Author Topic: oil thickness  (Read 9809 times)
Offline jjtoney
  • blood, sweat, and beers
oil thickness
« on: March 22, 2012, 02:45:23 AM »
Hello, wondering about my 1974 honda cb550f engine and the oil selection. I live in Arizona where it is very dry and hot about 107 degrees average in the begining of may till September. I am running the standard 10w 40 oil. I have noticed that i am seeing smoke come out of my breather cap after riding it around town in about 80 degree weather. I did put in the right amount of oil. I also have been doing some research on the site about using heavier oil. Would this be a solution too my problem with excess smoke through the breather filter and performance due too the climate/temperature. d
Offline trueblue
Re: oil thickness
« Reply #1 on: March 22, 2012, 06:07:12 AM »
I originally ran 10w40 in my 650 and it used a small amount of oil, I changed to 20w50 oil and oil usage dropped dramatically and so did engine noise, I live in Queensland and summer time temperatures are regularly over 30 c.
1979 CB650Z
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: oil thickness
« Reply #2 on: March 22, 2012, 07:57:24 AM »
When you get consistent temps above 90 F you can safely switch to 20 W 50.
Offline Rigid
  • She likes a
    • KingCustomCycles
Re: oil thickness
« Reply #3 on: March 22, 2012, 09:14:38 AM »
That smoke could be water vapor boiling out of the oil.  Not necessarily oil vapor.  Another possibility is fuel that is evaporating from a combination plugged bowl drain line and stuck needle.  Outside air temperature differences between 70 and 100 are small compared to the difference that occur inside the engine, regardless of ambient temps.  based upon speed, throttle position, and load.
Re: oil thickness
« Reply #4 on: March 24, 2012, 01:59:54 AM »
For your climate, I'd go with 20w-50, and or use a synthetic blend  for it's higher heat withstand.
If your compression check is good, try to figure out if the "smoke" from your breather is actually water vapor.  As in, does it still do it after the engine has achieved full operating temperature for 15-20 minutes.
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
Re: oil thickness
« Reply #5 on: August 01, 2012, 01:17:42 AM »
NAPA sells a house brand full synthetic made for them by Valvoline that is 15W-50. Great for the heat, and decently priced @ about 5 bucks per quart. Has been working great in my 550, with no clutch slippage as has been reported sometimes with other synthetics.
Offline tlbranth
Re: oil thickness
« Reply #6 on: August 01, 2012, 08:40:06 PM »
Try Chevron Delo. It's 15/40, costs $38 for 3 gallons at Costco. I have 4 bikes and use it in all of them.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline shinyribs
Re: oil thickness
« Reply #7 on: August 01, 2012, 09:30:45 PM »
Ok, I have a dumb question combined with a thread hijack: what is the harm in using 20-50 in moderate temps, say 65-80 F?
The darn fool didn't know it couldn't be done...so he went ahead and did it anyway.
My Hackjob build- http://forums.sohc4.net/index.php?topic=106103.0
Offline cabrala
  • Super Duper
Re: oil thickness
« Reply #8 on: August 01, 2012, 10:15:20 PM »
I use 20/50 in a New England climate without issue, and I would say you are safe in the 65-80F range. The problem area becomes very cold starts on which the thicker viscosity has the potential to blow your oil pump neutral switch (not sure if I have the proper part terminology). Some swear by it and other swear by the manual, so ultimately it's your call.
Way to sneak in an oil thread! :D
Pretty damn clever I must say.
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
Need a better, newer points cover gasket? How about rubber washers for the headlight bucket? Click the link below:
http://forums.sohc4.net/index.php?topic=122308.0
Offline shinyribs
Re: oil thickness
« Reply #9 on: August 02, 2012, 09:06:44 PM »
Thanks for the reply. I went ahead and checked the manual out of pure curiosity. It calls for straight 20w in moderate temps and straight 30w in hotter temps. So I'm guessing that 20w-50 should be spot on,actually.
Re: oil thickness
« Reply #10 on: August 03, 2012, 12:09:04 AM »
.... So I'm guessing that 20w-50 should be spot on,actually.
Yes, guessing, but why?  The Honda owner's manual states 10W-40 for all weather use.
More is not always "better".  And, who is reporting problems stemming from actually using the manufacturer's recommendations?
Why do we need to fix what isn't broke?
Offline shinyribs
Re: oil thickness
« Reply #11 on: August 03, 2012, 05:39:06 AM »
Guessing-just a 'saying'. I guess I should have said I "suppose 20W-50 will be spot on" or " I reckon" or "looks like" or "hey,check this out". Who knows why I say what I say....i sure dont ;D And 20w-50 is alot closer to the 20W the manual calls for than  10w-40 is. Manufacturer's Rec....right?
Re: oil thickness
« Reply #12 on: August 03, 2012, 11:22:16 AM »
I wouldn't assess it that way.  Oil viscosity varies with temperature.  Which means it flows slower when cold and the film barrier it provides between bearing surfaces get thinner and weaker as it warms.
All oils do this.  Enter Multigrade oils, which have polymer additives that change viscosity properties as heat is added.  Yes, it gets thinner, but it behaves and provides a film barrier equal to the higher weight grade on the label.
When the engine is cold 10W-40 behaves like 10W which flows easily about the engine, and provides all the film strength needed to properly lubricate engine components, even below freezing.  As the engine warms the oil, it behaves like a thicker oil.  When it gets to 180 degrees, t performs as a 40wt oil which is the thickest oil that Honda recommends for the SOHC4.
