Author Topic: **Updated 5/20/13** In over MY head 1975 cb550 cafe. thanks...Dave500, Twotired  (Read 112952 times)
youll have to wear sunglasses at night now with those guages lit up!i want you to get a a pair of those big green hulk fists and make gloves out of them for riding,wont be long now xman and youll be out there.
Offline xsmooth69x
i have more pics on my digi cam but whats left
finish the electrical. at the moment im having a problem with my headlight...... im in summer school now so i only have the weekend to work on it. so when i get back home i have to completely go through and trace all the wiring. i have an H4 conversion headlight with an HID kit with a 7" halo ring in the headlight. like the angle eyes on BMW but not a CCFL. its a plexi glass ring with super bright blue LED in the ends. it lights up pretty nice.
H4 with halo $12.99 + $19.99 shipping
HID kit $37.49 + $11.49
they are for cars and this is a stock photo of a jeep with the headlights on at night
what i have done with the wiring is (will update with real photos these are all stock photos)
LED bullet tail lights 19.99+2.77 ship
licence plate LED $6.49 free ship
also motorcycle licence plate bracket $20+$10 #$%*
the tach gauge $10
aftermarket mini speedo with my custom blue single LED i soldered in there $48
it has a 48mm face so its pretty small
my 139db stebel electro pneumatic air horn with wire harness package $58.61
ow ya this biatch is super loud
wrap exhaust
finish re upholstering my seat ( i will have a detailed post on this)
checking over the bike tightening things
« Last Edit: May 24, 2012, 07:26:50 PM by xsmooth69x »
1975 CB550 (FINISHED?!?!?)
Offline xsmooth69x
ow i got sweet gear
suomy vandal la cocca helmet $430+$60 iridium visor
full face just like everyone on the forums said to get instead of open face helmet  :)
gotta keep the vintage look so i got pin up girls on the helmet hahaha and its a sweet print to its done by giovanna casotto hes an international erotic comic artist and the lady was a real model
river road hoodlum thick leather jacket $200
and here you go dave500 not really the hulk gloves but there icon overlord gloves $125
these bad boys will protect my very important hands!!
its made with battlehide goatskin with kangaroo palms all with aramid stiching
knuckle armor and wrist plate
Offline LesterPiglet
  • 1977 CB550F2
I like the lady art.   :P
Offline Tews19
  • I am no
since i havent updated by build thread in forever because of school and now in the summer im in over drive trying to finish my bike so i can ride ride ride !!!
since i have these pics on hand i thought id share!
just my quick tach resto
cost-
2 X 24cm Car Blue 24-LED Neon Flexible PVC Strip Light $4.99 free ship
misc solder, paint $5
to take off the outside ring i decided to make a very very small slit (then like ive heard you can drop a bead of solder to later re connect the ring on the bottom out of sight) well later when i got to the point to solder the ring back on.... well that was horrible!!! i do not recommend it at all. for one the solder did not want to stick to the ring at all!!! but if you do decide to do the solder you must sand the ring in the section where you are going to solder. then instead of heating the solder and dropping a bead use the highest temperature setting on ur soldering iron and heat the ring up then drop the solder. this took forever and multiple attempts i used a shiat tone of solder because the bead kept on rolling off. i eventually got it
i did the usual painted my tach needle and cleaned up the gauge face
went through the tach mechanics clean and re lubed it
i also painted the inside of the gauge white so the light will pop more (when reassembling the gauge i had to sand down all the ring edges because apparently
 its such a tight squeeze the dismal amount of paint i used to spray the gauge it actually made them stack a little higher and couldnt fit the outer ring i cut earlier back on)
then i decided to take out the stock bulbs and replacing them with LED string things
check it out
i used 2 string LED strips and they both fit in pretty nice
*** this is just a google image but this is what i used but in blue
i used the stock wire harness for the original light bulbs and cut off the light bulbs and soldered the LEDs on. i also used the stock water proof grommet things
heres some pics lite up
heres everything re assembled
beautiful!
LOOKS GREAT!
How many did you use per gauge? 2 or did you order two total as in one per gauge?  I am going to order those and copy ya if you don't mind.
1970 Honda CB750 survivor.
Offline xsmooth69x
when u order them off flea bay they come in pairs.
i put 2 strips per gauge.
this is what the inside of the gauge looks like.
the circles on the top and bottom are the stock holes where the light bulbs fit in.
now the gap between the tach gear cage and the stock light bulb holes to snake them around like a W
i made sure to put the led strip in a W shape (green strip)(bottom) then the second strip as an "upside down W" (blue strip)(on top of the green) the reason i did this was because if you do it in the reverse order u will have a noticeable gap in the light between 5-7000 rpm. making sure that the last strip to be put in is and upside down W shape (blue strip) obviously you want your whole RPM range to be consistent and the bottom of the gauge u wont notice any inconsistency. im not making this up because i did it in the opposite way and you could total tell.
you can feed the wires out of gauge which ever way u want.
when testing them out for fun u can use just a 9v battery to turn the LED on and off. the battery u put ur tongue on and it shocks u.
