Author Topic: My CB750 Book and CB500/CB550 Book, by Hondaman: a 10% discount thru 12/26/25!  (Read 336364 times)
0 Members and 11 Guests are viewing this topic.
Offline mca2
Re: My CB750 book, by Hondaman: "coupon" for April discounts! (Edit 4/3/10)
« Reply #100 on: April 19, 2010, 01:32:57 PM »
 I'm getting lots of mail about the 500/550, too. My wife thinks I should write that one, instead.  ???  I'll have to get one or two to rebuild so I can get all the pictures: most of the drawings I did are the same for the two bikes, so about 40% of that book is already done!  ;D
I have to say i totally agree with your wife. A book on the 500/550 would be great. And while we're on it, the 400 is also appreciated :)
Looking for a NOS CB400f2 tank in parakeet yellow!
Offline mca2
For signed copies: I have one or two paperbacks left here, and 5 hardcovers, from the First Printing. The next ones I get will be without any errors, and will have the sharpened-up carb drawings. (They will be the Second Printing version, which Lulu.com is also selling now.)
How can i see if i order the second printing version soft- or hardcover at Lulu? I'm thinking of ordering one (Netherlands).
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Try http://www.lulu.com/product/paperback/my-cb750-book-paperback-size-a4/10656822 - the shipping will be less as it is printed in the UK. The A4 version is available in soft cover only though
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline mca2
Thanks for the link. I just ordered it. Lulu talked my into some more expensive shipping (trackable). I hope to receive it soon. now I only have to buy a CB750...  ;D
Offline hoodellyhoo
  • CB350F
I just got mine last night as a birthday gift. I'm having a hard time putting it down! Fantastic job Mark!
BackIntoBikes
Holy smokes, bought this on Tuesday and received it today (Friday)!! Hondaman is giving Amazon a run for their money! (Colorado to Colorado shipping might explain some, but still, quick service!)
Already can't put it down -- so much for work today. Thanks Mark!
Offline tommye
Re: My CB750 book, by Hondaman: "coupon" for 10% off of A4 size (6/2010).
« Reply #106 on: June 21, 2010, 09:31:17 AM »
Got my copy a while ago and finally got some time to read a bit  :)
Fantastic book Mark ! Just the sort of stuff I love !!!
Applied some of the good advice already and it really is spot on !!
Well done HM !!!!!!
Tommy
« Reply #107 on: July 18, 2010, 09:28:35 PM »
What's the status of the new versions?
« Reply #108 on: July 19, 2010, 07:16:07 AM »
Umm...which ones are you referring to, Don?
The current version is the Second Printing. I haven't finished the next book(s) yet. I'm working on a Performance/"F" version next.
« Reply #109 on: July 25, 2010, 10:35:49 AM »
Ooooh he said F version. Cool.
Offline jaguar
« Reply #110 on: August 09, 2010, 03:06:46 PM »
When do you think the F and performance part would be done?  Very interested in that.
Would it be a whole new book or an add on to the existing one?
« Reply #111 on: August 09, 2010, 10:30:05 PM »
It will only be a "new" book in one sense: it will cover only the F1-F3, with some reference to the K7/8, which had similar engines, sort of...the frame features of the "F" bikes included the disc brakes front & rear while the "K7/8" bikes had drum rear, slightly different engine mounts and oil tanks, and the styling was different. The head was different on the F2/3, compared to the K7/8, while the F1 head was a modified version of the earlier "K" engines, with fitments like the F2/3. Between the F1 and K8, there are essentially 3 different bikes, while the K0-K6 was only 2 distinct versions. Many F1 bikes even had model 657 carbs (with a different number stamped on them) in 1976, overlapping with the fading K6 powerplants, but the rest had the PD style with accelerator pumps and very lean mixtures that quickly ate exhaust valves and rings.
