Author Topic: Bikes wierd and wonderful  (Read 111125 times)
Offline Magilla
  • My bike: 1976 CB750F
Re: Bikes wierd and wonderful
« Reply #425 on: May 11, 2012, 07:05:49 AM »
What is the red bike two up in the top picture Magilla?
I can't make it bigger to see, looks a bit like my S83. ;D
No red bike.  If your talking about the purplish bike with the fat guy and the kid, that's me and my boy riding in Daytona on an 83 rubber mounted Shovelhead Harley Davidson.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline buca
« Reply #426 on: May 11, 2012, 07:57:04 AM »
Hey that's a beautiful BMW race bike Buca, I'm playing with a R100RS project at the moment, tell me what you've done to achieve 85 BHP mate, I love my "Bavarian Murder Weapon", but I laso have a 2007 Triumph Rocket III, and the BMW feels a little bit underpowered in comparison? Cheers, Terry. ;D
Hi Terry, working lot to make that. Most important mod is longer stroke. Typical BMW 1000 cc cylinder dimensions are 94 x 70,6 mm. Mine is 93.43 x 72.6. I use forged flat top piston from auto racing program and machined con rods longer for 11mm and smaller bering. Stock is 48mm mine is 45mm . Con rods are carillo style H beam made from light aluminium alloy. Heads are R75 with biger intake valve. Must use smaler head chamber due to flat piston to get comression 10 to 1. Camshaft is 286 with 0.8 mm more lift. But stock R 90 S cam will do the same. I get these by chance and it is good. Take lots of weight from flywheel/clutch assembly. Allmost 2 kg. From crankshaft 0.5 kg minus. On piston/conrod 130 gramm less than stock. Dellorto carb 38mm. Reving up to 7200 but is good for 8000 safe on shifting. I get biger stroke on crank with offset machining for smaller bering diameter. For hill climb use 3.36 ratio that is 175 kmh on 7000 rpm 4th gear. For road racing 2.98 wich is top speed 215 kmh.
« Reply #427 on: May 11, 2012, 05:51:08 PM »
That is beautiful mate, where did you get the stroker crank? I'm looking at this big bore kit with stronger rods and asymmetrical cam from Flatracer in the UK, what do you think of it? Cheers, Terry. ;D
http://flatracer.com/#/bmw-performance/4538136890
Offline buca
« Reply #428 on: May 12, 2012, 12:33:21 AM »
I made crank myself. It was most delicate work of all. Because I machined conrods ( not me, in machine shop!) I can  choose smaller flying  bering, from stock 48 mm I make 45mm . That s why I can ,when machining crank , make 2mm offset .Center of flying bering in that case move for 2mm and make longer stroke. very simple bat must have good and skilled machine operator. But in that case all original  surface hardening is gone and only base material left on crank. Then cranks must ( friction surface) be re chromed . That is the trick, but after do it all right that crank is allmost 100% wear free!I use con rod berings from BMW car racing program. From E 36 engine . And pistons are for early M3 models 4 cyl. 2.3 lit engine. Also cast cylindres for that pistons because of specific dia. Stock BMW R 100 is 94mm and mine is 93.43 . I want to cast cylindres anyway . Cast it at Solarevic Machine works . We make this year first few replicas of Fontana drum brakes 250mm.
Think that light pistons and con rods are better investment than big bore. Asymmetrical cam is ok. Give useful, wide  power and torque band.
« Reply #429 on: May 12, 2012, 02:55:38 AM »
That's fantastic mate, and very smart too! I should get you to build a fast engine for me! Cheers, Terry. ;D
Offline buca
« Reply #430 on: May 12, 2012, 03:35:07 AM »
Glad you like it. One more thing my crank is not 180 flat. but 182. Engine is smooth through whole rev range and reving so fast and light that I must be very careful not to over rev it. Zero vibrations . Reving almost the same in 2nd and 4th gear. And four speed gear box is better than five speed!!
