The SOHC/4 Patch & Pin Set is available at the SOHC/4 Store.
You have probably been very lucky. The vacum synch allows for the inevitable variations that can be found between cylinders and carbs. The dial gauges prevent sucking liquid into the cylinders. When you go through the synching process is that as you synch a carb the carbs around it change. So you finally tweak them all to get 1 3 4 even with 2. Your method does not allow for this.You may be close enough so the differences are negligible. It is not microsurgery.
Quote from: BobbyR on March 07, 2012, 09:07:04 PMYou have probably been very lucky. The vacum synch allows for the inevitable variations that can be found between cylinders and carbs. The dial gauges prevent sucking liquid into the cylinders. When you go through the synching process is that as you synch a carb the carbs around it change. So you finally tweak them all to get 1 3 4 even with 2. Your method does not allow for this.You may be close enough so the differences are negligible. It is not microsurgery.I would like to take the time and answer this fully.Although there are variations you would still not want to look into the intake and find out that one of the slides is 1/4 higher than any of the other slides even if the manometer showed it was right.It would mean that that carb has something very wrong or different going on with it and that it must have an air leak in the intake boot or the throttle shaft bushings.When you look into the intakes you want to see all of the slides going up and down at the same time. Also when the throttle is closed, you want all the slides bottomed outother wise it means that one of the slide needles would be raised up and causing more gas to be used on that carb. Because when a slide moves upwards the needle moves upward in the main jet. If you have a old engine you may have to use the manometer until some of the problems can get corrected. New pistons,rings, and carbs rebuilt etc.,.But I do understand what you are saying.When you use the manometer on the 1977 or 1978 CB750 carbs you making the adjustments that directly raise or lower the slides on #1,#3, and #4 cylinders.WHY NOT just measure them? Especially if the carbs are off of the motorcycle.Then if you use the manometer and it says one of the carbs is WAY off you know that particular carb or cylinder has some kind of problem. Air leak bad rings ,throttle shaft leak to look for. Then if a compression check shows all cylinders are the same then you know it is the carb or rubber intake boots.Just another way to do things.
Quote from: lucky on March 14, 2012, 12:43:02 AMQuote from: BobbyR on March 07, 2012, 09:07:04 PMYou have probably been very lucky. The vacum synch allows for the inevitable variations that can be found between cylinders and carbs. The dial gauges prevent sucking liquid into the cylinders. When you go through the synching process is that as you synch a carb the carbs around it change. So you finally tweak them all to get 1 3 4 even with 2. Your method does not allow for this.You may be close enough so the differences are negligible. It is not microsurgery.I would like to take the time and answer this fully.Although there are variations you would still not want to look into the intake and find out that one of the slides is 1/4 higher than any of the other slides even if the manometer showed it was right.It would mean that that carb has something very wrong or different going on with it and that it must have an air leak in the intake boot or the throttle shaft bushings.When you look into the intakes you want to see all of the slides going up and down at the same time. Also when the throttle is closed, you want all the slides bottomed outother wise it means that one of the slide needles would be raised up and causing more gas to be used on that carb. Because when a slide moves upwards the needle moves upward in the main jet. If you have a old engine you may have to use the manometer until some of the problems can get corrected. New pistons,rings, and carbs rebuilt etc.,.But I do understand what you are saying.When you use the manometer on the 1977 or 1978 CB750 carbs you making the adjustments that directly raise or lower the slides on #1,#3, and #4 cylinders.WHY NOT just measure them? Especially if the carbs are off of the motorcycle.Then if you use the manometer and it says one of the carbs is WAY off you know that particular carb or cylinder has some kind of problem. Air leak bad rings ,throttle shaft leak to look for. Then if a compression check shows all cylinders are the same then you know it is the carb or rubber intake boots.Just another way to do things.Great explaination. Now getting real. Once the bike is toghether how would you do this again? I have to tell you a carb synch is not a one time occurance. I am sure some has a bike that was synched in 1975 an they can balance a quarter on the motor. I am not so blessed, I get about 4 years and I am pushing it.
All of the slides will be within .001 of each other!No need to sync with vacuum manometer.
bench sync gets the motor running good enough to run and use the vac sync period.,get a perfect vac sync then measure the slide heights,they will differ.,a bit like points,,you can set them by eye and get it running,then use a dwell meter and timing light if you want.
yeah,,im just saying that a bench sync is a bit like just eyeballing points,,youll get it running but then you can use dwell meter and timing light to square it off.
and you look at this tool with your eye,,i think its been mentioned above that the idea of carb syncing is to balance the actual vacuum between the cylinders not actually get the slides at the same height,which will get the bike running ok then use a vacuum method,leaving them set where the precision instrument aligns them is precisely wrong.
