Author Topic: Chrome seat trim  (Read 14236 times)
Offline Scott S
Chrome seat trim
« on: August 22, 2011, 10:58:06 AM »
 I have a seat from a '75 550 and it appears to have been recovered. It's very nice and whoever did it did a fine job.
 However, it looks like they re-used the chrome trim strip. It's showing it's age. It's cracking and faded and sorta stands out against the new seat. Where can I find a replacement strip?
 Thinking about hitting up an upholstery shop down the road from me when I get the bike on the road and see what they have, but until then, any ideas?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Gordon
  • 750K1, 550K2
Re: Chrome seat trim
« Reply #1 on: August 22, 2011, 11:04:12 AM »
AFAIK, the chrome strip on the 550 seat is part of the seat cover, as in it can't really be replaced separately.  I'm sure it's possible with a certain amount of work, but as it is it's permanently part of the cover and is what holds the cover onto the seat pan.
Offline Scott S
« Reply #2 on: August 22, 2011, 11:16:52 AM »
 I just checked and the strip is definitely a seperate piece on my seat. I suspect that whoever did the cover cut the strip from the old seat?
 It slides over the lip of the seat on the outside and is held in by the stock clips underneath.
'71 CB500 K0
'81 Yamaha XS650
Offline JustinLonghorn
« Reply #3 on: August 22, 2011, 11:19:46 AM »
If it indeed just slides over the lip, you can buy replacement chrome trim at any Auto Parts place.
"So you had better do as you are told
You better listen to the radio"
My Super Sport Build
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: August 22, 2011, 12:37:25 PM »
Can you pull it away from the seat cover on the outside edge?
Offline Scott S
« Reply #5 on: August 22, 2011, 12:53:36 PM »
 Yes. The chrome is attached to a rubber/vinyl looking strip. Upon closer examination, I think maybe it's the original strip that was cut from the old seat and then slipped over the edge of the new seat cover.
'71 CB500 K0
'81 Yamaha XS650
KingCustomCycles.com
« Reply #6 on: August 22, 2011, 01:07:37 PM »
All the seats I have done had the chrome piece as a separate, slip-on, part after the vinyl was stretched and secured.  Imagine, if you will, trying to get that strip on that edge perfectly everytime during manufacture with it attached to the vinyl.  Any imperfections or variations in the vinyl installation could not be corrected if that was attached prior to finishing the installation. I am not saying it wasn't glued on at the factory, in combination with the clips, but it had to be added after the vinyl.  In answer to your question about where to get that piece, I have no idea and am watching this thread for the answer also.
« Reply #7 on: August 22, 2011, 02:37:57 PM »
In the threads I have read people use those chrome door edge guards they sell at auto part stores.
Offline wingman1946
    • BCINKART.com
« Reply #8 on: August 22, 2011, 03:34:52 PM »
Find a professional motorcycle seat repair/rebuild shop and they will have access to a replacement of some sort.
Offline WarwickE36
« Reply #9 on: August 22, 2011, 03:51:02 PM »
When I did my seat, I used a black one instead.  It is definitely separate.  I didnt like the chrome at all and am very happy with the black replacement.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
« Reply #10 on: August 22, 2011, 04:06:38 PM »
I bought the strip on eBy or about $8.
« Reply #11 on: August 22, 2011, 04:09:27 PM »
What they usually sell is door guard strips. You got a good price.
Offline Gordon
  • 750K1, 550K2
« Reply #12 on: August 22, 2011, 08:45:23 PM »
I'm guessing you've never worked on a stock 550K seat cover.  The chrome strip is what holds the seat cover onto the pan.  It and the plastic lip that folds over the edge of the pan and gets held on by the clips are a bonded one-piece with the cover itself.  There is no way to install the stock vinyl cover without the strip because there would be no way to hold it onto the pan.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #13 on: August 23, 2011, 09:36:20 AM »
I've worked on them, I think you're a bit off. There are sharp tangs that hold the cover in place. Then you install the trim to keep the cover tight and looking nice.
