Author Topic: spraying engine parts. what paint?  (Read 2826 times)
Offline sportsvan
  • birth, school, work, death
« on: January 15, 2011, 08:36:28 AM »
i have had my head, cylinder & rocker (valve cover) blasted.
i bought some simonize engine enamel silver spray which says it will stand up to 300 deg C heat when cured. (i will bake the engine parts in the oven when my wife is not around)
have already been in trouble as i primed the side panels & hung them on bungees to dry in the house overnight. i like the smell of fresh paint but she doesn't.
will this be ok for my cylinder temperatures???
78 750f supersport
78 xt 500
80 cb900fa
70 bsa royal star 500
2x 1970 mobylette 49cc mopeds
1972 mini clubman estate !
Offline Kong
Re: spraying engine parts. what paint?
« Reply #1 on: January 15, 2011, 08:51:16 AM »
Deleted by author
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline going4speed
« Reply #2 on: January 15, 2011, 08:59:04 AM »
those chemicals will stay in your oven.  They are carcinogenic.
Offline fmctm1sw
« Reply #3 on: January 15, 2011, 09:26:22 AM »
A lot of guys here use VHT aluminum paint.  POR-15 also makes a engine paints.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Kong
« Reply #4 on: January 15, 2011, 09:36:11 AM »
Duplicolor's engine paints, which they say are good to 500 F. do not require a heat cure according to their directions.
1978 Honda CB550K
1977 Honda CB550K
Offline sportsvan
« Reply #5 on: January 15, 2011, 12:16:03 PM »
what type of temperature will my engine get up to ?   ???
78 750f supersport
78 xt 500
80 cb900fa
Offline gerryw
« Reply #6 on: January 15, 2011, 01:07:07 PM »
used duplicolor sprayed in garage, then in house oven to bake, smell wasn't too bad at all, then when done, put oven onto self clean cycle which turns oven dirt to grey ash, that should take care of chemicals
gerry
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
« Reply #7 on: January 15, 2011, 01:53:11 PM »
You might think about getting them powdercoated instead of paint. Far more durable and will tolerate any temperature your engine will reach . . . unless (maybe) it's about to overheat and seize,at which point whatever you've chosen is the least of your problems.
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
Offline sportsvan
« Reply #8 on: January 15, 2011, 04:18:41 PM »
is there a silver powder-coat match ?
78 750f supersport
78 xt 500
80 cb900fa
Offline going4speed
« Reply #9 on: January 15, 2011, 10:40:50 PM »
Talk with the local powder jockey and ask him to show you the color pallets.  They should have a fantastic match for your requirements.
Offline swellguy
« Reply #10 on: January 16, 2011, 01:19:18 AM »
Yes, I did the frame of my Knucklehead in silver powdercoat, looks great, tough as nails:
Close up:
Offline xedge4lifex
  • Trillz McGillz
« Reply #11 on: January 16, 2011, 01:58:21 AM »
please dont put anything in your home oven. I went garage sale surfing and got myself a toaster oven for 5 bucks, cut the sides off and bolted some taller sheet metal on. worked great for baking small parts. but if your painting an engine parts they will dry over time with the bike running. however they will never "cure" even after baking as 2 part paint does.
post some pics when your done
Wake up, look up, there's a warmth up there
a reminder of peace, a reason to care.
