Author Topic: 78 CB550.  (Read 26330 times)
Offline andrew
Re: 78 CB550.
« Reply #75 on: November 14, 2011, 10:32:25 PM »
having some issues with the carbs. perhaps im an idiot, as well as ive never dealt with these "pd" nightmares before.
this is whats stamped on the carbs:
 is it these late model 77/78 pd carbs use their own style jets? they dont seem to look like the other keihin screw in jets, and i dont see a place for a press in o-ring jet to go either. i ordered 115's and 120's from dime city before i had opened the carbs to see these funny jets. the jets dime city sells that say they will fit up to 78' are the o-ring press in ones. (thats whats pictured under the listing, i havnt received them yet) here is the 90 jet that came out of my right side carb.
i thought perhaps the jet screws into the emulsion tube, but they dont budge, which at the time lead me to think its one piece. perhaps mine are really seized togeather? i put the 7mm on the emulsion tube and tried to twist the jet off with a flat head as well as pliers and nothing. can someone school me on these carbs as far as jetting, and where to get jets from that fit? the bike is a 78 and has the pd carbs on it. the bike has uni pods and a mac 4-1 with "race" baffle.(pretty free flowing) here some photos of whats inside the float bowl.
« Last Edit: November 14, 2011, 10:40:52 PM by andrew »
Offline Tews19
  • I am no
Re: 78 CB550.
« Reply #76 on: November 15, 2011, 05:25:32 AM »
The jet in your hand in the main 90 jet. The slow I is the one that presses in if I am thinking correctly. I had to clean my carbs 78 550 pds the week prior and it looked the same.
1970 Honda CB750 survivor.
Offline knowsnothing
Re: 78 CB550.
« Reply #77 on: November 15, 2011, 06:31:47 AM »
It has been about a year since i rebuilt mine on my 750, but I am pretty sure they the same and are 2 pieces.  Yours are just super stuck.
Also be sure to pull out the pressed in idle jet with a bit of leather and some pliers.  They are usually clogged if the bike has been sitting a while and the only way to really get them clean is to pull then and stick a small wire through them.  Just be careful not to make the holes larger.  If you do a search the process has been gone over a few times.
Good luck!
« Last Edit: November 15, 2011, 06:33:24 AM by knowsnothing »
1978 CB750k Blue - for sale
Offline heel_touge
Re: 78 CB550.
« Reply #78 on: November 16, 2011, 09:02:21 AM »
hows the riding position. im debating on clip ons but not interested in shortening a ride do to back or wrist aches.
Offline pablo78cb550
  • mmmph.
Re: 78 CB550.
« Reply #79 on: November 17, 2011, 04:44:40 PM »
yes those tips come off, run those throught a ultra sonic cleaner. should help out a bit.
AND make sure you haven't lost the needle jet.  it sits on top of the emulsion tube. about a 1/4" long. you can see the tip of it in side the carb when you lift the slide. i was missing 2 and for a long time couldn't figure out why my bike was not willing to run.
checked the timing like 5 million times
new ingnition nope
checked the valves nope
checked the compression nope
checked the charge nope
cleaned the carbs...... hey why is there only 2 of these thingys.....
just a thought. and these are only on the 77 and 78 carbs.
« Last Edit: November 17, 2011, 04:48:03 PM by pablo78cb550 »
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
Offline Kev Nemo
  • Honda Hacker
  • http://fallingapartart.com/
    • FallingApartArt
Re: 78 CB550.
« Reply #80 on: November 30, 2011, 11:01:21 AM »
Motion Pro?
I'm trying to find the ones that work for my '78 CB750-pretty sure these are universal (?)
Destroyed by Design since 2009 http://fallingapartart.com/
- '78 CB750k bobtrack
Offline Kemp
Re: 78 CB550.
« Reply #81 on: November 30, 2011, 10:07:34 PM »
Is your motion pro throttle a 1/4 turn quick throttle or is the stock turn ratio? The PD carbs on the 77/78 are harder to work on than the earlier style. They are the lean burn emission carbs and are harder to access the jet needle (to raise a notch to richen mid range) You pretty much need to disassemble the carb rack to access the needle jet! With uni pods on my 550 and running a 650 cam with 590cc kit I needed to raise needle up a notch for mid range, go to a 110main jet and increase slow jet to a #44.
Offline andrew
Re: 78 CB550.
« Reply #82 on: February 15, 2012, 02:31:10 PM »
it seems as if i have left this bike in time out for long enough. yesterday i tore it all apart and pulled the motor out of it as well as the other 550 parts bike i got with it. the motor thats going in the bike didnt have any signs of oil weepage or really any oil leaks i could see, as well as had the kickstarter in place. (P.O. snapped the shaft at the side cover) i removed the valve cover to check the valves and slack on the tc, and everything looks pretty good. put the vc back on, adjusted the valves and gave the motor a few coats of vht semi-gloss black. once that had dried, i installed as much of the stainless fastener kit as i could, as im not puting on a few covers until the motor is back in the frame. photos.
Offline andrew
Re: 78 CB550.
« Reply #83 on: February 15, 2012, 02:32:18 PM »
since my buddy couldnt make it tonight to help me install the motor, i figured id rebuild the forks. while they were apart i polished the legs and the top caps. nothing like chrome, but a hell of alot better than the crusty, pitted barnacles i had before.
before:
after:
and togeather.
sorry for the #$%*ty photos. the forks are much shinier in person. the lighting in my shop doesnt get along too well with my iphones camera. ill get some better ones when the bikes back togeather.
