Author Topic: Can someone actually help me?  (Read 4586 times)
Offline jonboycox
« on: December 02, 2011, 06:20:07 PM »
I post from time to time with limited and vague response. Please give this one some real thought and try to help.
  I am trying to set the timing on a CB400F with points ignition. I have purchased a new timing light. It will strobe on cylinders 2-3, but I cannot get a strobe on 1-4. I have tried it all along the plug wire, I have cleaned the plug wire of oil and dirt, I have followed the arrow for the direction of the plug, I have tried the opposite of the arrow for the direction of the plug. I have tried every trick I have seen posted in the archives of this forum. I cannot get a strobe from either the 1 or 4 spark plug wire. What could the problem be? The bike starts easily and runs on all four. Great idle, decent run up the rpm range.
Offline FuZZie
Re: Can someone actually help me?
« Reply #1 on: December 02, 2011, 06:27:35 PM »
1 and 4 should be sharing the same coil, you sure it's running well?
Offline bender01
« Reply #2 on: December 02, 2011, 06:35:01 PM »
Strobe connection to the battery still solid after moving to 1-4?
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
« Reply #3 on: December 02, 2011, 06:38:38 PM »
try and move the pick up closer to the plug,avoid burning the wire on the hot exhaust.
« Reply #4 on: December 02, 2011, 06:46:17 PM »
Don't mean to sound flippant, but seems you've got a 2 cylinder CB400.
What could cause this? Both 1 and 4 leads are dead? The 1-4 coil is dead.
I may be missing something else obvious.  So I'm in it to see whats wrong, like you.  ;D
« Reply #5 on: December 02, 2011, 06:56:38 PM »
...this happened to me before also...tried it again years later with same timing light, coils, and wires and it worked :o...never figured it out...you can set your timing statically with a simple 12v test lamp...
Offline Kanticoy
  • Mad Science!
« Reply #6 on: December 02, 2011, 07:10:03 PM »
That is an interesting problem.  Are all of the header pipes getting equally hot?  Is there fire at the plugs all of the time?  I'm wondering if the 1 and 4 coil is going bad, because as other posters have said, these two cylinders fire off of the same coil.  Points gaps set?  Getting good spark at the points?  Strange.
« Reply #7 on: December 02, 2011, 07:18:17 PM »
Something to check with an ohmmeter:
if the plug cap(s) are burned open, like above 11,000 ohms on the CB400F, the spark discharge will be slow enough that the pickup coil in the timing light may not be able to pick it up. The solution then is new plug caps.
Offline jonboycox
« Reply #8 on: December 02, 2011, 08:25:53 PM »
Awesome responses.
 All four cylinders are firing, all the pipes are hot as hell and I have the burns to prove it. The bike starts and runs really well, just not getting strobe to the timing light. I have tried with the tank off to access the entire length of the spark plug wire. The battery connection is totally solid. The plug caps are new NGK's all the way around. Should I check how they are threaded on to the wire? Is it possible to be getting enough current to fire the plug but not register on the inductive pick up? How can I test the ignition coil? Could this be the beginning of a bad coil? Keep it coming boys.
Offline FuZZie
« Reply #9 on: December 02, 2011, 08:56:18 PM »
Follow HondaMan's directions and post back, he didn't get that cape for nothing. ;)
« Reply #10 on: December 02, 2011, 09:44:00 PM »
Which plug caps did you get? The best bet for these bikes is the 5k (5000) ohm version with stock coils, or 10k ohms with Dyna's 3-ohm coils.
Yes, a weakening coil can cause this: you can check for this by opening the gap on a fresh pair of sparkplugs to 3.5mm each and see if the spark will jump that far (plugs resting on the fins) on both plugs at once. If not, the coil may be "slowing down", and usually it then acts up when hot, working OK when cold. Internally, the insulation is then flaking off some of the wires.
Also, give a tug to those wires where they enter the coil. If one comes out, it's done for.
  • I'm back
« Reply #11 on: December 03, 2011, 12:03:58 AM »
Could there been interference with the neighbouring 2 and 3 leads?
... or 10k ohms with Dyna's 3-ohm coils.
Hondaman, can you shed some light on this?
« Last Edit: December 03, 2011, 12:08:24 AM by Deltarider »
« Reply #12 on: December 03, 2011, 12:21:50 AM »
My personal opinion is strobes are a wast of money for the Hondas, get the points gap set at 0.35mm or 14 thou---NOT JUST SOMEWHERE IN THE TOLLERANCE---and set the static timing exactly on the F with a bulb---(N.B. it can take quite a lot of time and perseverance to get BOTH gap AND timing spot on) and the motor will run like a sewing machine---assuming of course that all the other service items are attended to
« Reply #13 on: December 03, 2011, 12:31:04 AM »
even if you use the most finnesse and evil eye you have setting points on these,the strobe will show up a shortfall which will be so obvious,more so these days i think to the low quality points available now,if its static timed accuratley it will run,,and run well,the strobe light gets it just that little bit more perfect,the hardest thing is marrying up the timing between 1/4 and 2/3,,youll have the gap or dwell correct but still the "sync"between the pairs can be a mongrel to set,you can be sloppy with low rpm engines in this reguard but these little engines spin fast and the less the pair of cylinders fight or lag the better,it results in a smoother running engine that is easier to vacuum sync,giving rise to a better riding experience.
