Author Topic: clubmans, clip ons or euro bars...  (Read 8599 times)
bmarshall
Re: clubmans, clip ons or euro bars...
« Reply #25 on: February 16, 2010, 12:07:04 PM »
check out the bars on a 09-10 Triumph Thruxton very cool. Kind of a cross between drag bars and clubmnans
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #26 on: February 16, 2010, 12:25:57 PM »
i do like those...  dangit!!  the decision here is kind of a big one!!
ok, so what kind of bars will yield a more aggressive approach to handling?  i've ridden some "streetfighters" before with MX bars on there, and they were comfy and i felt like it was easier to dip into the turns because my CG was higher.  thoughts?
Offline wannabridin
  • -Garrett
« Reply #27 on: February 16, 2010, 12:55:58 PM »
http://www.sportingforless.com/servlet/the-51/Chrome-Motorcycle-superbike-bar/Detail
what about a bar like that?  it's cheap and it would fit the GL top clamp right?  this is another issue the superbike bars would address, cleaning up the clamp mounts without shaving the clamps off!!
another question, what's the spacing between clamps on a '76 GL1000 front end?  it's 7/8" as well right?
« Reply #28 on: February 16, 2010, 02:45:39 PM »
Hi mate, when i had most of my Honda4's in the 80's i rode them as hard as they could be ridden on the road and i used superbike bars on all of them. I have always braced my frames and used steering dampers.
I had a friend back then that raced his with the same bars..
Offline BlackMax
« Reply #29 on: February 16, 2010, 03:00:57 PM »
Clubmans look cool, and "make" the cafe look.  However, I took mine off and went old-school (stock).   Way comfortable and still looks fine.   I'd vote fro Euros.  If you're going to put any miles on it, you dump the clubmans or clips eventually.  Just not practical, except around town for fun.
1978 CB750SS, 4-1 Yoshi, Pods, 3-angle valve job, ported chambers, ported intake, 41a cam
Offline mixstup
« Reply #30 on: February 16, 2010, 05:42:52 PM »
Try Mikes XS.com ,they have Clubmans,Euro,Honda Cb750,Clip-ons and Superbike bars all in one place and good prices,good service too!
cheers
Offline fatmatt650
  • Part Deux
« Reply #31 on: May 30, 2010, 08:44:12 PM »
Quick question - I believe I need a 37mm clip-on for my 76 cb750f but fastfromthepast lists the fork tubes http://www.fastfromthepast.com/servlet/the-1097/Honda-CB-750-F1/Detail as 35mm. Which size clip-ons should I order?
« Reply #32 on: May 30, 2010, 09:36:25 PM »
I believe all the CB750's had 35mm fork tubes. If you have any doubts, measure yours before ordering.