Offline andrew
Re: 78 CB550.
« Reply #84 on: February 15, 2012, 02:32:48 PM »
muscled the motor in tonight by myself. got the forks in and caliper as well as the front fender. im going to wait till my tires arrive to slap the wheels back on.
Offline andrew
Re: 78 CB550.
« Reply #85 on: February 15, 2012, 02:33:45 PM »
tires came in today so i got those mounted up and back on the bike. its nice to have it resemble something again.
also took apart the front caliper and spent some time cleaning it inside and out. the piston and seal seam to be in good shape. gave them a quick zip on the wheel and some fresh black paint.
my new jets arrived today as well, so im hoping my buddy will have a free minute tomorrow to let me come finish cleaning them (he lets me use his ultrasonic cleaner) and then reassemble them for hopefully the last time. fingers crossed.
Offline andrew
Re: 78 CB550.
« Reply #86 on: February 15, 2012, 02:34:40 PM »
well i got my carbs back from my buddy who ultrasonically cleaned them for me. he has been busy for a while so i was excited go pick them up and reassemble them. i get there and he even polished the tops and and float bowls! so awesome.
Offline andrew
Re: 78 CB550.
« Reply #87 on: February 15, 2012, 02:35:13 PM »
took em back to my shop and slapped em on the bike. i was having issues getting the bike going, but after taking my petcock out of the tank and giving it a good cleaning, she awoke! THIS DAMN BIKE RUNS!! (and strong too) i cant express how excited i am having it running and stopping under its own power. i took it out for a little test run tonight and she powers through all the gears great as well as cruises very smoothly. so pumped. heres some more #$%*ty photos of the final product.
Offline lucky
Re: 78 CB550.
« Reply #88 on: February 15, 2012, 02:38:01 PM »
Nice find. I have the same bike. Whats your goals with this build? I also Pm'ed you...
"If I drive for you, you get your money. That's a guarantee. Tell me where we start, where we're going and where we're going afterwards, I give you five minutes when you get there. Anything happens in that five minutes and I'm yours, no matter what. Anything a minute either side of that and you're on your own. I don't sit in while you're running it down. I don't carry a gun. I drive. "
This statement embodies the current generation. Take no responsibility,  make top dollar. Leave if there is any trouble. Not even loyal to fellow crooks. Just like Survivor Island ... Everyone in for themselves.
Offline andrew
Re: 78 CB550.
« Reply #89 on: February 15, 2012, 02:41:55 PM »
ummm.... what?
Offline Tews19
  • I am no
Re: 78 CB550.
« Reply #90 on: February 15, 2012, 03:11:36 PM »
Lucky, why you highjack his thread???????? Its a movie qoute, thats all.
Anyways, Andrew, Glad you posted today! I searched last night of over an hour looking for the build with the description of the rear taillight. Now I found it... Thanks!!!
Keep up the good work, Seat looks really good.
Offline Van-van
Re: 78 CB550.
« Reply #91 on: February 16, 2012, 06:37:45 AM »
Those dern kids!
Sent from my Galaxy Nexus using Tapatalk
Re: 78 CB550.
« Reply #92 on: February 16, 2012, 06:47:28 AM »
Bike looks tit!  Great work.  Now comes the fun part, riding the crap out of it  ;D
Re: 78 CB550.
« Reply #93 on: February 16, 2012, 06:49:01 AM »
Andrew - your bike turned out awesome! Could be BOTM material...
Offline Ryan66
Re: 78 CB550.
« Reply #94 on: February 16, 2012, 08:56:58 AM »
What headlight assembly is that? Love that yellow look
1976 CB550k (cafe project)
Offline fastbroshi
  • Puppet
Re: 78 CB550.
« Reply #95 on: February 16, 2012, 09:27:45 PM »
Probably just a yellow tint film applied on the stocker, you can find it lots of places.  It goes on just like window tint for cars.
Just call me Timmaaaaay!!!
Offline andrew
Re: 78 CB550.
« Reply #96 on: February 18, 2012, 12:45:35 AM »
its is the stock bucket with some h4 conversion reflector that came in a box with the bike. in the picture i was using film (like "laminx") but since then i have removed the film and sprayed the glass with krylon stained glass paint. it looks alot better in person, and the light output is much better. the film seemed to restrict some of the light.
Offline andrew
Re: 78 CB550.
« Reply #97 on: February 18, 2012, 12:48:28 AM »
and thanks for all the kind words fellas, it feels really good to be out and about on the bike. for a while, i was ready to wash my hands of this bike and just move on, but im glad i didnt. it runs and rides so smooth, and just pulls and pulls. ill try and take some out side photos of it tomorrow.
Offline wedoo2
Re: 78 CB550.
« Reply #98 on: February 18, 2012, 03:59:39 AM »
Andrew, I got to say that the paint scheme, using the original paint and brown seat looks great.  The first time I've seen someone use the original on a cafe build and it looks perfect.  That is an F right?  They have the right decals for this.  I'm sure that there are a lot more out there, I just haven't noticed.  I'm going to try the appliance paint on something BTW.
One thought; people go to a lot of trouble getting rid of all of the electrics, air box and side covers to leave that space open.  But sometimes it looks like there needs to be something there.  Just me.
I see Stevo mentioned the B word.  Great job.
Some days the sun is too loud.
Offline andrew
Re: 78 CB550.
« Reply #99 on: February 18, 2012, 09:33:36 AM »
thank you. the bike is a K model.
