Author Topic: "Little Horse," and "Little Dragon" the war of the 500's  (Read 170068 times)
Offline Little_Horse
    • My cafe build
Re: Yet another cafe bike build
« Reply #25 on: January 22, 2010, 07:36:29 AM »
My filters came!
"Little Horse Cycles" facebook page: http://www.facebook.com/pages/Little-Horse-Cycles/185809474769493
LHC is my start up cafe racer shop specializing in custom parts, bikes, restoration and recreation
The 500 builds http://forums.sohc4.net/index.php?topic=64250.0
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #26 on: January 22, 2010, 08:26:53 AM »
those are pretty slick, nice and tiny!  they're not my cup of tea, but they do look good on the carb!
where'd you get them?
    • My cafe build
« Reply #27 on: January 22, 2010, 08:49:35 AM »
On ebay, cheap knock offs of a k&n, they need to be small to clear the frame, only 3 in working space in there. It allows for a little bit better performance and so I can remove the heavy cumbersome air box.
    • My cafe build
« Reply #28 on: January 22, 2010, 08:51:24 AM »
So I want to replace this...
With this...
More to come on this ordeal, as soon as I have pics of the caliper, you know the thousand words thing :)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #29 on: January 22, 2010, 09:51:57 AM »
"little bit better performance" might not be accurate with stock engine... i know a guy with cheap dyno services if you want to get it overwith and have the best performance possible with the pods, but prepare for low end loss. search the forums- lots on this topic.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
    • My cafe build
« Reply #30 on: January 22, 2010, 10:10:29 AM »
I may eventually dyno tune it, I am pretty familiar with carb tuning. Well at least tuning with out a dyno, you know the butt dyno ;). I was speaking about top end gains, and weight gains. Pods do not allow enough velocity pressures to boost bottom end and mid range. To much flow not enough resistance. I will however need to find out what carb settings to start with as I don't know what has worked for most people with these bikes, like the main jet size, needle position and mixture screw setting, so I can at least have an idea of a place to start. I will have to do some searching I am sure.
Offline Slams77
  • Naturally Aspirated
« Reply #31 on: January 22, 2010, 10:46:37 AM »
I just wanted to chime in again to say that after finally reading your link last night you definitely have creativity and skill, and props to your father for his support.  I’m sure many people will agree with me that your build is very inspiring and informative.  Keep it coming man because it’s great stuff.
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
« Reply #32 on: January 22, 2010, 10:50:54 AM »
Just some info for you......I ran those same Emgo filters on my CB500 and you dont have to change anything on the carbs(just use the stock carb settings). Ran it like that for about 3yrs and bike ran great.....bottom-mid-top. Also.....a friend is running his CB500 AHRMA race bike with just velocity stacks....stock settings on the carbs......just make sure everything else is tuned.
Also.....ran a braided brake line on my bike....you will need to ditch all that stock line....rubber and metal section and run the line direct to the caliper and use one of these fittings from Dennis Kirk:
http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=194431&catId=416&leafCatId=41604
Allows you to screw that AN fitting on the brake line to the 10mm hole in the caliper.
« Last Edit: January 22, 2010, 10:52:31 AM by ohiocaferacer »
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #33 on: January 22, 2010, 10:53:42 AM »
watching
    • My cafe build
« Reply #34 on: January 22, 2010, 11:16:27 AM »
yeah thats the part I was looking for... too late though I already made it work. I welded the fitting to the caliper. It will be the same, just a little bit more work. I guess nothing new huh, do a lot of people do this?
    • OHIO CAFE RACERS
« Reply #35 on: January 22, 2010, 11:26:13 AM »
Do what........make more work for themselves, than is needed?? YES!  ;)
    • OHIO CAFE RACERS
« Reply #36 on: January 22, 2010, 11:34:31 AM »
Here is a pic of my old CB500 I just sold with the filters and the braded line.
....and racing my buddies CB500 at Barber Motorsports Park in 2008....open carbs......and in the rain. :o
I've been watching your build....if you need anything....just ask.
    • My cafe build
« Reply #37 on: January 22, 2010, 12:55:01 PM »
very nice bikes, racing looks like alot of fun.
    • My cafe build
« Reply #38 on: January 22, 2010, 02:01:13 PM »
Front brake is back on with the new line attached.
    • My cafe build
« Reply #39 on: January 23, 2010, 08:45:32 PM »
Things are coming together
  • Like a well oiled
    • Undead Asphalt
« Reply #40 on: January 23, 2010, 08:46:52 PM »
what did you weld into the caliper? an adapter?
Offline Zaipai
    • My Home page
« Reply #41 on: January 23, 2010, 08:52:08 PM »
Wow, that is coming along very nicely.. Very clean.. wow..
Nice work!
.: Scott :.
Its my Avatar..
75 CB550F  |
    • My cafe build
« Reply #42 on: January 25, 2010, 07:21:25 AM »
Yeah I welded the adapter onto the caliper, It also allowed me to angle it more straight up instead of toward the rim.
So things are coming along great, I wrapped my exhaust, that went well. The headers required a little bit more force to seat then I like I won't be able to tell if they will leak at the head until I run the bike. I am a little nervous about that. I guess at the worst it would just be a pain to fix, not impossible. I would have to unwrap the exhaust cut it mount it to the bike again and reweld then rewrap a major pain but doable. I should stop loosing sleep over it. I am still waiting on tires, that pretty much is it other then a few very minor loose ends in the wiring and ride ability set up.
    • My cafe build
« Reply #43 on: January 25, 2010, 08:45:21 AM »
Anyone see anything wrong with this picture?
  • Like a well oiled
    • Undead Asphalt
« Reply #44 on: January 25, 2010, 09:33:21 AM »
no.
Offline wannabridin
  • -Garrett
« Reply #45 on: January 25, 2010, 09:37:01 AM »
not at all!  i think you're just going SO fast that your wheels and tires have turned into a blur huh??
i was following this build over on the superhawks forum, damn fine work my man!  i can't wait for it to be over!!  it's giving me even more motivation to START my build and finish quickly!!!
    • My cafe build
« Reply #46 on: January 25, 2010, 10:54:07 AM »
I think if I only did one thing right it was to finish it quickly... you know before the wife finds out
Offline Zaipai
    • My Home page
« Reply #47 on: January 25, 2010, 06:16:57 PM »
Yea I spotted it right away.. driving with out the head light on.. tisk...tisk...tisk... ;)
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Lefthook
  • I always thought a SOHC was a Ford....
    • TEHdriven
« Reply #48 on: January 26, 2010, 11:37:56 AM »
Dude, I think we're going to have to set up a sohc4 local meet so I can check that thing out.
Amazing job.. some serious fabrication skills.
Offline wannabridin
  • -Garrett
« Reply #49 on: January 26, 2010, 12:21:10 PM »
damn,
i wanna come down to see that thing too!  i'm training in milwaukee, so i'm like 45 min away...
