Author Topic: Anyone running drag bars?  (Read 7418 times)
Offline 750K8 Kev
« on: July 12, 2010, 04:19:07 PM »
Is anyone running drag bars? and if so what size? I just got my drag bars on my bike and found out that I have no room for my master cylinder assembly. It looks as though I need them to be at least 31"-32" wide for my throttle to be able to sit flush at the bars edge. I am having a hard time finding 7/8 drag bars 32" wide.
I have a 78cb750k
« Last Edit: July 12, 2010, 04:23:54 PM by 750K8 Kev »
Offline Tintop
Re: Anyone running drag bars?
« Reply #1 on: July 12, 2010, 04:51:47 PM »
have a similar issue with my build.  master's banjo is up against bar mount when everything is in place.  throttle is right at end of bar.  can solve by going to a more modern master (shorter). :(  if you find bars though please post a link, as I would prefer to use the old round style master.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Rich361
« Reply #2 on: July 12, 2010, 05:32:28 PM »
Hi,
I know it's a long way but a guy in Nelson, New Zealand makes custom Handle Bars.
http://www.thehandlebarcompany.com/
It says on his website that he will make to your specifications....
He's making me a set at the moment for my Cb400f.
Not sure what international shipping will cost, but with NZ to US dollar it shouldn't be that bad.
Cheers
Rich
1975 CB400F
Offline 750K8 Kev
« Reply #3 on: July 12, 2010, 05:51:09 PM »
Thanks for the link. I think I'm gonna check out some local shops
Offline Tintop
« Reply #4 on: July 12, 2010, 06:14:21 PM »
I am running 28" drags, but haven't put on the master cylinder yet. Am I in trouble?
I am to the shop tomorrow to do some electrical prep, and talk to the painter about the tank.  will take a picture of my bar, with all stock 550 controls.
77 CB550 Cafe build
Offline Trav-i
  • Has finally become an
« Reply #5 on: July 12, 2010, 06:27:37 PM »
After a very quick search here are some pics for you.  Drag bars are doable, but take a bit of fancy engineering to make work.  Here ya go.
Forum member #9962
1992 GL1500 Interstate
Offline NickC
« Reply #6 on: July 12, 2010, 06:36:18 PM »
On my 550, I shaved down the edge of the gauge bracket a bit and got good fitment in there.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #7 on: July 12, 2010, 07:42:40 PM »
If any of y'all wana sell your stock bars, throw me a PM!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline bradweingartner
  • 74 CB 550 x2
« Reply #8 on: July 12, 2010, 09:25:26 PM »
A buddy of mine runs drag bars and I'm half-way through installing mine. I recall him having some issues with the master but don't recall what the specifics were. I'll let you know how mine turns out.
Offline 033A2
« Reply #9 on: July 13, 2010, 04:17:07 AM »
I'm running 28" drags on mine. Had them drilled so I could run the wires internally.  Everything fits, but it does take some effort, especially the master cylinder.
Offline haill
« Reply #10 on: July 13, 2010, 04:26:45 AM »
why don't you cut two sections off your old bars your replacing and weld it to both ends? Grinding the welds smooth, giving you the length required. The grips will cover up the welds. Used this method and it works well.
Offline KB02
« Reply #11 on: July 13, 2010, 04:59:10 AM »
Not to thread hijack, but do you have any more pictures of your bike? Looks pretty cool.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline 033A2
« Reply #12 on: July 13, 2010, 09:37:16 AM »
Thanks for the compliment.  If no one else minds, here are a few more pics.
K.
Offline Really?
« Reply #13 on: July 13, 2010, 10:02:56 AM »
Each time I see that bike I think it's Momma's Ride at first 033A2.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline 033A2
« Reply #14 on: July 13, 2010, 11:32:11 AM »
If you're referring to the bike I'm thinking of, they are somewhat similar.  That ride is built more original than mine and is very nicely done.  I think mine has a more "hot rod" feel to it for lack of a better description (just my opinion though).
K.
Offline 750K8 Kev
« Reply #15 on: July 13, 2010, 03:46:31 PM »
Did you raise the fork hight so the top bolts sit flush with the top of the triple tree or something? The fork top seems to be the main reason why the ms won't fit in there. I didn't want to start messing with my fork. Thanks for the pics, very nice bike.
« Last Edit: July 13, 2010, 04:01:36 PM by 750K8 Kev »
Offline 033A2
« Reply #16 on: July 13, 2010, 04:18:52 PM »
The top of the fork tubes are flush with the top of the clamp.  The fork nuts actually sit just above the clamp once screwed in. I'm running -2 fork tubes and -2 shocks to lower the bike, so everything fits pretty well.  I can take some closer pics if needed.  Just let me know.
K.
Offline 750K8 Kev
« Reply #17 on: July 13, 2010, 04:30:31 PM »
Some close pics would be great! So, does that mean you adjusted the forks then? pretty easy to do?
Offline 033A2
« Reply #18 on: July 14, 2010, 07:20:17 AM »
As requested, some close-up pics.  With the 2 inch shorter fork tubes, I was able to keep the top of the tubes level with the top of the clamp to get the lowered look I was after.  There is room to lower the front just a bit more by pushing the tubes up through the clamps if needed.  Hope these help.
K.
Offline 750K8 Kev
« Reply #19 on: July 14, 2010, 02:06:08 PM »
Thanks for taking the time to take and post the pics man! After checking out some lowering kits, getting some 32" bars made up at a local shop is more in my budget. If I had more money I would do it the way you did, I'm thinking a can get a bar made for less than $20.
Offline SKTP
« Reply #20 on: July 14, 2010, 02:07:35 PM »
I had to use bar risers to make drag bars work on my 78K
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline 750K8 Kev
« Reply #21 on: July 14, 2010, 03:05:27 PM »
 8) It's looks like I only need about an inch to clear the issue. thanks!
Found a 1" set for $76.95 in case anyone else has the same problem with their drags.
http://www.powersportsfx.com/sa/p/Universal_Risers_7_8_bar_style_handlebar_risers_-_1_up.htm
  • 74 CB 550 x2
« Reply #22 on: July 15, 2010, 12:19:07 PM »
I got my drags installed. I was prepared to use a riser but it was not necessary.
However, I have a home-made brake line setup so the banjo coming off the master makes an immediate 90 degree turn off the bolt. Clears everything just barely, but it works.
Offline 750K8 Kev
« Reply #23 on: July 19, 2010, 04:15:46 PM »
The 1" risers worked out perfect! and they really clean the look up too. The MC bolt sits against the right riser a little, but it fit's like a glove. I'm glad to hear you got yours figured out too.
« Reply #24 on: July 19, 2010, 05:57:01 PM »
Got a pic of the bars on the riser?
Sure.
Is it hard?