« Last Edit: December 03, 2011, 12:36:30 AM by dave500 »
Offline Scott S
« Reply #14 on: December 03, 2011, 03:54:08 AM »
 Did you cuoff a small piece of the plug wire when installing the new caps? Maybe a 1/4" or slightly less, just enough to expose some fresh wire for the caps to screw into.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline becken
« Reply #15 on: December 03, 2011, 06:04:57 AM »
Sometimes if you use a separate battery to power your strobe light (not the bike's battery) you will need to run a wire from the negative of the battery used to power the strobe to ground on the bike to make the light function properly.
1976 CB550F bought new
1981 CM400A wife bought new
2004 GL1800
Offline jonboycox
« Reply #16 on: December 03, 2011, 06:37:12 AM »
I am using the 5k plug caps. I did cut back to fresh wire before twisting them on. I am remembering seeing the wire coming out of the 1-4 coil rotating a little when I reinstalled them. I will try the trick with gaping the plug and seeing if the coil can push hard enough to jump 3.5mm, I suspect this is the culprit, as it is one of the things I had to repair. It looked as if the #1 plug cap had been yanked off in a crash, there was a length of yellow replacement wire threaded on with the wrong ohm plug cap on the end, this lined up with some scratches on the motor. The #4 looked fine however. I will also try to tug on the wires at the base of the coil on 1-4 and see if they are secure.
  Thanks for the best answers I have had so far on this sight.
bollingball
« Reply #17 on: December 03, 2011, 07:35:21 AM »
Have your ohm meter hooked up to the coil while you are doing the pull and tug. If your meter has the buzzer on the low setting you may hear it.
« Reply #18 on: December 03, 2011, 01:21:42 PM »
If the wire has been replaced, it is junk. The OEM wires are welded to the coil wires inside the coil (before they slip the insulation over it), and are not removable. This might be pointing directly to the problem...
Offline jonboycox
« Reply #19 on: December 03, 2011, 01:33:00 PM »
Some resolution at least. The ignition coil is officially dead, no spark from either 1 or 4 plugs.  Coil to wire joints where not in bad condition. Caps where reading right on 5 ohms, but when I reassembled everything I got no starting and only the 2-3 pipes getting warm. I pulled the 1-4 plugs individually, grounded them out on the motor and saw no spark at all.  I think HondaMan hit the nail on the head once again, that coil was going, going then gone. So moving forward, where should I look for new ignition coils. I would like to replace them both, and preferably with something new. Any links to available options would be greatly appreciated!
« Reply #20 on: December 03, 2011, 04:00:27 PM »
Today's version of Honda's own coils are actually much better than the 1970s version. They also give a longer duration spark than any of the aftermarket coils, and are always my first choice on a rebuild for someone, even a racer. The coils are good past 14k RPM.
The other options out there each have issues: the Dyna 5 ohm coils are pretty good, but have a shorter spark duration than stock coils. The Dyna 3 ohm coils make more voltage, but if the plug caps and wiring is good in the bike, there is little or no difference from the voltage change because the duration of the spark is VERY short unless you add some things to those coils. Those 'tings' are: add a series resistor to the power side of each coil, 1 ohm (this is even Dyna's own recommendation for the SOHC4 bikes), and change the plug caps to 10,000 ohms instead of 5,000. These two things together will let the 3 ohm coils generate about 1.1mS spark duration at about 25kV at the plugs, but the stock coils make 1.2 to 1.5mS duration, much better in comparison. The stock coils make about 7500V (7.5kV) spark, but these engines (stock) only need a little over 4kV to fire and run well.
The main advantage of the Dyna coils is in the long run: the wires can be replaced, where the stock coils won't let you change them.
Offline Kanticoy
  • Mad Science!
« Reply #21 on: December 03, 2011, 04:11:54 PM »
The GL1000 coils are awesome replacements for our bikes.  With little effort they will fit the stock bracket, they have replaceable leads, and they produce a very nice spark.  I have them on a cb550 and 2 cb400f's with zero problems.
The only modification I had to do was cut off the little plastic surround on the two end grounding/mounting lugs.  Then it bolts right in.
« Reply #22 on: December 03, 2011, 07:27:33 PM »
make sure what ever coils you get the primary resitance is 5ohms,,in your reply i think you meant your caps have 5000 ohms or 5kohms?
Offline cben750f0
« Reply #23 on: December 03, 2011, 09:25:27 PM »
just remember that the screw on leads will hit the inside of the tank if you dont modify the mount.... had that issue when i fitted them to the F, in the end fitted VF750/1000 coils and all is good.
http://forums.sohc4.net/index.php?topic=48400.0
peace
« Last Edit: December 03, 2011, 09:30:08 PM by cben750f1 »
« Reply #24 on: December 03, 2011, 11:44:35 PM »
GL 1000 coils are not 12volt as they run through a ballast resistor on the GL so yes they will give a great spark as they are being over voltaged but who knows for how long
