Author Topic: High Heat version of Bondo for Exhaust?  (Read 15131 times)
Offline YogiBear
« on: February 23, 2010, 03:01:01 AM »
Im working on a 4 into 1 exhaust for my CB500. It has some dents on the bottom and a slight dent on the outside of the muffler at the end. Im wondering if theres something out there that's the equivalent of bondo that I could use on the pipes? It would obviously have to stand up to high temps.
1974 Honda CB750K4        1973 Honda CB500 Four
Offline MasterChief750
  • Detonation
Re: High Heat version of Bondo for Exhaust?
« Reply #1 on: February 23, 2010, 03:10:34 AM »
i would use a welder as i am not aware of any type of high heat bondo
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
Offline YogiBear
« Reply #2 on: February 23, 2010, 03:13:43 AM »
You think welding would work on such thin metal like the tubes? It doesnt have to be bondo, I just used it as an example. Something like bondo, ya know?
Online Alan F.
« Reply #3 on: February 23, 2010, 04:40:14 AM »
No there's no filler for exhaust pipe dents like bondo.  As masterchief1112  said, if you were to have the dents filled with weld or braze, you could grind and sand the area smooth thus filling the dent.  If the pipes are too thin, then they're probably rusty inside and not worth the effort.
  • Detonation
« Reply #4 on: February 23, 2010, 05:12:38 AM »
a good welder can weld pop cans together without burning through, i cant but the man who taught me can, it would need to be the lowest heat possible so as to not burn through but someone should be able to fill weld them for you.
I AM THE STIG
Sam is THE STIG
« Reply #5 on: February 23, 2010, 07:32:33 AM »
Its called brazing rod, Steel filler rod, and if its far enough back.. maybe solder...
 Why dont you try to massage out the dent?
Offline Ichiban 4
  • "Ichi"
« Reply #6 on: February 24, 2010, 12:05:27 AM »
There are high heat epoxy type products out there in the market place.  Devcon used to make an aluminized product..that you could repair crank cases and cylinder heads with.  [By "high heat" I mean up to around 500 degrees F].  Excepting for the head pipes..I don't think most rear pipes/mufflers get even to 500 F.
One problem with the Devcon..other industrial type products..as mentioned is 1.) they're hard to get in small quantities (like less than a gallon??) and 2.) they're usually quite expensive.  It's been years since I've priced that stuff..but way back when..a gallon of that stuff was well over $100.00 per gallon.
May be..as others have mentioned here..that brazing or silver soldering (by a skilled welder) may be your easiest..cheapest bet.  Don't think regular lead-tin solder would hold up on an exhaust pipe BTW.
Good luck,
Ichi
Al Summers
Present: '77 550K
« Reply #7 on: February 24, 2010, 12:13:20 AM »
I use to use Devcon to fix brake master cylinders on bikes that had been dropped and i could buy it in a tube, never had to buy it in bulk here in Aus.
Offline Gordon
  • 750K1, 550K2
« Reply #8 on: February 24, 2010, 12:23:46 AM »
I used a product called "muffler mender" that I got at the auto parts store on a hole in the #3 muffler on my 550 over two years ago and it's still holding strong.  I don't know how well it would work as a dent filler, but as long as the bonding surface is sufficiently clean and roughened I don't see why it wouldn't hold at least as long.
« Reply #9 on: February 24, 2010, 07:37:15 AM »
 I used Devcon fillers on fibreglass on a fairly regular basis a few years back.
 It came in a box about 4 x4x 5 inches, which had 2 containers inside, it is pricey though. We used it a lot on fibreglass overlay drilling templates, used on Western Star truck bodies at the factory..
 But on exhaust, I would try to pop out the damage, if you can post a pic , I may be able to tell you how to fix..
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #10 on: February 24, 2010, 07:57:07 AM »
try thin layers of jb weld. i did this for a vw exhaust collector on a merged exhaust on a 65 beetle years ago and it held for many years.
Mark Twain - Notebook, 1894
Offline MaaseyRacer
    • Fuelist
« Reply #11 on: February 24, 2010, 01:33:28 PM »
I used JB Weld to fix a crack in my old Honda's transmission case while I was coming home from a road trip.  It held for two weeks while I was sourcing replacement parts.  I am sure it would have held longer, but I did not chance it.
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1970 Triumph Bonneville
1972 Honda CB450
1975 Norton Commando
Offline YogiBear
« Reply #12 on: February 24, 2010, 05:29:32 PM »
Well, I guess ive got options to explore now. Thanks guys.  ;)
Offline country joe
« Reply #13 on: March 09, 2010, 01:02:23 PM »
My grandfather used to use the muffler mender stuff (He was too cheap to buy new mufflers) with good results. If you got the surface sanded and cleaned good, it should stick. After it dries, sand it into shape by hand. A power sander might overdo it. I have a similar problem to yours. I've got a '78 550 with a good 3 inch long dent in one of the sides of the exhaust. I'm bobbing this bike, so what i am doing is cutting the mufflers off right where they start (which I was going to do anyway) drill a hole in the dent, then use a slide hammer and pull the dent out a little bit. I would then weld up the hole, sand and paint the pipes heat paint black, then use some of that black heat proof pipe wrap. That should fix it up nice. Anyway, that's what I'm doing to mine just trying to throw you some ideas.
'78 Honda CB550K
'79 Yamaha IT400
'74 H-D Sprint 350 (basket case)
