Author Topic: newbies cb550 streetfighterish build  (Read 34846 times)
Offline brandEn
Re: newbies cb550 streetfighterish build
« Reply #50 on: January 04, 2011, 05:59:51 PM »
Sorry about that, bad link.
Fixed it for ya!
Online Stev-o
« Reply #51 on: January 04, 2011, 06:00:56 PM »
Hey I almost ordered those grips but went with these instead
Nice!  soft?
Offline brandEn
« Reply #52 on: January 04, 2011, 06:03:06 PM »
I hope so! Just ordered them today. They are gel grips so they should be soft.
http://www.motogrip.net/Store/StoreHome.htm
Offline nickandkristy02
« Reply #53 on: January 04, 2011, 06:09:21 PM »
mine are gel and feel super great.
« Last Edit: January 04, 2011, 06:12:33 PM by nickandkristy02 »
« Reply #54 on: January 14, 2011, 07:40:29 AM »
yes or no on this seat or should i go with more of a hump?
Offline Syscrush
  • Sold. :(
« Reply #55 on: January 14, 2011, 07:52:50 AM »
I think that you need more of a hump to provide visual balance with the tank.
But it's your bike - what do you think?
« Reply #56 on: January 14, 2011, 09:53:58 AM »
like this? the red is the exhaust
Offline Syscrush
  • Sold. :(
« Reply #57 on: January 14, 2011, 10:33:35 AM »
That hump shape looks quite good to me.
Has anyone ever made a seat tail from the back end of a tank?  That could make for a very interesting look.
The exhaust is a question mark IMO.  I'm looking forward to seeing what you come up with.
« Reply #58 on: January 14, 2011, 04:13:24 PM »
this the one i made for my rd350 used a cb550 tank.lol
« Reply #59 on: January 15, 2011, 03:19:40 PM »
WELL I FINALLY GOT STARTED ON MY SEAT AND EXHAUST.MY BIKE IS AT MY DADS HOUSE BECAUSE IM PAINTING A BIKE FOR A FRIEND.IM MAKING YHE SEAT HUMP FROM THE TANK FROM THE SUZUKI DONOR BIKE.GOT THE EXHAUST MOCKED UP IN 1" PIPE TO TAKE TO THE MUFFLER SHOP TO GET SOME 2" PIPE BENT FOR IT.ONLY PROBLEM IS .............................................I FORGOT MY CAMERA :'( :'( :'( :'(.SO UNTIL TOMMOROW .LOL
« Reply #60 on: January 17, 2011, 04:00:18 PM »
finally took some pics ;D THIS IS NOT THE PIPE IM USING IM GETTIN SOME PIPE BENT AT THE MUFFLER SHOP SO IT WILL BE ONE SOLID PIPE!
notice how it flows with the frame lines
Offline Syscrush
  • Sold. :(
« Reply #61 on: January 17, 2011, 04:35:30 PM »
Lookin' good!
« Reply #62 on: January 17, 2011, 05:18:48 PM »
thanks ;D
Offline Roach
« Reply #63 on: January 17, 2011, 05:29:01 PM »
looking at your exhaust are you doing a 4-1 or 4-2? is it going to run under from the front over your oil pan? then up between your case and the swing arm?
1978 CB550K Cafe Racer
« Reply #64 on: January 17, 2011, 06:03:58 PM »
it is a 4 into 2 that will run along the bottom of the oil pan via 2 "Y" connecters.then up thru the swing arm
Offline Roach
« Reply #65 on: January 18, 2011, 10:15:13 AM »
the only thing i would check is your ground clearance between the 2" pipe running over the oil pan when you are on the bike might be low. but you seem pretty on it with this build so guessing you have already thought of that. ;D
« Reply #66 on: January 18, 2011, 10:32:09 AM »
the exhaust will go around the oil pan...sorry for the confusion ;D
« Reply #67 on: January 18, 2011, 10:34:17 AM »
went and had the pipes bent at the exhaust shop ;D its getting close!!!.... and yes i know my #$%* is dirty
Offline oldrider
« Reply #68 on: January 19, 2011, 09:38:37 AM »
I just wanted to ask what your planning to use to protect your body from the amount of heat directly under the seat. Exhasut wrap and some quality heat shield material attached to the seat pan might keep you from catching on fire. Also keep the heat in mine when selecting the location of your electronics.
Bikes I've owned
Honda 1969 CB350
Honda 1973 SL250
Yamaha 2004 V-star
Yamaha 2006 Roadstar
Honda 2005 ST1300
Honda 1975 CB550
« Reply #69 on: January 19, 2011, 10:08:08 AM »
i do plan on using some heat sheild material uner the seat and seat hump.as for the electronics ??? i will have to get creative.im gonna have to wrap the pipes i guess....thats gonna be expensive :'(
« Reply #70 on: January 19, 2011, 03:10:35 PM »
got a little work done on the exhaust today until my welder ran out of wire ::)
cut 2 v notches in each pipe,welded together,then put the collecter on then no more wire.lol
anyone see any un seen problem that i cant?
Offline fastbroshi
  • Puppet
« Reply #71 on: January 19, 2011, 04:13:16 PM »
Maybe drop the collectors down underneath the bike so it's not as visible?
Just call me Timmaaaaay!!!
« Reply #72 on: January 19, 2011, 04:24:33 PM »
Like i posted elsewhere, a few guys here have tried headers like that and they failed, not enough length in the primary pipes and this results in poor back pressure, you only ever see pipes like that on serious drag bikes and that is entirely different. Will pop and be a pain in the arse to tune...Don't know the exact specifics but NO one builds aftermarket pipes like that for a reason.....Just saying..
« Reply #73 on: January 19, 2011, 04:30:47 PM »
broshi i wanted to put them under but there wasnt enough room but the will be wrapped anyways dont think the will be to bad
« Reply #74 on: January 19, 2011, 04:37:24 PM »
mick there will be a complete exhaust for this bike
