Author Topic: 1976 750K, replacing pucks, need help with a part number for o rings  (Read 782 times)
Offline stickman
  • A vintage 750 is a terrible thing to waste....
I need to replace the 6 Sealing Rubbers under the cylinder head cover.  After researching this site I have identified the following parts I need:
6 Sealing rubbers, part number 91318-300-013
1 breather cover gasket, part number 571438
1 Cylinder head cover gasket part number 571643
4 small orings under cam tower
The last item is what I need help id ing with a part number.  I am using the Bike Bandit site if it makes a difference.
So, can anyone assist with a part number for the 4 o rings?
Many thanks in advance.  Stickman
Ed Jones, Lenoir, NC
1971 CB750, 1994 Kaw police bike KZ1000
Offline fire113
Re: 1976 750K, replacing pucks, need help with a part number for o rings
« Reply #1 on: November 01, 2011, 10:00:14 AM »
...I am not sure but I only have the part numbers for K0-K2--> 91317-300-003  (O-Ring 3.7 x 1.7mm)
« Reply #2 on: November 01, 2011, 10:21:14 AM »
His 76K takes a larger diameter ORing than the early Ks. I'll be back with the number. I'm going to motogrid.com anyway.
« Reply #3 on: November 01, 2011, 10:24:29 AM »
They are 91305-323-000 x 4, 5.8 x 1.9mm for $1.85 ea.
Fire113: I see in the parts diagram you provided the "323" O rings are shown as the later model ring. I think the later K2s had the larger ORing as well.
« Last Edit: November 01, 2011, 10:26:31 AM by MCRider »
Offline fire113
« Reply #4 on: November 01, 2011, 10:54:50 AM »
Hi MCRider,
...have to look at my pictures, not sure what kind of o-ring I used last year as I did the K2 engine but I think that I used the large o-rings, can't remember right now, have to check the pictures to be sure.
edit--> Yes! I used the lager o-rings  ;D
« Last Edit: November 01, 2011, 11:00:55 AM by fire113 »
« Reply #5 on: November 01, 2011, 11:27:09 AM »
Hi MCRider,
Based on my references, the larger ORings started at K3. But i thought some later K2s had them as well, a mid-model change.
Just an additional tidbit: The "323" center digits indicate CB500, so they are shared with the 500 at some place.
I see you're from Germany. Wasn't the K2 the latest model to arrive there? Then it was upgraded a few years later?
Offline fire113
« Reply #6 on: November 01, 2011, 01:29:09 PM »
...after the K2 (K3-K5 left out for the German market) Honda went on with the K6, and K7. May be the PO changed the head, You will never now hat the PO did.
As I opened up the engine  :o ...takes too long, that is an other PO story  ;)
Have a good one...
« Reply #7 on: November 01, 2011, 01:31:12 PM »
Oh, I see.   :)
Offline stickman
« Reply #8 on: November 04, 2011, 02:46:35 PM »
Thanks all, especially MCRider.............Great info.
