Author Topic: what is the button for?  (Read 3773 times)
Offline tango911
Re: what is the button for?
« Reply #25 on: November 18, 2010, 07:37:38 PM »
Is it a cigarette lighter?   ???
Still looks like a cigarette lighter to me.  Did you try to pull it out and light your cigarette?
i pulled on it and it back fired   :o
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Offline fastbroshi
  • Puppet
« Reply #26 on: November 18, 2010, 08:47:27 PM »
Oh that.  That's your easy button.  I've ran across girls that had one, they usually don't last too long though.
Just call me Timmaaaaay!!!
« Reply #27 on: November 18, 2010, 09:22:57 PM »
Like i said thats where the ignition switch SHOULD be, the bracket by the clocks is an aftermarket part
Offline gregimotis
  • poet laureate; SOHC4.
« Reply #28 on: November 18, 2010, 09:28:52 PM »
That's the history eraser button, you fool!
http://www.youtube.com/watch?v=ku2wFaaPAzI
Maybe something good... Maybe something bad.  I guess we'll never know!  Because YOU'RE GOING TO GUARD IT!!!
(best episode in the history of episodes, ever)
« Last Edit: November 18, 2010, 09:31:06 PM by gregimotis »
Offline Goofaroo
  • general nuisance
« Reply #29 on: November 19, 2010, 07:36:43 AM »
Put some banana peels, beer cans, and assorted household refuse in the gas tank. Accelerate quickly to 88MPH then hit the button.  Bon Voyage!
1972 CB500 four
1972 CT90
1974 CT90
1978 BMW R100S
1983 CX500
1986 GL1200 Aspencade
1986 CH150 Elite Deluxe
1984 NH125 Aero
2005 Genuine Stella 2T
2007 KLR650
2002 KLR250
1985 XR350R plated
1994 DR350SE
2004 Concours ZG1000
1987 KDX200 C
1992 KDX200 E
2010 BMW F800GS
Always room for one more.
Offline camelman
  • Man... Myth... Legend
« Reply #30 on: November 19, 2010, 08:49:19 AM »
Doc: "Where we're going, we don't need roads."
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline mystic_1
  • 1970 CB750K
« Reply #31 on: November 19, 2010, 09:15:24 AM »
I'm reminded of the following story from the hacker Quux (Guy Steele):
A Story About ‘Magic'
Some years ago, I (GLS) was snooping around in the cabinets that housed the MIT AI Lab's PDP-10, and noticed a little switch glued to the frame of one cabinet. It was obviously a homebrew job, added by one of the lab's hardware hackers (no one knows who).
You don't touch an unknown switch on a computer without knowing what it does, because you might crash the computer. The switch was labeled in a most unhelpful way. It had two positions, and scrawled in pencil on the metal switch body were the words ‘magic' and ‘more magic'. The switch was in the ‘more magic' position.
I called another hacker over to look at it. He had never seen the switch before either. Closer examination revealed that the switch had only one wire running to it! The other end of the wire did disappear into the maze of wires inside the computer, but it's a basic fact of electricity that a switch can't do anything unless there are two wires connected to it. This switch had a wire connected on one side and no wire on its other side.
It was clear that this switch was someone's idea of a silly joke. Convinced by our reasoning that the switch was inoperative, we flipped it. The computer instantly crashed.
Imagine our utter astonishment. We wrote it off as coincidence, but nevertheless restored the switch to the ‘more magic’ position before reviving the computer.
A year later, I told this story to yet another hacker, David Moon as I recall. He clearly doubted my sanity, or suspected me of a supernatural belief in the power of this switch, or perhaps thought I was fooling him with a bogus saga. To prove it to him, I showed him the very switch, still glued to the cabinet frame with only one wire connected to it, still in the ‘more magic’ position. We scrutinized the switch and its lone connection, and found that the other end of the wire, though connected to the computer wiring, was connected to a ground pin. That clearly made the switch doubly useless: not only was it electrically nonoperative, but it was connected to a place that couldn't affect anything anyway. So we flipped the switch.
The computer promptly crashed.
This time we ran for Richard Greenblatt, a long-time MIT hacker, who was close at hand. He had never noticed the switch before, either. He inspected it, concluded it was useless, got some diagonal cutters and diked it out. We then revived the computer and it has run fine ever since.
We still don't know how the switch crashed the machine. There is a theory that some circuit near the ground pin was marginal, and flipping the switch changed the electrical capacitance enough to upset the circuit as millionth-of-a-second pulses went through it. But we'll never know for sure; all we can really say is that the switch was magic.
I still have that switch in my basement. Maybe I'm silly, but I usually keep it set on ‘more magic’.
1994: Another explanation of this story has since been offered. Note that the switch body was metal. Suppose that the non-connected side of the switch was connected to the switch body (usually the body is connected to a separate earth lug, but there are exceptions). The body is connected to the computer case, which is, presumably, grounded. Now the circuit ground within the machine isn't necessarily at the same potential as the case ground, so flipping the switch connected the circuit ground to the case ground, causing a voltage drop/jump which reset the machine. This was probably discovered by someone who found out the hard way that there was a potential difference between the two, and who then wired in the switch as a joke.
http://www.catb.org/jargon/html/magic-story.html
mystic_1
- John Augustus Shedd
Offline knowsnothing
« Reply #32 on: November 19, 2010, 11:17:54 AM »
Haha awesome story Mystic  :D
1978 CB750k Blue - for sale
Offline Goofaroo
  • general nuisance
« Reply #34 on: November 19, 2010, 06:26:35 PM »
I pulled on it and it back fired.
Same thing happens when someone pulls my finger.
1972 CB500 four
1972 CT90
1974 CT90
1978 BMW R100S
1983 CX500
1984 NH125 Aero
2007 KLR650
2002 KLR250
1985 XR350R plated
1994 DR350SE
1987 KDX200 C
1992 KDX200 E
2010 BMW F800GS
« Reply #35 on: November 19, 2010, 08:56:09 PM »
Offline Kframe
  • Life is good!
« Reply #36 on: November 19, 2010, 09:09:48 PM »
It's for the JATO rocket!
:D
-K
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
CB7fiddy
« Reply #37 on: November 20, 2010, 03:50:29 AM »
it's your power windows button :P
Offline tango911
« Reply #38 on: November 20, 2010, 05:59:26 AM »
lol
the guy used car speaker wire from the button to the hub.  awesome.
ill be tearing this thing down as soon as i re-organize the shop and make room to do it.  I bought a bunch of lil containers and ziplocks to store everything and label.  Will start a "restoration" thread soon.
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline tango911
« Reply #39 on: November 25, 2010, 09:49:27 AM »
update:
 i started a project thread,  and got the bike almost all the way torn down.  the button was what the PO was using as a starter button, but the hub was a huge mess with bare wires and all.  I was looking at the new wiring harnesses from one of the websites, but they say 73-76,   i thot 72 was the same through 76?   So i may be looking for a complete harness, but i might be able to salvage this one if i can figure it out. they did some nasty cutting and splicing.
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline strynboen
« Reply #40 on: November 25, 2010, 10:34:57 AM »
think it aktivate the "BLING",,,,and tank are full... of it 8) 8)
[attachment deleted by admin]
i hate all this v-w.... vords
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #41 on: November 25, 2010, 11:41:37 AM »
I wouldn't worry about the button. You got no front brake!!!
Maybe it's the release button for the drag chute.  ;D
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
