Author Topic: Norwegian cafe.. Oil tank in the swingarm....  (Read 109295 times)
Offline lordmember1969
Re: Norwegian cafe.. Oil tank in the swingarm....
« Reply #400 on: June 02, 2012, 11:39:19 AM »
Hi Guys :) :) :)
The fork works just fine:) Was out riding today, and if weather is warm it is just right. When cold as it often is up here it is a bit slow on the rebound... So will go for thinner fork oil. You may all be right but in my case the welding seems to be OK.. :) Will report when thinner oil is tested but does not bother me to much so might be not be done til after riding season..
will now just enjoy the bike :) :) :) ;D
thanks for the interest
Cheers
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
Offline Syscrush
  • Sold. :(
« Reply #401 on: June 02, 2012, 06:21:14 PM »
THAT is what it's about!!!
Offline 23tbucket
« Reply #402 on: June 02, 2012, 07:40:27 PM »
About welding aluminum without distortion......submerge the item in water except the area to be welded or run a slow stream of water everywhere except where the welding has to be done. I've never done this, but have heard of this process.
:Two cents Clifford
Offline Mtmooradian
« Reply #403 on: June 03, 2012, 04:30:48 PM »
You want the whole piece to be the same temp, if just the weld area is hot it will expand where your welding is and shrink when cooled..... This will cause massive distortion.
These legs are cast because it's cheaper.
Offline Syscrush
  • Sold. :(
« Reply #404 on: June 04, 2012, 06:13:16 AM »
Do you have any glamor shots of the bike in its current state?  Any coming?
« Reply #405 on: June 04, 2012, 10:16:26 AM »
yes ve vant new pichs. with the finish bike
.helst fra kongens udsikt..oppe på bjerget...
« Reply #406 on: June 04, 2012, 10:32:34 AM »
Will see what I can come up with :) :) :) Still have plans for the exhaust and some other stuff it is not done yet:)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline Bugster
« Reply #407 on: March 17, 2013, 03:03:46 AM »
Hi Robert.
Fun reading. I really should be focusing on my physics studies, but this is fueling my new addiction.
First post on this forum by the way.
I noticed the excellent soldering craftmanship done to your oil cooler tubing  ;D
Bout time you got rid of that other junk that is clogging up your garage space, and getting around to get those last bits and pieces done in time for the season.
« Last Edit: March 17, 2013, 03:10:16 AM by Bugster »
« Reply #408 on: March 17, 2013, 08:30:25 AM »
no posts sine june last year..hope all runs fine in norvay ???
« Reply #409 on: March 18, 2013, 12:19:16 AM »
Hi Robert.
Hi  :) Thanks :)Yes you did a excellent job on that tubing :) Will start working on the bike again when done with the Model A , Me and Halvar have been burning the midnight oil on that project this winter .. Hope to see your project on the forum soon?
Robert
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #410 on: March 18, 2013, 12:41:31 AM »
Hi:) All is well,  a lot of snow but other than that fine  :) :) :) :D Have been working hard on a Ford Pheathon hot rod project this  winter so the bike has been in storage elsewhere.. Will start working on it again when done with the car :)
« Last Edit: March 18, 2013, 09:30:44 AM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline Bankerdanny
  • Endeavor to persevere
« Reply #411 on: March 19, 2013, 02:31:30 PM »
That is awesome. Clear coat it and leave it be!
Offline Bugster
« Reply #412 on: March 20, 2013, 10:57:56 AM »
Well, not much of a project yet.
I am sitting in my hotel room in Trondheim and sourcing out some parts for that engine I hauled out of your garage the other day. I have ordered carbs, and am bidding on ignition parts. I belive I need to order a top end gasket kit, because I think I need to "off with the head". I suspect that the valves needs to be lapped.
If I get a deal on that 550 this weekend I might just start a thread when I start building.
« Reply #413 on: March 20, 2013, 11:01:45 AM »
Thanks :) :) :) No paint or bondo on this one ;) Will go for the patina look :)
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #414 on: March 20, 2013, 11:09:50 AM »
Cool :)  I would just start the engine when gathered the parts missing and see what it sounds like. Then order a top end kit if it sound bad :) :)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline Bugster
« Reply #415 on: March 20, 2013, 12:54:13 PM »
All the valves was farting when I inspected them, but I will give it a go.
As a former driver of old british motorcycles/farming equipment I also need to go trough a personal transition before taking on this task. To start with, I am actually eating sushi as I am writing this  ;D (Not kidding)
« Reply #416 on: March 21, 2013, 09:04:32 AM »
 :) :) ;) ;D :o :o
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #417 on: March 21, 2013, 12:18:35 PM »
those farmers freakes are the vildest...just say ferguson..6 cylenders 99 hk perkins..made in france
« Last Edit: March 21, 2013, 12:20:42 PM by strynboen »
Offline Hummel
« Reply #418 on: March 06, 2014, 01:46:55 PM »
Any Update on the svingarm ? This is a really interesting idea and I think a want to copy it ;) if that okay.
I wondering if you wanna have oil in the boxed tube on the svingarm or only in the welded tank in the middle ?
Are you sure the oilpump will be fed enough when the oil tank is placed so low ? And what about the breather hose, when the oil is pump back in the tank wouldn't is just fill the tank up and press the oil out of the breather hose ??
Just a few concern to your design I hope you will correct me about :)
Thanks
Tommy Denmark
Offline Mtmooradian
« Reply #419 on: March 06, 2014, 02:52:31 PM »
Mine works
http://forums.sohc4.net/index.php?topic=105803.0
Offline Mtmooradian
« Reply #420 on: March 06, 2014, 02:53:19 PM »
I get about 3qts total cap. No breather
Offline Mtmooradian
« Reply #421 on: March 06, 2014, 02:53:37 PM »
3000miles no problems