Offline buca
« Reply #431 on: May 12, 2012, 04:55:33 AM »
     БУЛЕ
« Reply #432 on: May 12, 2012, 06:11:06 AM »
Looks great mate, do you have a youtube clip of it running? Cheers, terry. ;D
Offline buca
« Reply #433 on: May 12, 2012, 06:24:59 AM »
Not at the moment, but have something and will post to you.
Offline buca
« Reply #434 on: May 12, 2012, 01:40:58 PM »
One of my projects is this chopper. Frame is modified IIWW zundapp ks 750 side car , engine honda XRV 750 everything else, pretty much, made by myself. Did not finish yet due to priority list change in favour of Transamericas motorcycle world record attempt 2012.
Offline buca
« Reply #435 on: May 12, 2012, 01:46:23 PM »
« Reply #436 on: May 12, 2012, 04:33:16 PM »
That's an interesting custom mate, and certainly deserves a place in this thread, a modern Honda engine in a WW2 Zundapp frame? Weird AND Wonderful! Cheers, Terry. ;D
Offline Hush
wtf?
« Reply #437 on: May 13, 2012, 07:31:43 PM »
And you think this may have got a certificate of inspection! Check out the gas tank!
Online CycleRanger
  • No comment about being an
« Reply #438 on: May 14, 2012, 08:46:34 AM »
Saw this on CL.   '76 with a YZ250 front end.  ::)
« Reply #439 on: May 15, 2012, 02:31:39 AM »
Ha ha, well I had a Yamaha XT500 once, and to be honest, that 650 wouldn't have been much worse in the dirt! ;D
Offline Radam
  • taco racer
« Reply #440 on: May 18, 2012, 05:09:40 PM »
buca, you've made some cool bikes, and I love your shop! By the way, I've got a question that I'm not sure you can answer honestly,... are you Batman?!  ;D
Offline buca
« Reply #441 on: May 19, 2012, 12:01:37 AM »
Yes, I am Batman! Reveled after all this years!
« Reply #442 on: May 19, 2012, 03:07:25 AM »
Ha ha, and considering how close Serbia is to Romania, Buca might be "Vampire-Bat man"! ;D
Offline Hush
In the wonderful category
« Reply #443 on: May 19, 2012, 12:21:20 PM »
This nice example for sale here in NZ of a 72 Suzuki T350, I had one of these as my first "big" bike and being able to attain 100 mph any time you wanted was the ultimate thrill. Looking back they were pretty agricultural and who decided brown was a good colour for the cables?
Still there is something thrilling about the resonant sound of a 2 stroke twin (T500 T350 T250) from those long chrome pipes...... ;D
http://www.trademe.co.nz/a.aspx?id=477043052
Offline Hush
BSA Bantam
« Reply #444 on: May 28, 2012, 01:56:39 PM »
Always had a soft spot for these little beauties, they were a dime a dozen when I was growing up and with the arrival of the Jap stuff no one seemed to want them much.
It's one of the few real vintage bikes I would give garage space to. ;D
http://www.trademe.co.nz/a.aspx?id=479716218
Offline Flying J
« Reply #445 on: May 28, 2012, 02:20:42 PM »
Do you do all your work in a cave? Wish I had one. My garage gets hot.
Offline Hush
Vincent
« Reply #446 on: June 01, 2012, 11:42:22 AM »
Heard stories of these legendary bikes when a very young bloke, supposed to be very quick for their time, looks like this one has been lying in a dusty shed for a long long time but definitely a great project.
http://www.trademe.co.nz/a.aspx?id=480986327
Offline Hush
Matchless
« Reply #447 on: June 01, 2012, 11:44:33 AM »
Another of the Wonderful category, last from the mighty Matchless stable, isn't she a beauty?
http://www.trademe.co.nz/a.aspx?id=480915903
Online CycleRanger
« Reply #448 on: June 01, 2012, 09:57:17 PM »
Wonderful! :)
Offline Hush
« Reply #449 on: June 02, 2012, 01:59:06 AM »
I would seriously ride that CycleRanger, love the bars but the seat doesn't look like a 1000 miles of comfort! ;D
