Author Topic: Pix of My Cheapo $12 Vacuum Brake Bleeder  (Read 6571 times)
Offline elquenada
« on: March 20, 2010, 05:07:45 PM »
I am a cheapskate and I love making stuff so I whipped this up before installing my new brake lines tomorrow.
I used a brass 1/4 barb fitting, a brass coupler and a rubber gromet (roughly $5) to make a tightly sealed port for my brake fluid to run into.  In order to provide sucking power I got a "wine saver" from the super market for about six bucks.  Since the wine saver is a little small for the soda bottle opening I fattened up the top of the bottle with some electrical tape toi get a tighter seal.
So far Ive only test it with water but it seems like it will do a fine job.
1975 CB 550
"A veces lo que es contra lo justo
por la misma razón deleita el gusto"
Lope de Vega
Offline wannabridin
  • Patience made me a
  • -Garrett
Re: Pix of My Cheapo $12 Vacuum Brake Bleeder
« Reply #1 on: March 22, 2010, 06:29:56 AM »
nice tool!!  i got my brake bleeder at harbor freight for about $15 or so with a coupon, and there's a lot of attachments with it.  so just in case others don't wanna make it or can't get a vacuum device...
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92474
with a 20% off coupon, you're only looking at $16, so just food for thought.  good thinking though with yours!  hope the bottle doesn't collapse with too much vacuum...
Offline markb
  • When I finish my current project I might be a
« Reply #2 on: March 22, 2010, 07:44:55 AM »
Great ideas.  So I went to check the $16 one and found this one too, for $4.99!  A lot like the original post.  I might have to try this one.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=37201
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline wannabridin
  • -Garrett
« Reply #3 on: March 22, 2010, 01:35:54 PM »
the vac does make it much easier!!!  and an enlarge master cylinder fluid bottle would make it even EASIER!!!
but to explain how it works real quick...
1. you hook up the vac handle to a container, then to your bleeder nut on your caliper.
2. take off the master cylinder reservoir cover and fill with fluid.
3. pump up the handle on the bleeder and crack open the bleeder.
4. watch for bubbles and the amount of vacuum on the gauge.
5. close bleeder nut and pump up brake handle (not always necessary, but i like to do this to help ensure a good flush)
6. top off master cylinder reservoir if necessary.
repeat steps  3-6 until you have nice clear bubble-less fluid coming out of the bleeder nut.  be sure not to allow any air into the system while the bleeder is open.  otherwise you have to start over  >:(
i hope this helps!!!
oh ya, if you have 2 calipers, then repeat this step for each caliper
