Author Topic: front wheel spacers  (Read 1031 times)
tonys10
front wheel spacers
« on: February 15, 2010, 05:41:44 PM »
I have a 1974 CB750K that I am finally getting back to putting together. I have all of the front axle spacers on according to the microfiche but I still have about 3/4" of play....what have I forgotten?????
Offline Johnie
Re: front wheel spacers
« Reply #1 on: February 15, 2010, 07:15:51 PM »
How about the spacer in my picture? Not the one in my fingers but the one on the axle.
« Last Edit: February 15, 2010, 07:18:29 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline camelman
  • Man... Myth... Legend
« Reply #2 on: February 15, 2010, 07:48:49 PM »
Make sure you have the "nut" in correctly too.  That's the one in his hand in the prior pic.  I put mine on with the flats on the outside once, and it didn't sit in the forks correctly.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
« Reply #3 on: February 15, 2010, 07:55:19 PM »
Camelman
yes be sure the hex goes to the inside. Also be sure you engage the speedo transmission into the speedo drive plate correctly. that won't cause the problem you have, but just be mindful. Two dogs in the transmission mesh with the two notches in the drive plate.
Other than that there is only one spacer, so its likely the nut. The axle butt goes on the speedo drive side, the spacer and nut on the opposite side.
tonys10
« Reply #4 on: February 15, 2010, 08:30:27 PM »
ah, I have the nut on with the flats on the outside right now....I will reverse it and try again.
