guests are viewing this topic.
Offline Magpie
« Reply #33300 on: April 05, 2025, 10:26:41 AM »
My SOHC 4's have gotten the love over the last few months and are looking good and running nicely.  My 1980 CB750F now needs some love. It's been pushed back several times as new projects come along. It got a light going over but it's time for more. Cliff.
Offline M 750K6
« Reply #33301 on: April 05, 2025, 03:22:32 PM »
Very nice. 👍 How does the ride compare to the SOHC?
« Reply #33302 on: April 08, 2025, 12:11:17 PM »
Cliff…. That’s a stunner too!
« Reply #33303 on: April 08, 2025, 12:13:51 PM »
Finished up the K1. Ready for spring (it’s snowing again today!). Tubes, tires, headlamp, tank, side covers and badges. Some fresh brake fluid is next, when my new Mity-Vac arrives. The old one fell apart in my hands today!
« Reply #33304 on: April 08, 2025, 12:35:44 PM »
Looking good John 👍
« Reply #33305 on: April 08, 2025, 01:32:34 PM »
Looking good John 👍
Thanks Stu…. Very pleased with how that tank turned out. It’s only slightly faded on top but the sides match the new side covers very nicely.
Offline fire113
« Reply #33306 on: April 19, 2025, 04:25:43 PM »
Both bikes looking very nice, good work.
Was searching for the fast head for the fast engine.
« Last Edit: April 20, 2025, 02:45:52 PM by fire113 »
Offline fire113
« Reply #33307 on: April 20, 2025, 12:59:45 PM »
...was searching for the cam towers and rocker arms found them and a lot of other stuff too :)
Offline TideWater2
« Reply #33308 on: April 20, 2025, 01:32:34 PM »
What a great pair, looks great! Love the red, lol
3 - 1971 CB750 K1s
« Reply #33309 on: April 21, 2025, 08:09:47 PM »
Thanks. Thinking I could move the ex-K1 tank and side covers over to the K3 and have triplets!
Offline Dr. Frankenstein
« Reply #33310 on: April 24, 2025, 12:55:06 PM »
I discovered an almost perfect match for the Honda Flake Sunrise Orange - and it only costs about $27... it's a can of Krylon Glitter Blast ($10) and a can of Candy Orange from KustomCans ($17), with a Rustoleum Primer/Sealer base, and it's an almost perfect match. I'm in the middle of painting my '72 Cb500 Four right now, waiting for the candy to set up before I apply the SprayMax 2K Clear, and that should make it Really pop!  I got two cans of the candy orange because I didn't know how much it would cover, but it did the two side covers and the tank with no problem, just enough to do the whole thing, with a very little bit left over. I'll repost when I get the clear on, but I am very impressed with that candy! Thought you guys would like to know...
« Reply #33311 on: April 24, 2025, 01:08:22 PM »
Dr. Frank, will you also use a fuel-resistant clearcoat for the last coat?
This crappy Ethanol they use in the gasoline is horrible to paint.
Torpedojuice
« Reply #33312 on: April 24, 2025, 02:48:53 PM »
Watching paint dry!
« Reply #33313 on: April 24, 2025, 04:02:41 PM »
This afternoon was day(partial days)#4 to finish cleaning up the set of HM300 exhaust I got from Andy750. They were caked with old burnt on oil/chain lube as well as most had blotches of surface rust so I used real brass brushes and brake cleaner to loosen the oil areas and some foaming glass type cleaner to lube the brass brushes. They are in fairly good condition, now(I had my wonders before starting the cleanup) with  only a few whammoes and 2 small rust holes (I plan the patch in flush with stainless steel sheet goods, tig welded.
I had to drill out one of the baffle bolts that snapped above the muffler, 2 other bolts will have to get drilled out of the baffles and retapped also.
With my ball peen hammer and a brass drift I made from some scrap plumbing parts, an 8" drft rod now.
These will go on a K2 I have in the que to get worked on.
« Last Edit: April 24, 2025, 04:13:28 PM by newday777 »
« Reply #33314 on: April 24, 2025, 04:05:32 PM »
Grcamna - yes, I used SprayMax 2K; I've used it on my KZ400S to great effect. Here's a shot of the final product - it looks a bit orange-peely, but I let it sit and it's leveled out really nicely, the pics don't do it justice, it came out great; I'm very happy with it! I have some double-line white pinstriping like the OEM I'm going to add to detail it a bit to hide the rough edges of the black, but it should look really nice when I'm done. I got bored waiting for the candy to show up this afternoon and decided to dig into the carbs of the 550 I want to do next; they look kind of gross, but I've worked on worse...new jet holders are on the way, and at least all the jets came out okay; but then the paint showed up so I had to get that done first...but with the completion of the 500 tank, I think she's ready to roll! I used Rustoleum Semi-Gloss on the black part, and didn't put clear over that, but seriously, it looks awesome.
« Last Edit: April 24, 2025, 04:26:42 PM by Dr. Frankenstein »
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
« Reply #33315 on: April 24, 2025, 05:36:20 PM »
Ordered Hondaman's new book for the 550.
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
« Reply #33316 on: April 24, 2025, 11:19:37 PM »
You did a good amount of work,cleaning them up;came out good.
« Last Edit: April 25, 2025, 07:14:40 AM by grcamna2 »
« Reply #33317 on: April 25, 2025, 12:26:03 AM »
You did a good amount of working cleaning them up;came out good.
Well worth the effort 👌
« Reply #33318 on: May 07, 2025, 06:25:33 PM »
Nice work Stu! I have the ones from the S/C to tackle. Been procrastinating for +6 months so far!
« Reply #33319 on: May 07, 2025, 06:29:36 PM »
Decided to take the K4 for its first outing. While charging up a dead battery, pulled off the rusty old Gemini (Made in California) exhaust and fitted the Hindle system I picked up from “Flybackwards”. Half the weight and twice the noise! Fired up and ran well, just like it always does. This engine has never been out of the frame. Sounds great, my son will love it.
« Reply #33320 on: May 07, 2025, 07:13:25 PM »
Yes sir those Hindle pipes are top notch...just put one on my Suzuki GS1100e.  Made me fall in love with that bike all over again.
Offline Kelly E
  • Geriatric Hooligan
« Reply #33321 on: May 07, 2025, 07:24:55 PM »
How do you fall out of love with a GS 1100E? 8)
We put RS 36 carbs and a Delkevic exhaust on the 80' and now we would have to be really desperate to sell it even though it's a crusty looking old dog.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline WhyNot2
  • I'm finally an
« Reply #33322 on: May 07, 2025, 07:45:23 PM »
Did nothing to my 750 or 350F due to being in Delaware to attend my uncle's funeral.
He was a decorated Vietnam U.S. Marine Veteran and was given the full honors of a military service.
Was very hard listening to the taps and 21 gun salute, due to me being a gulf war veteran, myself.
« Reply #33323 on: May 07, 2025, 07:51:14 PM »
I’ve got another one put away for the Rickman CR750 too!
« Reply #33324 on: May 07, 2025, 08:08:59 PM »
I'm sorry for your loss.
