Author Topic: Cruise Control / Throttle Locks ?  (Read 2820 times)
26.2
« on: May 17, 2006, 03:27:09 AM »
Hello all,
Has anybody installed a cruise control or throttle lock on their bike?  If so, what brand did you use, how well does it work, and was it a challenge to install?  I have a series of long trips planned for the summer (including an Iron Butt) and I'm exploring ideas which will give the old throttle hand a break and ways to maintain a constant cruise speed.
thanks in advance to any thoughts or insights,
- Tom
1978 CB750K
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: Cruise Control / Throttle Locks ?
« Reply #1 on: May 17, 2006, 03:31:34 AM »
There was a thread about this a while back.  There's a link in the FAQs to a "Throttle Wrist-Cramp Eliminator".
http://www.sohc4.us/forums/index.php?topic=743.0
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline Steve F
« Reply #2 on: May 17, 2006, 03:38:53 AM »
I had one on my 82 650C, and it didn't work very well at all.  It would constantly slip back, and I would have to re-adjust it.  Just pissed me off more than it helped.  It was all plastic, and I'm not sure how it was attached, but I didn't like it.  Maybe they've improved them since the mid 80's?  I'd just try to stay away from the all plastic varieties if possible.
Offline cb650
« Reply #3 on: May 17, 2006, 04:30:13 AM »
I have a couple of the cheap ones and they work fine.  Like them cause they are hardly noticeable.
           Terry
Offline Jay B
« Reply #4 on: May 17, 2006, 04:47:26 AM »
Try a Throttle Rocker. Little plastic thing that slips on the right handgrip and sticks out so your palm helps hold the throttle. I have a fancy $100 Throttlemeister throttle lock on my BMW, I don't think I've ever used it since I bought the $10 Rocker. Look in the back of most any bike mag, about $10 including shipping.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #5 on: May 17, 2006, 05:07:58 AM »
[quoteTry a Throttle Rocker. Little plastic thing that slips on the right handgrip and sticks out so your palm helps hold the throttle]
They are avail in a number of places, try J.C. Whitney, saw one there.
Offline mick750F
« Reply #6 on: May 17, 2006, 06:32:40 AM »
   There was a throttle lock on my bike when I bought it. It's one of the first things I removed along with a cheesy windshield, highway bars and a king/queen seat. It worked well enough but I didn't like the idea of the throttle being locked. I now use a Throttle Rocker which works great. A good $10 investment if you ask me, although it does seem a bit overpriced for a piece of plastic.
Mike
Glosta, MA
KilgoreTrout
« Reply #7 on: May 17, 2006, 08:10:30 AM »
This stuff should work.
eldar
« Reply #8 on: May 17, 2006, 12:14:01 PM »
Vista cruise is still being made. it uses a thumb lock that works well as long as it is adjusted right. You dont need to touch the throttle at all. they are about $30 or so.
Offline cben750f0
« Reply #9 on: May 17, 2006, 02:04:09 PM »
have used the vista, as long as you get the grip clearence right and adjust it properly, i had no trouble with mine....peace
« Reply #10 on: May 17, 2006, 10:31:31 PM »
When I had my BMW R100RS, (POS) I had to fit a throttle lock because the high frequency vibration would make my hand go to sleep on a regular basis, so I had to constantly remove my hand to shake out the "pins and needles".
The earlier CB750's had a built in throttle lock screw under the throttle body, but it's fiddly to adjust while trying to concentrate on the road, so one of those "thumb lock" jobs are my preferred option for long distance cruising.
I'd prefer one to the throttle rocker, although I suppose both would be good, for different reasons? Cheers, Terry. ;D
Offline Dave Wyatt
« Reply #11 on: May 18, 2006, 09:30:11 AM »
I used a throttle lock years ago and was not pleased with it.  It worked as intended, but with a steady throttle the bike would slow down going uphill and speed up on the downhill side.
I bought a $10 Kuryakin Throttle Boss this spring and find it works great.  I can't take my hand completely off the grip, but I can relax enough to relieve the tension.
http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=H59066&store=Main&catId=410&productId=pH59066&leafCatId=41003&mmyId=
Dave Wyatt
1976 CB750A
1965 C100
2008 GL1800
I swear, the damn things are starting to breed!
huntman58
« Reply #12 on: May 19, 2006, 07:18:07 PM »
Use one all the time I believe it is a Vista cruise. Wore one out and now have my second one. I tried the paddle thingy and did not care for it. Found it in my way when I wanted to shift my hands and it always was in the wrong place when I wanted to use it so I was always adjusting it