It will be a "supplement" to the first book in the sense that I will not go all through the whole Engine Inspection, Engine Rebuild, Carburetor, and much of the Electrical chapters again. The engines are so similar in that regard that all I will cover this time will be the differences, like pointing out the valve and combustion chamber changes and the fact that the upper ends of the later bikes don't directly fit the earlier ones, etc. The electrical systems of the F1-K8 were almost identical, unlike the earlier ones that changed 6 times. A couple of gears in the tranny changed tooth counts, but beyond that, almost everything else "down below" interchanged until the 630 chain showed up in the 1977 models (then the final drive shaft changed).
It's also going to be a lot less pages, possibly 100 instead of the (more than) 260 of the last one. It will be more focused on improving the performance and handling, as this always seems to be the desire of the "F" lovers. So, it will be a lesser work, not intended for the broader audience of the much larger collection of the "K" bikes out there. There are far fewer of the "F" on the road today than the earlier versions, in a percentage sense (Probably due to their shorter-lived, hotter-running engines, in the case of the F2/3/K7/8). And, you'll almost always find the "F" with scraped-up sides, particularly the right side, from the weight imbalance they suffered (big 4-1 pipe, oil tank, and rear caliper all on one side) and their inability to stop in the rain with the front/rear discs. These things can all be addressed, but it takes more than a few posts on the forums!
In most ways, the present book covers the "F" bikes, except for the rear discs and the different combustion chambers (hemi with domed pistons), minor cam and spark timing changes, and PD carbs. The wiring is similar to the K5/K6, except the silly "safety module" was finally replaced with a simple diode (duh). Aside from wire color changes, the handlebar switches and such from the K5/6 all interchange with the "F" and later "K" bikes. Every functional thing is otherwise unchanged. So, to repeat all that 'stuff' would be redundant, and expensive to purchase for the end user. (IMHO...)
« Reply #112 on: August 09, 2010, 10:47:15 PM »
What, nothing on my beloved 1975 CB750K0 Super Sport (as tagged by Honda) lovingly referred to as the CB750F or F0?  :'(
« Reply #113 on: August 10, 2010, 11:36:43 PM »
Ah, the lonely ones...they were the crossover bikes, using the last of the "K" engine parts, but with the hemi'ed heads, 657 carbs (renamed 7A, I think it was), spoked wheels, drum rear brakes, and much better balance! I like those "F" bikes the best, myself, as they "saved" the then-aging 750's reputation on the street!
« Reply #114 on: August 12, 2010, 09:44:49 AM »
I just titled my presumed f0 and learned it's an F1. now this news.
« Reply #115 on: August 21, 2010, 11:31:56 AM »
Got the book and it's awesome! Only problem is I just took apart a master cyl and came in to print the page from manual because I don't want my dirty hands all over it!
Offline Jeff.Saunders
  • Obsessed by Old Motorcycles
« Reply #116 on: August 21, 2010, 01:53:48 PM »
Mark, having had copies of your book for a couple of months now, I can honestly say I've learned a ton from it.  It gets into levels of details not found in any factory or aftermarket manual.  If a customer has a question about the 750, your book is the first one I grab.
I had a local customer in here today who has a K0 (which he rides - although with a later engine in it to preserve the early engine) - I had a hard time getting him to leave as he wouldn't put down your book.  I suspect he'll be buying one...
« Reply #117 on: August 21, 2010, 11:09:41 PM »
Thanks, Jeff, you just might be my first "storefront reference"!  :D
I just bought some more of those pistons of yours, too: excellent stuff. The micro-grooved skirts will be perfect in these (tight) engines I'm building!
« Reply #118 on: August 22, 2010, 08:34:10 AM »
Mark, I can't imagine how many hours of work went into the book...
While the book isn't cheap, the payback on your investment is considerable when you look the time saving and mistake avoidance that comes from reading the book.  I like it as it's written in real world terms and explains more than just tear down and assembly - more of a 'how to and why' than just a 'how to' book.
Offline johnyvilla
« Reply #119 on: August 22, 2010, 11:28:16 AM »
Great book Mark. I was a little disappointed that I didn't get to
 read it until after I built my motor, but there is so much more in the book. I was also glad to see that it wasn't just a compilation of your posts most of us have probably read, but a very thorough look at the history and ownership of the fours we all love . Four pages on chains and sprockets alone! My gosh!
