Author Topic: 1971 CB500 Four - remove head & cylinders without taking engine out of frame?  (Read 3039 times)
Scarab
Does anyone know if it's possible to remove the head and cylinders on a 1971 CB500 Four without first taking the engine out of the frame?
Thanks in advance.
I highly doubt you can get the cylinders off
Offline mjstone
  • I'm definitly not a
You can probably get the head off, but the cylinders have to be lifted clear of the studs that run threw from the case  to the heads.  So no, you will have to remove the engine to get the cylinders off.
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Offline That 70s Bike
  • Honey I'm not obsessed, see... I'm just an
  • SEE YOUR AD HERE!
 ??? My '76 CB550 is sitting right now with the head & cyl's off, motor still in frame. '71 CB500 is very similiar bike.
I did read the CB750 motor must be pulled to do same.
« Last Edit: May 04, 2011, 08:52:48 PM by That 70s Bike »
CB750K6- survivor   CB500K2, CB550K2- projects
All Standard Honda 500/550/650 can be stripped to base gasket level with engine in the frame.
WARNING
read the manual CAREFULLY about re-installing the cam cover
ive done it.
