Author Topic: My CB750 Book and CB500/CB550 Book, by Hondaman: a 10% discount thru 2/9/26!  (Read 348759 times)
Re: My CB750 Book, by Hondaman: 10% off until 2/5/21! :)
« Reply #475 on: February 03, 2021, 05:31:38 PM »
What if I have one of these for sell? New
List it in the For Sale section. Someone will probably buy it: they are pretty popular. :)
Offline beernard
Re: My CB750 Book, by Hondaman: 15% discount until 2/25/22! :)
« Reply #476 on: February 25, 2022, 01:07:34 AM »
Thanks Hondaman. I have benefitted from your given, shared and fantastic knowledge in a disproporsionate way. ie I gave you nothing. I do hope you are well and happy.
Regards, Bern
« Reply #477 on: February 26, 2022, 06:51:16 PM »
Regards, Bern
My reward comes in the form of putting you and this bike back on the pavement together. ;)
Offline 1976_CB750K
Re: My CB750 Book, by Hondaman: 10% discount thru 8/19/22! :)
« Reply #478 on: August 16, 2022, 06:49:46 PM »
Annnd, for my first post, I just ordered your book - looking forward to it. It looks terrific.
I've been here longer than my profile shows; just never got around to posting.
After I finish my current project, it will be time to get this beast back on the road.  8)
Thanks!
« Reply #479 on: August 17, 2022, 04:54:52 PM »
Thanks!
Thanks for getting one! :D
The K6 bikes are the most enigmatic of them all, IMHO. They ranged from slouches to hotrods, depending on which parts Honda scrounged to build them with. They had stopped at the K5 because they were touting the CB750F0, but those sales fell so flat that they scrambled (after American Honda screamed at Honda Japan for discontinuing the 4-piper) to start making them. Some have F0 bottom ends with K5 top ends (lower primary gearing), some have F0 heads on K5 cylinders (low compression, like 8.7:1 or so), some have the opposite with K5 heads on F0 cylinders, with or without domed pistons (domed were about 9.5:1 compression with test numbers like 150 PSI), and some are just normal K5-like top ends on K5-like bottom ends. The second version (domed pistons) above was the hotrod of the bunch. The wiring, too, became 'undocumented' in that short jumper wires with small colored bands on their ends were used to bridge F-type handlebar switches with K-type main wiring harnesses in the headlight in some of them, and no published schematics of these ever appeared (that I've ever seen). But, they managed to all work! :)
Offline 1976_CB750K
« Reply #480 on: August 18, 2022, 05:27:40 PM »
Thanks for the great info, Mark! :)
Are there "early" and "late" versions of the '76; or is it just a matter of digging in and seeing what I've got? (The latter, no doubt.  ???)
I can't WAIT to receive the book and dig into THAT.  8)
Offline 1976_CB750K
Re: My CB750 Book, by Hondaman: 15% discount thru 8/26/22! :)
« Reply #481 on: August 22, 2022, 07:02:15 PM »
Received the book today. Enjoying the read.  8)
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #482 on: August 22, 2022, 11:07:11 PM »
Mark, how much are your books selling for currently?
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
« Reply #484 on: August 23, 2022, 11:34:40 AM »
Use code BACKTOSCHOOL15  to get 15% off on Lulu orders through August 26th.
David
PS subscribe to their emails and they will send you emails with coupon codes. 10 or 15% is very common. 30% occurs sometimes during the year. Most I have ever seen was 40% but only once to my recall.
« Reply #485 on: August 29, 2022, 10:11:08 AM »
There are 3 actually distinct versions of the 750K6 that I have seen: the early, the middle and the last version.
-The early ones used mostly leftover K5 and some F0 parts, mixed in the engines and wiring harnesses. These engines had "K" bottom ends with the dual-sprung clutch steel plates and the "F" clutch basket to make them fit, so the top clutch plate is different from the others. These engines sometimes had F0 heads (392 casting mark in the back) on top of K5 cylinders and pistons. The carb bodies were the same ones used in the F0 bikes, but with the K5 jetting and needles (K27102 needle numbers). These engines only developed around 48 HP because the compression was only about 8.8:1.
