Author Topic: what is a good carb sync?  (Read 9943 times)
Offline xsmooth69x
« on: May 24, 2011, 01:31:23 AM »
there are 3 styles out there
vacuum - emgo makes them
liquid kind - pro motion
metal rods - morgan carbtune
is there any pro and cons of these? or is it just personal preference?
1975 CB550 (FINISHED?!?!?)
Re: what is a good carb sync?
« Reply #1 on: May 24, 2011, 01:58:44 AM »
personal preference.
  • I'm back
« Reply #2 on: May 24, 2011, 03:48:58 AM »
I share a set of 4 clocks with another friend/motorists. Unless you have more bikes, cost of buying is hardly justified. That's why we shared and soon an owner of 2 350's will use them too. My experience is: once set you don't have to sync for a long time, very long indeed. As a matter of fact when you think they're out of sync, I would advise you to look for another cause. In my experience the carbs stay synced almost forever. Honda did a good job on this, after learning lessons with the 4-cable operated carbs on the early 750 models. Last time I used the set is some 15 years ago. On a few occasions I had the carbs on the kitchen tabel (for experiments with the needles) and decided to see how accurate I could sync by hand, using a small allen key for testsliding under the little cutaway section in the front side of the slides. I adjusted, testslided, adjusted, testslided etc. Then I drank a cup of coffee and repeated it, eyes closed for maximum touch. After mounting the carbs on the bike and attaching the set I was surprised I had managed to sync within 2 cm Hg(!), well within factory specs.
Maybe - just for fun - I will build a DIY as described elsewhere, because I like the idea so much (simple fysics). Gives me also the possibility to check if the 4 clocks are still within calibration after all the hefty movements. The homemade set can never lie. No negatives: you need no figures, just visual information that fluid is at the same level. For the rest of you: share. Less is more.
« Last Edit: May 24, 2011, 03:53:57 AM by Deltarider »
Offline xsmooth69x
« Reply #3 on: May 24, 2011, 11:34:13 AM »
I've used the Emgo, it works fine but the tool needs to be checked and possibly calibrated before use, Very easy to do using the same engine cylinder and the chrome colored adjuster screw on the gauge front. A good check is to swap vacuum lines after the tuning of the carbs to see if there are indicated differences, verifying the gauges once again. The gauges can lay flat and need not rely on gravity and position like other types plus they are cheap to buy. They also don't have liquid to worry about leaking or being positioned inproperly during storage. After the simple gauge matching I checked each with a digital manometer designed for boilers and found the analog units to read the same to one another. +1 for personal preference
^ that is a brilliant idea about tuning the clocks with 1 cylinder.... that was my biggest con when reading about these syncs that the gauge style needs to be syncs for the syncs to sync the carburetors lol
Offline xsmooth69x
« Reply #4 on: May 24, 2011, 11:36:49 AM »
well i rebuilt my carbs and took everything apart..... never tuned carbs before so i dont think im pro enough to do it by my senses. i also haven't gotten the bike started etc etc
Offline Really?
« Reply #5 on: May 24, 2011, 11:41:05 AM »
Motion Pro is a POS.  I had to fix it after the first use and still don't trust it.  I have used the liquid Morgan and was happy with that but I borrowed it so I do not own one.  I have the vacuum gauges and like them a lot.  Easy to deal with and maintain.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline xsmooth69x
« Reply #6 on: May 24, 2011, 11:44:17 AM »
perfect ya i think im going with the emgo vacuum gauges  :)
« Reply #7 on: May 24, 2011, 11:59:22 AM »
i got a set that look identical to the emgos, for 1/2 the price.   8)
calibrated them to my #1 cyl, and they have been great since.
i'll find the link for you...
edit...
$56   Barracuda Carb Gauges
on Ebay
Saber Cycle is the seller
« Last Edit: May 24, 2011, 12:05:50 PM by flybox1 »
Offline MoMo
  • Ride like you're invisible
« Reply #8 on: May 24, 2011, 12:09:35 PM »
My  personal preference is the Morgan Carbtune. I've had vacuum and mercury styles...Larry
Offline Really?
« Reply #9 on: May 24, 2011, 12:15:21 PM »
The only good thing that came out of the Motion pro setup was the plastic T thing.  You can sync all the guages at once.
