Author Topic: 78 750F Chopper/Digger  (Read 95546 times)
Offline lucky
Re: 78 750F Chopper/Digger Project
« Reply #75 on: November 09, 2011, 07:23:12 AM »
Sorry, but it will be getting painted.  I am going to keep everyone in suspense.  You will know when you see it.  No bologna, please.  The last thing that will go on this bike is a killer clear points cover that some drunk who hangs out too much in the SSDB made me.
Not painting the frame is a real mistake.
It needs corrosion  protection or you can kiss it goodby.
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #76 on: November 09, 2011, 09:30:49 AM »
....in 30 years.
Offline coma13
  • Lex Talionis
« Reply #77 on: November 09, 2011, 06:05:57 PM »
I'm loving this build.  8)
They wail and weep,
The march of the sheep,
As they go to that cross on the wall.
Offline SOHC Digger
  • I'm not an
« Reply #78 on: November 10, 2011, 07:11:34 AM »
CycleX 520 Chain kit ordered!  Will be ordering front master cylinder kit and brake pads next week.  After that, I will be turning the ten mile radius around my house into a proving ground!
Offline Raef
« Reply #79 on: November 10, 2011, 05:35:06 PM »
....in 30 years.
if you throw acid on it, leave it out in the rain and ride it on snow covered salt treated streets
Offline SOHC Digger
  • I'm not an
« Reply #80 on: January 06, 2012, 11:38:58 PM »
CycleX 520 chain kit did not disappoint, as usual with them!
Rebuilt front and rear master cylinders, assembled and bled the brake system, fixed a sticking float needle, and threw a mirror on.
I tried to take her on the maiden voyage today, seeing as it was 56 degrees here, but she wouldn't start.  I think I have weak spark.  So, we'll throw a new set of plugs in and check it out.
Offline wedoo2
« Reply #81 on: January 07, 2012, 03:18:07 AM »
Digger, with that engine painted orange, I've got two words for your paint colors:
GO BEARS!
Some days the sun is too loud.
Offline SOHC Digger
  • I'm not an
« Reply #82 on: January 07, 2012, 08:09:10 AM »
GO BEARS!
Ha!  Nope.  Ain't happening!
Offline lucky
« Reply #83 on: January 07, 2012, 09:27:46 AM »
Early April.  Rigid frame with original front end and stock comstar wheels.  The frame has about 40 degrees of rake.  I gotta say, I do love the look of those wheels too.
Who made the frame????
Offline SOHC Digger
  • I'm not an
« Reply #84 on: January 07, 2012, 10:35:30 AM »
A.E.E. back in the day.
Offline SOHC Digger
  • I'm not an
« Reply #85 on: January 11, 2012, 11:14:15 AM »
Maiden voyage today!!!  You can't slap this grin off my face!  Damn does this bike ride nice too!!!  ECSTATIC!!!
Offline hapakev
  • Your Standard
« Reply #86 on: January 11, 2012, 07:42:02 PM »
Sweet looking ride man!
Smoking Jack
1978 CB750F(ish)
Offline hapakev
  • Your Standard
« Reply #87 on: January 11, 2012, 10:31:48 PM »
Hahahaha Nice!
Smoking Jack
1978 CB750F(ish)
« Reply #88 on: January 12, 2012, 07:17:03 AM »
YOU, are the frigging man Digger! woot woot
Offline Really?
« Reply #89 on: January 12, 2012, 08:26:25 AM »
Building a crotch bobber would seem like a fun project.    Just can't let go of $800 for a cyclex frame.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline hapakev
  • Your Standard
« Reply #90 on: January 12, 2012, 12:13:31 PM »
Cycle One sells a $350 weld on hardtail and you get to keep the stock vin#/registration.
Smoking Jack
1978 CB750F(ish)
Offline SOHC Digger
  • I'm not an
« Reply #91 on: January 12, 2012, 10:55:52 PM »
70's frames like this one from AEE, C&G, Santee, or Amen can be found on Ebay for the $400 range, and the cool factor is much higher in my opinion.  You're running a vintage engine, why not put it in a vintage frame?
Offline Ricky_Racer
« Reply #92 on: January 13, 2012, 06:18:35 AM »
Digger, agreed on the cool factor.  For many guys the problem is the lack of an MSO.  How're you handling your titling in Illinois?  RR
Offline SOHC Digger
  • I'm not an
« Reply #93 on: January 13, 2012, 06:44:46 AM »
Providing Bills of Sale for everything major, frame, engine, etc.  I will let you know how the titling process works out.
Offline Ricky_Racer
« Reply #94 on: January 13, 2012, 09:16:35 AM »
Cool. That's how we have to do a SPCN (Special Construction) here in CA as well. It's not as bad as in some states.  BTW, nice build! She's got a great profile.  RR
Offline SOHC Digger
  • I'm not an
« Reply #95 on: January 16, 2012, 10:47:55 PM »
Just placed an order for one of Tintop's anti-pod kits.  I think performance wise this is going to be the best approach.
Also plan on ordering this exhaust from CycleX this week:
Once I have these two things, I should be able to fine tune the carburetors.
Until then, I just have to take care of a couple things the state requires to title a bike:  horn (lame), horizontal license plate (lame), brake light switch for foot pedal (not so lame I guess).  Then it's on to the business of title application.
Offline SOHC Digger
  • I'm not an
« Reply #96 on: January 21, 2012, 12:01:15 AM »
Exhaust should be here Monday, Tintop's Anti-Pod kit around Feb 2nd or 3rd.
Offline SOHC Digger
  • I'm not an
« Reply #97 on: January 29, 2012, 07:26:18 AM »
Ok here's how the CycleX exhaust looks.  I am pretty pleased for the most part, but I still don't have a lot of ground clearance (probably because I'm only starting with about 5" from the frame to begin with).  If you look though, there is room to bend the pipes a little and bring in up more in line with the frame.
Sounds great though!  Much quieter than the four straight pipes, but still loud enough to command attention.
Offline KB02
« Reply #98 on: January 29, 2012, 11:29:06 AM »
I agree. Bend the headers just a degree or two to get them closer to the frame. Then pull the muffler off the headers and put in a short extension pipe - 6 to 8". Bend that pipe just about the same spot as the frame does to have the pipe follow the line of the frame than slap the muffler back on. It will look much slicker.
Great job on the bike overall. I like the engine's color scheme!  ;)
(Pardon my crude photoshop skills...)
« Last Edit: January 29, 2012, 11:39:11 AM by KB02 »
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline lucky
« Reply #99 on: January 30, 2012, 11:02:55 AM »
I did a little color correction for you and got a lot of that magenta out.
Click one time on photo  to see larger image.
