Author Topic: Broken Bolt  (Read 2096 times)
Offline grandelatte
  • CB750K1-ish Frankenstein
    • Life is Xampericious!
Broken Bolt
« on: November 29, 2009, 04:28:35 PM »
This is my second day of owning a CB750K1.  It needs lots of TLC.  One of the issue I discovered is a broken bolt on the points cover.  If it were sticking out a bit, I would use a pair of pliers to turn it, BUT it is broken even to the surface.  Do you have any suggestion to how I should get it out?   ??? ??? ??? ???
TIA - Jim
Offline Patrick
Re: Broken Bolt
« Reply #1 on: November 29, 2009, 04:39:23 PM »
Go to Harbor Freight (or some other hardware store) and get left handed drill bits. If you are lucky the bit will grab the broken bolt as you drill into it and spin it out.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline myhondas
  • Not really such a
Re: Broken Bolt
« Reply #2 on: November 29, 2009, 04:40:28 PM »
Center punch it.....drill it about 1/8-3/16" deep and use an easy-out to remove it after spraying it with a good penetrating oil like PB Blaster.
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
Re: Broken Bolt
« Reply #3 on: November 29, 2009, 04:51:41 PM »
Whatever you do be careful mate, that is a pretty soft casting around the remains of that screw, so don't just go wanging into it with a hammer and punch.
If you can file the end of it smooth you'll have a much better shot at punching it dead centre, and that's really important, because if the "left hand drill" method doesn't work, you may have to drill the screw out completely and use a helicoil to replace the thread, and if you're off by half a mm (or don't drill parallel to the old screw's angle) you'll just end up with a mess.
You might get lucky with an "easy out", I've found that the square ones are really good as they seem to "bite" better than the fluted type, but just make sure that your drill bit is nice and sharp so it doesn't "wander", and use plenty of penetrating fluid. Cheers, Terry. ;D
Offline gane
  • Gane
Re: Broken Bolt
« Reply #4 on: November 29, 2009, 05:04:58 PM »
Jim, As most of us have found, broken bolts/studs are common, and depending on location can be real bears. Offer this. Your' 1st approch is often the most critical.  With nothing to grab, you'll need to drill...It's important (and I can't over ephasize) that 1st drilling is EXACTLY centered.if neccesary file/grind whatever, old bolt/stud until it's possible to center punch a center before drilling. then,,, penetrating oil, next, actual drilling.start w/smallest reasonable drill possible (preferibly Left handed) sometimes this will work in itself, if not, attempt light heat (prophane til spit sizzles) and ez-outs. this needs be done before hole in offending bit is so large that ez-out simply swells bit and increases seizure. still no luck? drill progressivly larger hole until remaining bit can be prized/cracked/broken out piecemeal. even if this has damaged internal threads, it still provides a good basis for drilling/installing a helicoil or better yet timesert. Sometimes welding extensions to bit is possible, and heat/leverage allow removal. Ulta sonics is another option in some cases. Your' problem is pretty straight forward as these things go, hope there's something here that helps, luck G
Re: Broken Bolt
« Reply #5 on: November 29, 2009, 05:06:56 PM »
Everything that has been said is good to try. Luckily its just the cover screw and you could get by without it worse come to worst.
My 2 cents, file it FLAT. Center punch it, get a REALLY SHARP drill bit, brand new cobalt tip or whatever. Smaller than the OD of the screw which is 6mm.  Drill it down the center. USe favorite tool EZ Out or such to remove it.
The reverse drills sound intriguing, I've never seen or used one.
If it gets really messed up, you can use a 1/4-20 American screw rather than a helicoil. Get the old crap out, tap it to 1/4-20, which is just a skosh larger than 6mm and get a screw to fit.
Restoring it to 6mm is always preferred.
Online Don R
Re: Broken Bolt
« Reply #6 on: November 29, 2009, 06:01:58 PM »
If you have access to a small mig or other welder you can hold a washer over the bolt and weld the washer through the hole to the bolt. let it cool a little and turn the washer with channel locks, If it breaks off try again. Sometimes it takes more than 1 try. I have also used a thin nut. not for the faint of heart but I've had good luck with it.
Offline grandelatte
Re: Broken Bolt
« Reply #7 on: November 30, 2009, 07:08:34 AM »
thank you all.  i will try your suggestions tonight.   :)
Offline Yoshi823
  • Biker to the bone.
  • Never too old to be a biker
Re: Broken Bolt
« Reply #8 on: November 30, 2009, 07:26:55 AM »
I think that the heat from the welding may well soften the corrosion between the ally crankcase and the steel stud,so making it easier to get the remains out.
Good idea to helicoil the hole as well.
Bikes...they're in the blood.
Yamaha 2001 R1
Yamaha 1990 FZR1000R EXUP
KTM 2004 450 EXC RFS
Honda 1997 XR400R
Honda 1988 CB125T2
http://www.cb750cafe.com/bikes.php?cat=3&id=67
Offline grandelatte
Re: Broken Bolt
« Reply #9 on: December 05, 2009, 03:15:25 PM »
thanks guys for your help.  i found Black and Decker screw extractor at Home Depot.  i followed the instruction and it came out in one piece.
again, thank you so much for your suggestions and encouragements.