-The middle ones had the "K" heads back on them, with "K" pistons and cylinders and "087a" marked carbs. These carbs are much like the regular K5 carbs except for the air screws, which originally had little plastic caps on them that prevented them being turned more than 1/2 turn in any direction off of normal (this was a Carter era EPA "fix" that was supposed to keep us from 'illegally' modifying idle air mixtures and thus emitting excessive hydrocarbons' and was found in cars, too). We just removed and pitched the caps after they cracked, at about 10k miles. You can use a regular air screw in its place, they are internally the same as the K5 carbs. Some of these carbs are marked just "7A". The wiring harnesses were like the early ones, with little jumper wires using bands of color on a colored wire to indicate which end was being jumered into another circuit, as the main wiring harness body was K5 but the handlebar wiring was F0. These engines made about 52-55 HP.
-The late K6 is the best-performing 'K' bike (stock) since the early K1 bikes. It has the K5 bottom end with the F0 top end, Stellite valve guides and all! It has the F0 cam with the above-mentioned carbs, but with the jet needles from the F0 bikes (K132107 or K132102 or K13nnn needles). The important part to note here is the upper end of these needles in the F0/1 bikes have a thicker section that extends further down the needle before the taper begins. This matches to the late-intake-valve-opening of the F0 cam and prevent plug fouling problems: if the earlier carbs are used with these cams, plug fouling is constant and unfixable without these special needles. Using Keyster's needles will also reduce plug fouling in these unique engines, but will also reduce HP considerably. This combination was/is the hotrod version. I haven't seen HP figures for one, but I know from riding them that they will easily exceed the ton in 4th gear and feel much like the K0 in the lower gears. My butt-dyno would estimate them at around 70-72 HP.
« Last Edit: August 31, 2025, 12:57:18 PM by HondaMan »
Offline 1976_CB750K
Re: My CB750 Book, by Hondaman: 10% discount thru 9/2/22! :)
« Reply #486 on: September 01, 2022, 05:11:32 PM »
Thanks SO much, Mark.
Your knowledge of these bikes is truly encyclopedic.
I read the book in 2 days besides skimming the more technical, above my pay grade parts. Excellent! :)
Offline 4CM5
Re: My CB750 Book, by Hondaman: a 10% discount thru 9/27/24! :)
« Reply #487 on: September 24, 2024, 03:35:22 PM »
Just Order the Book! Thanks.
Offline cjskovsen@gmail.com
Re: My CB750 Book, by Hondaman: a 10% discount thru 11/8/24! :)
« Reply #488 on: November 10, 2024, 11:05:33 AM »
Just ordered! Thanks - Found another discount though :-)
Offline mca2
Already had the 750 book and today the 500 book arrived. Looks great in hard cover!
Looking for a NOS CB400f2 tank in parakeet yellow!
Offline cavemanrex
  Just ordered a copy of "My CB 750 Book" from lulu.
  I am just wondering what major difference there is between my Kawasaki ZRX 1200 piped and jetted with pods out in the open and the CB 750? Is it the design of the carbs?
Thanks for getting the book (and helping support these forums)! You sound like you might be interested in the details found in the Performance I and Performance II chapters of the book: these are home-brew mods that can be done (some with a machine shop's assistance) to perk up the post-1970 CB750 to run with the original sandcasts and even the later F2/3 series of the bikes.
There's 4 decades of technological changes and nearly 2x the HP and chassis performance changes between the 2 bikes you mention: the CB750 engines before 1975 were hand-cast in hand-set sand molds, while most all bike engines since 1975 are built in automated injection molding machines, being far more accurately built. ALL of the CB750 frames were hand-welded (despite Honda's new releases of "automatic welders" used after the 1975 models). Today's engines have every detail touched by CAD systems while the 1970s relied mostly on experience and very learned technicians to make correct parts.
The marketplace declared the CB750 to be the world's first superbike, which lit the fuse on a race between Honda and everyone else in the years afterward. The CB750 was also tagged as the first UJM (Universal Japanese Motorcycle), creating the entire UJM all-purpose bike race that ensued in the years after, until around 1990. Honda seemed happy to step back from their performance lead after putting out the incredible CBX Six (ending in 1983), one of the most-desirable bikes of the last century, and turned to building more cars instead of bikes.