« Last Edit: May 24, 2012, 07:12:47 PM by xsmooth69x »
Offline Tews19
  • I am no
Awesome. Thanks... I just placed my order
« Last Edit: May 24, 2012, 06:04:01 PM by Tews19 »
Offline xsmooth69x
also here is a gauge another member did
http://forums.sohc4.net/index.php?topic=67321.0
i first did it this way and used a LED ring but i did not like how it turned out
as u can see the picture above the ring of light is just simply a ring and you can see the individual square LED. it just wasnt my look and installing them was way way way more of a pain in the ass.
this member actually took out some of the LED to separate the ring in the tach.
also on a side note i only did the tach. i have no idea what the inside of the speedo looks like. i would image the case is exactly the same and nothing will get in the way.
Offline xsmooth69x
ow ya!! thanks!
Offline xsmooth69x
messed up on my paint photo and partially revised the write up
"its made with battlehide goatskin with kangaroo palms"
kangaroo palms eh?nice and soft,i wonder what else youll get up to with those?
those stebel air horns have a good rep but need to be operated once in a while also or they lock up.
« Last Edit: May 24, 2012, 11:32:24 PM by dave500 »
Offline xsmooth69x
ow really they lock up? ill make sure to take it off the bike and put it in my house during winter. the horn does have a temperature range of operation cant be to cold or to hot apparently. im also modding the horn too since its so big i cant really fit it anywhere. im going to disconnect the horn and the electric air compressor and put a 1/4 tap on it and run a air line so i can put the horn anywhere. its so dumb to because the electric compressor thing has to be perfectly vertical.
i just run dual auto type wind tone horns,hi/lo note,loud and harmonious.
Offline xsmooth69x
very nice. mine are 2 tone too its pretty awesome!
Offline xsmooth69x
just some night photos of the bike with all my LED and HID kit on the bike
Offline xsmooth69x
also apparently you need blinkers on motorcycles so ill have to figure out how to incorporate that into my bike now.....
Offline Mcwilliams570
Looks good nice and bright. Had a flash back of Clark Griswold turning on the xmas lights outside in the movie christmas vacation.....:)
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline Tews19
  • I am no
I got my turn signals from lockhart philips. only 19 bucks each. dual filament for running lights single for non running lights. One of each. What does your seat look like? You can mount them into the frame hole that is stock on the rear. Front, you can hook up on the bucket.
maduncle
Excellent stuff - where did you get the H4 Halo and HID kit?
Offline xsmooth69x
well the H4 halo i got on ebay for $12 and $20 shipped go figure right
it was called "65-78 FORD MUSTANG 7" HALO DIAMOND HEADLIGHT H4 66 67"
the seller was "acekogyo"
but i checked on ebay again and i could not find anything. there was a couple halo ones but they where all projector style. so idk maybe they stopped selling them period but at the time there was multiple sellers selling the item.
the hid kit is just some generic H4 motorcycle HID kit. they are ridiculously cheap on ebay. i mean they are so cheap to where if the bulb burns out just buy another kit since the HID bulbs themselves are practically the same price.
Offline xsmooth69x
frame holes in the back are used for my tail lights.
im going to run no blinkers for a bit and see if i get pulled over.
worst comes to worst i will probably get an LED strip under my seat that blinks left or right. then take some led strips and wrap them around my front forks above my bottom triple tree and use those for my front blinkers or get some bar end blinkers. but i also have bar end mirrors and i dont want my bars to get super long and cluttered so i will have to look into it.
my seat is still in progress. i will have a write up and all that jazz when it is finished and when i have enough pictures. this fri i will be finished. at the moment i have all the raised diamond stitching and now i will be up holstering after cutting down the foam.
im making sure to keep it a 2 seater for the ladies  8)
Offline xsmooth69x
so i will have 2 separate LED strips that are yellow mounded under my seat pan. so when i open up the seat to use the helmet strap holder they LED strips will move with the seat.
the led strips can be cut down to fit so it should be easy. with a solid state flasher and since these are just LED it would be an easy mod
Offline xsmooth69x
Matt
hahaha nice! ya they are super bright and they look uber cool.
although the ring and little bulb will serve as my day time running lights which in the sunlight are kinda faint but there.
and when u turn the HID lights on it deff washes out the halo ring. so mostly its just for show when the bike is parked at night.
Offline jneuf
As someone who had non functioning signal lights for a little while, I wouldn't leave them as an after thought.
I already feel like drivers out there are waiting to hit me, don't make it easier for them by not having signal lights!
'75 CB400f
Offline xsmooth69x
ya thats a very valid point ill just order the led strips