Offline 750
« Reply #120 on: August 22, 2010, 12:40:54 PM »
Just finished the first book.  Cover to cover page by page.  Now reading it a second time and then again until I memorize it.  Any time line on the K7-K8 book yet???????  I'm definitely in for a copy and can't wait until it's on the shelf.  Is there any way I can help expedite it? Picks? Anything to get it to my doorstep sooner?  I'll even come and pick it up in person ;D
« Reply #121 on: August 22, 2010, 10:26:51 PM »
The differences in the "F" and K7/8 engines (compared with the K0-F0 engines) will be pointed out in this next book. The chassis differences from the earlier bikes are in the swingarm (cheaper) and the triple trees (stronger) and the rear tire/rim size change. Of course, the F2/F3 had that rear disc, too. Wiring between the F1 and the other late bikes was almost identical, too.
I'm sure it will take at least all winter: it's a lot of work!  :o
Offline 750
« Reply #122 on: August 23, 2010, 05:10:38 AM »
[/quote]
I can't even emagine the work one must put forth to write books like these.  All winter is short.  I don't know that I could write it in a lifetime:D Good luck with it and thank you for shareing the knowledge in the first one.
« Reply #123 on: August 23, 2010, 04:39:28 PM »
Mark,
in the current book you occasionally mention where later parts can be used in place of earlier parts.  Will you put together any additional info in this area?  For example:  Pistons, Piston Rings, Cams and Cylinder Heads - what interchanges, what doesn't - both within the K series and between the K & F models (and Automatic).  Honda doesn't give much help with their supercession info on rings and pistons, yet I know you can do some mixing and matching.
« Reply #124 on: August 23, 2010, 06:47:32 PM »
Mark,
Most certainly: I get this question a lot.  ???
I'll most likely make it a table or cross-reference of sorts.
In the meantime, the short list 'preview':
The cam question is easiest: all cams interchange, but with varying performance. The 1969-1975 (K0-K6) cam yields more midrange torque than the later version, while the later version is made for more peak HP at 8250 RPM or so. Installing a CB750A cam in a K or F will disappoint the rider from a performance standpoint, but will make his wallet happier with improved MPG.  :D  All of the cams must be degreed-in for proper performance, as Honda was fairly casual about the opening/closing timing on all of them, so long as they made 8mm of lift in production.
The piston question is pretty easy: the early pistons and rings fit everything, even if they lose about 2-3 peak (above 6500 RPM) HP in the 1976 & later "F" and the K7/K8 engines. They breathe better, though, which is helpful for improving midrange torque with hotter (longer duration) cams, and they yield a bit more valve clearance. Conversely, if the early heads are hemi-ed out (as shown in the Performance chapters of this first book) to clear the later domed pistons, and a set of K5 or K6 (i.e., taller) cylinders are fitted to any early "K" engine, and stiffer springs installed, the bike clearly changes its character to a snappier ride, thirsty for more octane, able to leap tall Mustangs in a single bound...
The gearing gets more complicated, but possible, with one notable exception: if the later K4-style shift drum is installed, the shifting will be snappier and the Neutral easier to find.
Some things will be a "replay" of the more subtle, but important things, like using high-quality tranny bearings of the RIGHT clearance, etc., where recently some vendors I've seen have been selling stuff they don't understand so well. (Not your stuff, Jeff: you're on top of it...  :) )
And so it goes...this will be the "flavor" of the chapters outside of pure Performance in this next one. In some ways, I think it will be more challenging, especially for getting the pictures together! I can say for sure that the Engine R&R part won't be rephotographed.  :P
I'm hoping MRieck will forgive me for having to exclude the things I had once put into the first book, but had to remove when the book got too big: I had to 'tone down' the overall performance stuff in favor of getting the book under $100, and the great stuff he sent me was a big step beyond the overall 'feel' of the text. I'd REALLY like to talk him into letting me have some more shots of his work, and even advice, in this next one. He does more radical mods than I have over the years, and his work is first-rate. For instance, I'd like to have a chapter of "The 90 HP engine"... :o  That would take his handiwork, for sure.
