Author Topic: CB550 Salt Flat Racer!  (Read 17942 times)
Offline B.O.X.N.I.F.E.
  • The Stumped
Re: CB550 Salt Flat Racer!
« Reply #50 on: October 30, 2011, 09:14:56 PM »
Did you measure both wheels ?
I just now saw your response to this, sorry for the delay.
Yes, other than the wheel diameter I found no other differences in measurements between the two wheels(which I'll repost below). Given the opportunity to start from scratch I'm thinking I would like to run 520 sprockets. Would make o-ring chains possible I think.
Hub: 86mm
Hub to rim side a: 7.5mm
Hub to rim side b: 9mm (hub center beveled around thru hole on this side) Confirms 1.5 mm offset?
Thru hole: 2.34 inches (my caliper only goes 2 decimal places)
1974 CB550
Forever West
Offline Old Scrambler
« Reply #51 on: November 04, 2011, 12:51:14 PM »
Boxknife............when you are running for speed you want the least amount of drag on all components..........a clean chain (no o-rings) will count for extra speed..............just remember to clean and oil it before you leave the salt-flats.
You may be interested in the Texas Mile and the new Ohio Mile (replaces Maxton) events. They are on asphalt and offer great opportunities to test your machine before you go to the salt-flats. Check them out on the landracing.com site.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