I would look for the Honda trim if you can find it, it's bit more beefier than the door trim. But if you can't find it the door trim works great. Try and find the stuff that has glue on the inside of the channel.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #14 on: August 23, 2011, 09:44:18 AM »
The stock 750 seat covers I have removed have had the chrome strip permanently attached to the seat as Gordon has mentioned. If you want to save it you literally have to cut it off.Never have had a 550 though.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #15 on: August 23, 2011, 10:15:43 AM »
On the 550 he should be able to just pull the old chrome strip off and put a new one on. Should only take a few minutes.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline keiths
« Reply #16 on: August 23, 2011, 07:29:49 PM »
I bought some channel trim and had a hard time getting the glue to stick on the thick edge and around the bends.
I always wanted to try this stuff, but never did.
http://www.brandsport.com/trmg-ww2-wc-05.html
It's cheep enough and might look better than the channel trim.
Let us know if anyone tries it.
« Reply #17 on: August 24, 2011, 06:29:18 AM »
Gordon - the cheap aftermarket seats for the 550 don't have the chrome trim, it attaches like Duad states above (I recovered one 2 years ago on my 550). Didn't like the recovered seat and sold it and found an original.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #18 on: August 24, 2011, 11:18:49 AM »
I just did a 750 cover and the chrome strip is channeled underneath for rivets, The rivets go through the outer seat cover, seat pan and folded seat cover . Seat cover is attached with little spears/wedges on the seat pan. Rivets for chrome strip are held with clips or tinnermans. Stock aluminum rivets are also bent after the clips are installed. I used aircraft rivets on mine and filed the heads so they would fit better into the channel. Clear as mud?  :)
you guys need to read a little better, he said 75' 550. No mention at all of a 750 seat.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline Gordon
  • 750K1, 550K2
« Reply #19 on: September 07, 2011, 08:18:22 PM »
Okay, so you guys had me doubting myself on this (not that hard to do ;)).  I had some time this evening to take the seat off my '76 550K to see if I had just missed something obvious the last time I took it off to find out what I would need to recover it, and as far as I can tell it's exactly how I remember.
The chrome trim is permanently adhered to the seat.  The only way to remove it from the cover would be to cut or tear it off, and then there would be no way to hold a new cover onto the pan, because the only clips on the bottom of the pan that hold the cover on are the same clips that hold the chrome trim and rubber strip onto the pan.  There are no separate clips or hooks to hold the vinyl cover by itself.
Am I just crazy?  Is there something I'm completely overlooking?
Offline Scott S
« Reply #20 on: September 08, 2011, 04:58:11 AM »
 That's what mine looks like from underneath, too. Like I said before...It appears someone installed an aftermarket cover and carefully trimmed the old seat cover to remove the trim, then installed it around the freshly covered seat.
'71 CB500 K0
'81 Yamaha XS650
Offline Gordon
  • 750K1, 550K2
« Reply #21 on: September 08, 2011, 06:09:58 AM »
I'm very interested to know how the cover is held onto your seat pan.  My 550 seat is badly torn in two places and I've been wanting to recover it for a long time, but the only covers I can find don't come with the chrome/rubber strip so there's no way to attach them to the pan.
Offline Scott S
« Reply #22 on: September 08, 2011, 12:18:54 PM »
 Gordon,
 I'll be removing the seat in the near fiture as I've found a correct '77-78 seat. I'll take plenty of pics when I can get to it (the bike is pushed up against the wall of the garage right now and I can get better pics once the seat is off ).
'71 CB500 K0
'81 Yamaha XS650
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #23 on: September 08, 2011, 12:34:49 PM »
Unfortunately from Honda all you could ever buy is a complete seat assembly. Most after market seat covers don't come with foam or trim. the trim is not hard to do. trust me if I can do it anybody can do it.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline Gordon
  • 750K1, 550K2
« Reply #24 on: September 08, 2011, 03:19:34 PM »
Okay, but how did you attach the cover to the pan?  The clips that hold the stock cover on via the chrome/rubber strip will not work for holding vinyl by itself.
