Author Topic: My Tron tail light.  (Read 6974 times)
Offline Dyrden
My Tron tail light.
« on: January 22, 2012, 02:03:45 PM »
This is in my build thread but not everyone is gonna see that.  I had the idea a while ago but after seeing Tron(and seeing how the Duck was done) I figured I could do one better.
Its lit by 36 dual intensity LEDs from custom dynamics.
Untitled by bailey_james62@ymail.com, on Flickr
Its extremely bright from behind and pretty bright from side angles.
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
Re: My Tron tail light.
« Reply #1 on: January 22, 2012, 02:22:51 PM »
Frigging brilliant!
Ringo
« Reply #2 on: January 22, 2012, 02:29:10 PM »
Looks great man!  I love Custom Dynamics.  Little on the pricey side, but you can't beat plug and play LEDs.  I went with one of their flush mount kits (the top light).  Couldn't be happier.  Good luck on the rest of the build.
Offline Dyrden
« Reply #3 on: January 22, 2012, 02:37:25 PM »
Thanks guys.  Ringo, your build is one of my favorites.  I used the flush mount LED as well, but I just used the LED strip from it because of its short height.  I didnt use the reflector portion and bought a small sheet of 1/2 polycarbonate so I could make the tight radius curve with it.   I think we have the same LED tail light, I got the 36 LED strip.
Ringo
« Reply #4 on: January 22, 2012, 02:47:29 PM »
Very cool.  My LED strips were epoxied into the housing from CD.  I take it yours weren't?  I had to fabricate a flat area into the back of my seat to to accommodate the housing.  It was what I was planning to do from the start, but the option of flexibility would have been nice!
Offline 65Ch3v3LL3
« Reply #5 on: January 22, 2012, 10:04:20 PM »
Looks great. The CD LEDs are good quality. I've run some of the Radiantz LED strips on my Harley for years and never had any problem. Are you doing integrated turns also or are you adding separate turn signals?
1979 CB650
2011 Harley Road King
2008 Harley V-Rod VRSC DX
2012 Sierra Denali 2500HD
1965 Chevelle Malibu SS
1922 Ford T-Model
Offline faux fiddy
  • bike in a box
« Reply #6 on: January 23, 2012, 03:44:39 AM »
I like it, but cost to do it, I'm just  stock parts  broke. Ever think of getting an  SV instead of just the lights?
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline ejc2g
« Reply #7 on: January 23, 2012, 09:01:04 AM »
Very nice, looks great!
Offline Dyrden
« Reply #8 on: January 23, 2012, 11:07:41 AM »
An SV? Cost in materials including the LED and frame loop was about 100 bucks. Time wise it took me about 1 full day of work and that was with a break for motocross on CBS.
Offline calikid
« Reply #9 on: October 19, 2012, 01:56:17 AM »
this is sweet! where is the link to this LED light?and its just plug and play? how did you get the led flush to the loop? I see its cut in, but how is it attached?
Offline Garystratos201
  • I have never been a
« Reply #10 on: October 19, 2012, 12:35:39 PM »
very sweet indeed !!!
Visit my build project;
http://forums.sohc4.net/index.php?topic=111620.0
Current ride; Bass boat.... 2005 Ranger 521VX,250 hp Mercury Verado, super charged and direct fuel injected. Not a bass on the lake can out run me !!!
Offline derelicte
  • '74 CB750
« Reply #11 on: October 19, 2012, 03:23:26 PM »
it's a star trek tail light
Offline Dyrden
« Reply #12 on: October 19, 2012, 04:36:18 PM »
The LED is plug and play... if you can do some wiring and fab that is.  Basically this is just a square hole in a curved piece of tube.  I used 16 gauge steel to make a pocket and the LED loads in from the top and back.  It then shines through the opening and through a thick piece of polycarbonate that I sculpted to match the outside profile of the frame loop.  Its a hot rod trick used when you want to blend lights into body work.
« Reply #13 on: October 20, 2012, 10:16:18 PM »
  And. Local guy here, Goldammer has made them as narrow as 1/4 inch, and they are surprisingly bright, Has them on several of his bikes, some are built into the edge of the fender, and look invisible til lit. Two of his bikes that have them are Trouble, and BTR 3, can find them on line.
Offline MattFreeman
  • What Have I Done?
« Reply #14 on: October 23, 2012, 02:25:49 PM »
sweet. thanks for the post.
Offline Lavis500
  • Why don't you go ask a
  • "Don't plan vast projects with half-vast ideas"
« Reply #15 on: October 23, 2012, 05:46:19 PM »
Cool!  Can it blink on each side, too?  Or are you getting different turn signals?
"Whatever it is, I swear I didn't do it!"
'73 CB500 - Sally
Offline Dyrden
« Reply #16 on: October 23, 2012, 06:29:12 PM »
I could incorporate turn signals into the light but decided not to run them.  Ive since TIGed the sheet steel to the frame loop and ground it smooth.  The frame is also PCed black.  Ill take better photos as soon as the bike is on the road.
« Reply #17 on: October 23, 2012, 07:30:06 PM »
The very thin ones on Goldammer bike signal and work as a brakelight, and the fender edge is about 3/8,  or less in thickness..
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #18 on: October 23, 2012, 07:49:27 PM »
Nice work.
Offline mono
  • Definitely no
« Reply #19 on: October 24, 2012, 12:09:01 PM »
nice work!
Offline MattFreeman
  • What Have I Done?
« Reply #20 on: January 23, 2013, 12:12:55 PM »
http://www.customdynamics.com/Images/2012%20Cus%20Dy%20Catalog-103.jpg
I'm guessing you purchased this light. I can't see from the photos how one would attach the led board to anything. Did you glue the back of the board to a piece of steel? There doesn't appear to be holes for bolts or screws...
Can you shed alittle light  ::) on how you accomplished this?
Thanks
Offline SF
  • I burn gas very well
« Reply #21 on: January 23, 2013, 12:48:07 PM »
nice job. i like it
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline Dyrden
« Reply #22 on: January 23, 2013, 08:46:59 PM »
Thanks
Yup thats exactly the one.  That LED board weighs about nothing and I just mounted it to the back edge of the pocket I made with the double sided tape.  Its been holding fine and is protected from the elements.  Some railroad track launches and its still holding strong.
Offline MattFreeman
  • What Have I Done?
« Reply #23 on: January 24, 2013, 06:03:00 AM »
ah yes, tape. very good. thanks a ton.