I do not know where you can find one like that but I would think it to be possible.
« Reply #10 on: May 24, 2011, 12:22:40 PM »
now THAT would be handy little piece.
...time to search the big-box stores  :D
Offline xsmooth69x
« Reply #11 on: May 24, 2011, 12:29:20 PM »
wow a moon tube  :o that is crazy!! im going to try and find on of those tooooooo. if anyone can find that please post
bollingball
« Reply #12 on: May 24, 2011, 12:57:55 PM »
Should be able to make one look at the aquarium stuff at wallMart.
Offline jneuf
« Reply #13 on: May 24, 2011, 01:04:53 PM »
I have a morgan. Syncing my carbs was pretty simple.
'75 CB400f
Offline rbmgf7
  • 2>4
« Reply #14 on: May 24, 2011, 01:09:00 PM »
I have the Promotion. Used it many times without a problem.
Offline xsmooth69x
« Reply #15 on: May 25, 2011, 03:47:56 PM »
edit...
on Ebay
could you find that link lol. i went to there website and its $89 and nothing on ebay.....
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
« Reply #16 on: May 25, 2011, 05:43:12 PM »
I'm using the Morgan Carbtune and love it. While I agree with previous comments that the Honda carbs shouldn't go much out of synch,...I have "retuned" my carbs 3-4 times in a year. I don't see it is feasible to own a 35-40 year old bike and just ride it between scheduled maintenanc intervals. For most of us, I'm picking,...we are forever tearing into something in order to get to something else to fix something we forgot about in the process. Every tinker with a carb, the timing, the points, fuel lines etc....I follow with a re-synch. I regard this tool as esssential to every tinkering owner.
« Reply #17 on: May 25, 2011, 06:05:32 PM »
Quote from: xsmooth69x link=topic=89623.msg1005348#msg1005348
[/quote
http://cgi.ebay.com/ebaymotors/Carb-Synchronizer-Vacuum-Gauge-Sync-5-6mm-YAMAHA-DEAL-/380330232458
Offline CB500_k2
  • Wrenching makes a good retirement.
« Reply #18 on: May 25, 2011, 06:32:09 PM »
I like the mercury filled MotionPro units.  The density of the mercury damps vibration quite well.  You just have to get the condensate above the mercury out or it polymerizes.  I am not sure what the reaction is but the residue is solid after a year of no use.  Share with a friend to avoid problems.
Too many bikes -- too little time
1973 CB500
1974 CB350 - sold
1975 CB400F SuperSport
2000 Ducati Monster Dark
Offline splitt
« Reply #19 on: May 25, 2011, 07:18:04 PM »
I've got a set of Honda gauges & a Motion Pro mercury stick. The Honda gauges are the worst set that I have ever seen. The needles bounce so bad that they're impossible to read.
I've been using the Motion Pro gauge for close to 18 years now and I believe that they are the most accurate. If you do go with mercury sticks, handle them safely, and be aware of the dangers of mercury. Riding motorcycles can be dangerous enough, we don't want to reduce our ranks any further by poisoning ourselves.
Offline Spanner 1
« Reply #20 on: May 25, 2011, 07:38:49 PM »
Disagree with Deltarider.... the fact that he came close with a mechanical sync. is just lucky. Now do some other work on your bike , like valve lash or float level or timing , all would effect individual cylinder vacuum IMO and cause the vac. pressures to change relative to each other requiring a re-sync.
Offline xsmooth69x
« Reply #21 on: May 25, 2011, 11:03:37 PM »
^ ill take that luck
« Reply #22 on: May 25, 2011, 11:09:24 PM »
analouge dial guages must have a damper or they will go haywire.
  • I'm back
« Reply #23 on: May 25, 2011, 11:28:33 PM »
Then I've been lucky three times...  BTW, am I the only one in this forum that has managed?
Not necessarily right. If the carbs were right from the factory and have stayed right ALL changes in vacuum result from other things like changes in valve lash or timing, all indeed effecting individual cylinder vacuum. That has always been my point. Given the carbs were right from the factory and have stayed right (and they do!) you can achieve the right sync by adressing the other points of maintenance. That's my point. Except when there's someting wrong mechanically (worn rings and/or pistons, damaged valves etc). Compression or leakdowntest will tell you. Trying to cure those problems by syncing will not work.
