Author Topic: New Project - 1975 CB400F  (Read 11564 times)
Offline DarcyCB400F
Re: New Project - 1975 CB400F
« Reply #25 on: April 13, 2011, 03:52:53 PM »
Those bars don't look stock for a 75-76. Originals look more like what are commonly referred to as "superbike bars".
They are stock... the 75/76 had lower bars and the foot controls were set back slightly. The '77 had a more upright seating position.
The blade fuse option isn't neccesary unless your melts down. This can easily be prevented by a good cleaning.
Nice find! Care to share the $$??
1977 CJ360T
1977 CB400F
1980 CB900 Custom
1981 GS550L
1989 DR200R
1998 VT1100C2 ACE
1999 XR400R
2006 CR230F
2007 HD Road King
Offline SanDogDewey
« Reply #26 on: April 15, 2011, 08:26:27 PM »
New bars came in today. Mocked them up to see how they look. Much better than what was on there. I think the PO put the '77 bars on, because of the fairing he had installed.
Cleaned up the gauges and installed new meter cushions.
Finished rebuilding the master cylinder and cleaning it up as well.
The PO had installed a set of dual horns. Apparently they were drawing too many amps.
Offline SanDogDewey
« Reply #27 on: April 17, 2011, 07:28:34 AM »
Got the triple clamps cleaned up and painted for the All Balls tapered bearing conversion.
A littel aircraft stripper does wonders.
Offline SanDogDewey
« Reply #28 on: April 17, 2011, 07:53:10 AM »
New bars and refurbished triple clamps.
Offline zachz
« Reply #29 on: April 17, 2011, 09:16:20 AM »
Looking very good.  I need to lay my hands on some of that aircraft stripper...
Offline kap384@telus.net
« Reply #30 on: April 18, 2011, 09:43:13 AM »
Lookin good.  Always a great feeling bolting on those refinished parts.
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
Offline vames
« Reply #31 on: April 18, 2011, 01:02:58 PM »
SanDog: Can you tell me which spacer(s) you used for the All Balls kit? It'll save me some trial and error. Thanks.
Offline sopo400f
« Reply #32 on: April 18, 2011, 02:54:53 PM »
Sandog,
I also have double horns on my 400f. On mine they are wired right to the positive side of starter solnoid.
Dan
1975 cb400f blue
Offline SanDogDewey
« Reply #33 on: April 18, 2011, 03:56:47 PM »
I used the small spacer supplied with the kit. Everything seemed to bolt up correctly. I torqued to 22-28 ft lbs, swiveled the head, loosened and retorqued to 6-9 ft lbs.
Offline SanDogDewey
« Reply #34 on: April 18, 2011, 03:58:27 PM »
Sandog,
Dan
If you are using a relay, I can see where that would work well. However, if you are running that many amps through the original wiring and switch (as my PO did), you could have a problem.
Offline sopo400f
« Reply #35 on: April 18, 2011, 06:00:51 PM »
Thankfully the po did install a relay. So far its the only electrical thing that works on the bike.
1975 cb400f blue
Offline SanDogDewey
« Reply #36 on: April 20, 2011, 05:55:21 PM »
Got the gauges, mirrors and forks back where they belong. As soon as I get a new bearing retainer for the front wheel, she'll be rolling again. I still have to pull the rear apart to replace the bearings though.
« Reply #37 on: April 20, 2011, 09:33:26 PM »
Looks awesome!
1965 Honda CB450K0
1972 Honda CT70K1
1978 Honda XL100
1983 Honda CX650T
1995 Honda VFR750
2015 KTM 200 XC-W
1963 Suzuki T10
Offline johnsy
    • what I do!
« Reply #38 on: April 20, 2011, 10:14:14 PM »
holy damn progress! looks good.
current project, cb550 four
75 360T
Offline -CB-Jamie-
« Reply #39 on: April 21, 2011, 12:05:37 AM »
Very nice SanDog
72 CB350/4
76 CB400/4 CB400f "Project Resurrection"
77 CB550/4 1977 CB550 Yet Another Cafe
77 cb200
09 cbf600
« Reply #40 on: April 21, 2011, 12:17:49 AM »
you didnt even have to take the engine apart,cool.
Offline Marco83
    • *My PhoTo AlbUm*
« Reply #41 on: April 21, 2011, 12:34:37 AM »
Nice project!
Offline SanDogDewey
« Reply #42 on: April 21, 2011, 09:39:10 AM »
With 8500 original miles she's was in pretty good shape. The PO did a good job of keeping it serviced. The oil is even still clean and looks like it was serviced yesterday even though it hadn't run in 10 years. I pulled the carbs, cleaned them and installed all new gaskets. I also adjusted the cam chain. Will take a look at the valves once everything is back together. She a smooth runner! Still a little corrosion to clean up on the engine nuts and bolts.
Offline BenFrank
« Reply #43 on: April 25, 2011, 06:58:32 AM »
Beautiful bike!
I have a 76 Cb400F that I'm breathing new life into...
I didn't know you could just "hose down" a bike like that!
Here I was with a tooth brush and a can of engine brite!
Offline SanDogDewey
« Reply #44 on: May 09, 2011, 05:05:48 PM »
Got it out for a ride this weekend. My daughter was re-learning how to ride a bike with a clutch again. Ended up killing the battery with all the re-starts. Recharged the battery and dug into the rear wheel to replace the bearings and clean up the swing arm. Waiting on a new bearing retainer as the old one was destroyed in the removal process. I made a removal tool, but it was still a bear to get out. I ordered the a real tool from Motion Pro.
Offline SanDogDewey
« Reply #45 on: May 09, 2011, 05:09:09 PM »
I also installed a dyna ignition last week. What a difference that makes! Beats the heck out of trying to adjust the two sets of points. Bike runs so much smoother. I've got the coils too, but am waiting on the plug wires to install.
Offline SanDogDewey
« Reply #46 on: May 09, 2011, 09:30:32 PM »
Got the coils wires in tonight and wired up the Dynas.
Soldered the terminal ends for the coils
Heat shrink on the terminal ends
I soldered the leads from the coils into the existing harness.
« Last Edit: May 09, 2011, 09:34:09 PM by SanDogDewey »
Offline SanDogDewey
« Reply #47 on: May 12, 2011, 07:34:50 PM »
Drove the bike to work today for the first time. Not a bad ride if you keep her up around 7k rpms. This bike is for my daughter and we're going on our first group ride this Sunday.
Before
After
Major fixes
- Cleaned and synch'd carbs
- Dyna Ignition and coils
- Replaced front and rear wheel bearings
- Replaced steering bearings
- New chain and sprockets
- New tires (still need to be mounted)
- Rebuilt master cylinder and caliper (converted to DOT 5)
gsnorcal
« Reply #48 on: May 12, 2011, 07:37:57 PM »
Looks great!
Offline SanDogDewey
« Reply #49 on: May 12, 2011, 07:49:34 PM »
Looks great!
Thanks! Here's our two Super Sports.
« Last Edit: May 12, 2011, 07:55:32 PM by SanDogDewey »
