Author Topic: Front sprocket oil seal - replacement disaster!!!  (Read 22858 times)
Re: Front sprocket oil seal - replacement disaster!!!
« Reply #25 on: January 30, 2012, 04:50:49 PM »
+1 on what Johnie said! Curious to see this magic tool!
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #26 on: January 31, 2012, 05:51:02 AM »
Here's one example, there are others. Usually, they involve some sort of hook function.
« Reply #27 on: January 31, 2012, 07:27:06 AM »
 What I dont like about most seal pullers, is they twist the seal to one side, which is not helping the bore.. has to be easier to pull relatively straight than forcing it at an angle. I use 2 screws 180 deg apart.
 I learned this doing the thiunwall Kayaba fork legs, very easy to crack them pulling the seals.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #28 on: January 31, 2012, 05:53:43 PM »
I'm thinking of a dental pick as a seal removal tool, right?
It's what I use on a seal like this.
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
« Reply #29 on: February 01, 2012, 04:42:43 AM »
I was using a dental pick on mine but it wouldnt budge. Handy for getting between the seal and the casings however to kind of free it up. However as Frank mentioned maybe I was grabbing too close to the middle of the seal and not on its outer edges - 180 apart with two screws or whatever. Its a very tight space in there.
Offline RayWrangler
  • 1970 k0 cb750
« Reply #30 on: September 28, 2013, 12:33:14 PM »
i know this is years after the post but may help future readers.
I HAD THE SAME ISSUE OF LEAKING OIL FROM THIS SPOT. i bought the sprocket seal gasket and took the chain and the sprocket off. i found that it was actually leaking from the chain oiler adjuster which is that nut and bolt that is in the sprocket.
when you look at the pictures above you see inside their are threads. and a hole on the top . oil fills inside of that passage and lubes up the chain. a bad inner seal can leak a #$%*load of oil all over your floor.
what i did to fix.
1. TAKE CHAIN OFF
2. TAKE SPROCKET OFF
3. TAKE SOCKET AND REMOVE THE CHAIN OILER NUT
4 GET A RAG AND SPRAY THAT AREA WITH BREAK CLEANER TO REMOVE GREASE ( CLEAN IT ALL UP)
5. FIND YOUR SELF A M6 SCREW I THINK ITS M6 BUT REMOVE THE SEAL ADJUSTER FROM THE NUT YOU UNBOLTED.
6. USE THE SCREW AND PUT SOME HIGH TEMP RTV AROUND THE THREADS AND SCREW INTO THE NUT.
7. THAN ONCE THE INSIDE OF THE SPROCKET SHAFT IS CLEAN. FILL THAT HOLE DAMN THING WITH RTV
8. PUT IT ALL BACK TOGETHER
9. SAVES YOU THE HASSLE OF REPLACING THAT SPROCKET SEAL. IVE SANDBLASTED THOSE SEALS BEFORE.... AND THEY HAVENT LEAKED. + THAT SEAL IS JUST A COVER, IT DOESNT HOLD BACK PRESSURE. THEIR IS A ROLLER BEARING BEHIND IT.
HOPE THIS HELPS FUTURE RIDERS
« Reply #31 on: September 28, 2013, 02:06:03 PM »
Thanks for posting. Believe me it wasn't the chain oiler leaking - I have that plugged permanently. In my case it was definitely the seal and once it was replaced no more oily back wheel. And the second time I did it used a drift to get it in straight - that's the trick!
Cheers
Andy
Offline anders288
« Reply #32 on: September 28, 2013, 06:39:52 PM »
Cheers
Andy
      Good job Andy
« Reply #33 on: September 29, 2013, 06:51:13 PM »
EDIT - Anders machined a drift and helped get the seal in straight - great work as always Anders!
thanks
Andy
