Author Topic: Air filter choices  (Read 1889 times)
Offline bmxjrod
    • JRoD's PhotoShop
Air filter choices
« on: April 25, 2011, 06:39:29 AM »
Has anyone tried the cheaper Emgo pod filters? Are they worth the savings over the k&n filters?
CB750 K6
Offline bmxjrod
    • JRoD's PhotoShop
Re: Air filter choices
« Reply #1 on: April 25, 2011, 06:42:18 AM »
Forgot to mention, its on a 76 750k...
CB750 K6
Offline Doctor_D
« Reply #2 on: April 25, 2011, 07:46:17 AM »
Try the search function as there have been numerous, lengthy "pod" discussions in the general sohc bikes forum.
(And Emgo's are cheap Chinese garbage that are worse than a stock airbox in many ways.)
Take care,
David
1978 CX500
1971 Norton Commando
Offline bmxjrod
    • JRoD's PhotoShop
« Reply #3 on: April 25, 2011, 08:33:15 AM »
Thanks for the heads up!
CB750 K6
« Reply #4 on: April 25, 2011, 12:37:18 PM »
DOH!!! :o
i'll take mine with extra butter please!  ;D
« Reply #5 on: April 25, 2011, 02:46:21 PM »
I had excellent result using the emgo pods on a cb360, can't get kn's to work worth a nickle on a cb750
Offline anthony
  • ebay and i have a love hate relationship
« Reply #6 on: April 25, 2011, 02:57:50 PM »
i have the emgo pods on my 550. they stop large bugs and small birds. i have had them for 1 year and they are falling apart. if you are sold on pods spend the extra on k&n's.
« Reply #7 on: April 25, 2011, 03:17:03 PM »
OK.I'll be the first. Try the stock replacement K&N filter for the stock air box or are you doing some type of a cafe etc.
Offline nayto550
« Reply #8 on: April 25, 2011, 04:08:07 PM »
On my 550, I used the stock airbox because it was specifically designed for that engine, I imagine the same is true for the 750.  I couldn't afford the K&N replacement at the time, so I took my OEM filter, cut out the paper element, hot glued in a chunk UNI filter foam and it works like a charm!
1976 CB550F
1976 CB750F - in resurrection process
1988 HD FLHS
« Reply #9 on: April 25, 2011, 04:36:45 PM »
Are you experienced tuning carbs.? if not, stick with the stock airbox. Your bike will be a lot easier to tune and stay tuned with the stock airbox. Pods are for looks and airbox is for good reliable running......
Offline Doctor_D
« Reply #10 on: April 26, 2011, 06:39:03 AM »
+1
At least K+N tried to mold velocity stacks into the inside of their pods, but using them does change the length of the tuned intake runners.  Over the years I've built certain bikes where this wasn't an issue and others where it caused mysterious flat-spots and made jetting and tuning the carbs difficult.
Take care,
David
1978 CX500
Offline bmxjrod
    • JRoD's PhotoShop
« Reply #11 on: April 26, 2011, 09:29:29 AM »
Im sold on the stock airbox. I wanna ride this thing when I get it done, not work on it more.
CB750 K6