When America launched protectionist activities against Honda (first) and other Japanese car- and bike-makers (later) in the late 1970s, Honda slowly stepped back from leading the industry after they produced the CBX Six. Some say this bike was Honda showing the world "what could be" if political and trade issues didn't stand in the way. Kawasaki and Yamaha (and to a lesser extent, Suzuki) stepped into the motorcycle performance arena then as Honda simply backed away from it to make cars their primary product then: one wonders what Honda we might have had if that hadn't happened? ;)
Welcome aboard the forum cavemanrex
What is the major difference? Displacement and carb size along with pumper carbs in the Kawi? Is that what you want to know?
What 750 do you have?
Mark, the DOHC 750's were the natural evolution of the original SOHC, and politics had nothing to do with it. ;) They made 10 more HP, and the 1980 models, which had needle bearings in the swing-arms instead of the plastic bearings used in the '79 750s and CBX, had handling as good or better than the best Ducati of the day. ;D After that, Honda moved on to the V-4 bikes, like the Interceptor, and as far as I know, they still make motorcycles?
« Last Edit: December 09, 2025, 07:56:53 PM by scottly »
Absolutely correct on all counts! Especially the improved swingarms, which Honda changed bearing systems in no less than 8 times in the SOHC4 series.
The DOHC 750 was the same engine as the mighty CBX Six, with 1st-oversized pistons and only 4 of them. The DOHC 750 had the better alternator, though.
The first several years of the V Interceptor engines were a disaster, if you count what happened to them here in Colorado in the 1980s. They were found everywhere, parked on the sides of the roads awaiting towtrucks for things like broken transmissions, failed fuel systems, loss of spark and [some sort of] intermittent stray "handling" issue they seemed to have had. Once in 1985 our church bike club (about 30 bikes, more riders) had me and a friend of mine organize the first-every church motorcycle club ride (we did 4 per year after that until 1990). It went from Denver to Loveland, up the canyon and through Estes Park and Rocky Mountain Park, then south along the Front Range to Winter Park and Berthoud Pass, then I-70 back to Denver, about 350-ish miles of beauty. We started that day with 18 bikes and 22 riders, 4 of the bikes were the [then new] Interceptor V-4s, my CB750K2 in the lead, Johnny on his CX500 riding drag (we kept track of everyone via our CB radios on his & my bikes), the rest being Yamahas, a 1982 CBX (the cafe' racer one) as #2 behind me, some BMWs, a MotoGuzzi V-twin, and 2 Suzukis (I don't remember which ones, or all the rest of the bikes). By the time we got halfway up the canyon to Estes Park. one Interceptor shucked its transmission, being stuck in 2nd gear only, and one of the other Interceptors volunteered to drop out with him and escort him back to Denver. Neither made it home until a week later, on a trailer. A 3rd Interceptor got as far as Estes Park for Breakfast with us, but would not start afterward, we left him there waiting for a tow truck. The last Interceptor made it as far as Winter Park and overheated on Berthoud Pass on the way down (not up!) and opted to stop & wait for it to cool and was going to short-hop it back to Denver: he called for a tow truck later from Idaho Springs, instead. Two of the Beemers (2-up each) turned West at I-70 off Berthoud Pass road to come home over Squaw Pass (my all-time fave ride) and we arrived back in Denver with about half of those we left with, all the 'dead' ones being the Interceptors. Three of those 4 riders sold their bikes that following winter, 2 of them bought other bikes after that: thus was Honda's legacy following those days. I saw more than 7 more Interceptors sitting on the side of Denver freeways during my commutes to work in those days, a sad advertisement. :(
Then there were the [famous?] Hondarleys, which exploded on the scene here for about 5 years, after which they could be bought (still) for $1000 on average. The Gold Wings, of course, were (and are) everywhere in numbers here, even old ones, but they are hardly canyon-scooting rides. They do well on the interstates, though.
Update: this ride was in 1985, not 1982 (corrected above).
« Last Edit: December 10, 2025, 11:29:07 AM by HondaMan »
Offline Perseo
Note here to thank Mark for "My CB500/CB550 Book."  The beautiful hard cover version arrived two days ago and, as they say, I can't put it down.
I don't even own a CB500 or 550 yet, but am in the market.
There is a lot of good learning in the book applicable to my CB400F.
I agree! Mark did a great job on it and on the CB750 books.
