Author Topic: YET ANOTHER CALIPER QUESTION....  (Read 999 times)
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« on: May 05, 2006, 06:34:49 AM »
when doing the dual disk setup, the speedo drive side caliper has to mirror its normal orientation, and thus, the bleeder and feed are backwards. Will the flair seat inside the feed port just pop out of the caliper?  is this all that is necessary to reverse the feed and bleed??
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Offline dusterdude
Re: YET ANOTHER CALIPER QUESTION....
« Reply #1 on: May 05, 2006, 07:09:56 AM »
on some calipers you can use a sheet metal screw to remove the seat.not sure if it will work on ours tho.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #2 on: May 05, 2006, 08:55:19 AM »
I had the same issue with my setup, still do actually.The bleeders are in different spots, which is not a big deal to me..
I was gonna go thru swapping everything so the bleeders were in the same spot, but I dont think it's worth the trouble at the momment, knowing what I have gone thru thus far trying to get this damn bike rideable .. ::)
