Author Topic: Who has the fail safe method to.................  (Read 1401 times)
« on: April 29, 2010, 01:01:49 PM »
remove the vin plate from the steering neck? Please advise. I just picked up the frame from the welder and need to take it to the powder coater.
AND, brother can you spare two VIN tag rivets while I'm begging??
Re: Who has the fail safe method to.................
« Reply #1 on: April 29, 2010, 01:38:09 PM »
There was a post where a guy showed some round headed brads that were dead ringers. He got them from the local hardware store.
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #2 on: April 29, 2010, 01:44:03 PM »
VERY carefully take a small, narrow chisel and tap around the head of the rivets then knock them right through the holes and out of the bottom of the neck
Mark Twain - Notebook, 1894
Offline markb
  • When I finish my current project I might be a
« Reply #3 on: April 29, 2010, 01:58:53 PM »
What they are is a Type U Drive Screw.  Much safer in my opinion is to drill them out after carefully center punching them in the exact center of the head and using a drill that is the diameter of the screw.  Then the head just falls off when the drill gets to the screw.  You'll still have some fun after that because the plate also has glue under it.  But you can and should remove them before painting and especially powder coating.  Check out this link for more info:
http://forums.sohc4.net/index.php?topic=29686.0
Mark
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
« Reply #4 on: April 29, 2010, 04:14:14 PM »
You can easily knock them out by
tapping on them with a socket extension
from INSIDE the neck tube.
With a little luck you may be able to reuse them.
Bikes parked out front mean good chicken-fried steak inside.
« Reply #5 on: April 29, 2010, 05:48:08 PM »
Not exposed inside the neck  :(
« Reply #6 on: April 29, 2010, 06:02:03 PM »
MarkB,
Good link! Thanks much. Looks like I'll have plenty leftover for everyone else.
« Reply #7 on: May 10, 2010, 08:36:57 PM »
MarkB,
Thanks for the 4 Type U Drive Screws aka tag rivets. Looks like I'll be removing the VIN plate tomorrow in preparation for powder coating thanks to your gift.
Jerry
« Reply #8 on: May 10, 2010, 08:47:57 PM »
How many VIN - TAGS did you need to go with those rivets SIR.  Your order is waiting Sir   ;D   Keep those Super Sport 750"s Alive -----------