If you were to use a straight grade oil, my 77 CB750F owner's manual doesn't recommend more than a 30Wt oil in straight weight and assumes the engine will never be operated with outside temps below 59F using the grade oil.
There is NO factory recommendation/requirement for 50W oil at any temperature.
If you wish to ignore factory recommendations and insist that more is better, why would you stop at 50 Wt?  Why not go to 70 or 90 wt?
Isn't having $90 better than having only $40 or $50?  :-\
On the one hand if you never travel to anyplace and start the engine cold where temps are 32F or below, then technically you are within bounds using an oil that can't behave at less than 20W viscosity.
What is of concern though, is not so much how it behaves while at operating temp.  But, how it behaves and functions as it warms up.  So, how you are using it matters.  Short runs, may never warm the oil much, leaving the engine with marginal lubrication using 20wt.   10Wt flows and behaves much better in this regime.  However, if you start once a day and ride for hours, cold performance is less critical, because the operational time spent while the oil is cold is a much smaller percentage of total operation time on the engine.
The point is, that the manufacturer says you needn't worry about oil viscosity or tailor the grade for the specific treatment you are doling to the machine, by simply using 10W-40.  It's all weather, all condition, street recommended.  And, you don't need to be a guinea pig or use your engine as a test rig to determine the efficacy of an alternate oil selection.
Check out the vast difference in viscosity when the oil is cold, as in during start up.
I see this chart and say "Aha, THAT'S why Honda said to use 10W-40".  I don't understand why so many assume Honda knew less than internet posters.  On the flip side, if the machine is modified to produce more internal heat (max power), or is operated to spend more time in an environment of high heat,  (Ie, outside normal/racing) then you are already in the experimentation arena, and have chosen to be a guinea pig.  ;D  Roll the dice and take your chance!
To me, stock engine = Honda recommendations.  I've not seen a convincing argument for change other than statements surrounding the terms;"I like it".
I did try 20w-50 some years ago in my 550's.  Clutch drag, gnashing of gears, clunk and lurch into gear (particularly when cold) was far more prominent.  Cold operation was clearly harder on the trans and shifter mechanism.  Didn't actually break anything.  But, I'm sure there were increased wear factors with all that hammering.  With 10w-40, start up and go was far less problematic and smoother, particularly on cold mornings.
Chart from:  http://widman.biz/English/Calculators/Graph.html
Good luck on your choice!
Offline NewOldSchool
  • Apprentice
Re: oil thickness
« Reply #13 on: August 03, 2012, 12:24:12 PM »
Honda Man recommended using 20w-50.
So I do that.
Never noticed anything negative about it switching from 10w-40.
Not putting miles on your bike is like not having sex with your Girl Friend so she'll be more desirable to her next Boy Friend.
Re: oil thickness
« Reply #14 on: August 03, 2012, 12:56:08 PM »
Thats what I use. Going to try some Melvac next time, but 20W50 is what I use now.
Offline cabrala
  • Super Duper
Re: oil thickness
« Reply #15 on: August 03, 2012, 01:01:49 PM »
TT's rendition of "if it ain't broke, don't fix it" is well played across this forum, and while I do think his take is a very valid and logical one, it's a bit exaggerated here.
The OP was not being unreasonable about straight weight oil choices, so there is no need to harp on "why not 70W or 90W". Plenty of us ride 20W50 and do not live in the desert or in ridiculous year-round heat environments. While no one should subject their bikes to extreme guinea pig-ism, I am all for trying out a variety of oils to develop a preference. Be logical about it though and pay close attention to the bike.
For the record, Honda engineers know/knew a whole lot more than many "internet posters", but that shouldn't take away (entirely) from what we've tried, tested and learned from over the course of ownership.
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
Re: oil thickness
« Reply #16 on: August 03, 2012, 01:04:14 PM »
So I do that.
Like was said befoe if you have temps consistently above 90 degrees F 20W50 works great.
If you have temps consistently cooler than that 10W40 is recommended.
Summer, 20W50 good, All other seasons with temps below 90 degrees F use 10W40.
  • Apprentice
Re: oil thickness
« Reply #17 on: August 03, 2012, 03:53:37 PM »
So I do that.
I do live in Southern California. We have summer and cold summer. :)
Offline CoachDoc
Re: oil thickness
« Reply #18 on: August 03, 2012, 04:10:10 PM »
I'll go with HM on this one. I used 20w-50 oil for years and never saw any of the problems TT ascribes to it. I'm extremely confident that the higher top end viscosity will provide better engine protection in the heat, and the 20 at the bottom end is fine down to the 30 degree range per the owner's manual, so to me this is the way to go. As I mentioned previously, I'm now using a 15w-50 which will make concerns about cold weather starts even more of smooth point.
Offline shinyribs
Re: oil thickness
« Reply #19 on: August 03, 2012, 04:20:15 PM »
Two Tired, thanks for all the info. In my drag motors ( GM V8's) I always used the oil my engine machinist set the engine up for and I never really learned all the ins and outs of the viscosities. On my daily drivers I always went by manufacturers rec's. I had it wrong. I thought that 20w-50 meant it was 20w oil ( pourability)with the lubricating properties(sheer strength) of 50w oil. Shows what I know,huh?
Also, i recently did Hondaman's clutch mod to my bike,and while it did improve things vastly with the increased oil pressure I have now with healthy o-rings in the bike,it is still a tad hard to find neutral. My line of reasoning ( which is often screwed up) was that if the increased oil pressure helped as much as it did,then maybe a swap from 10w-40 to 20w-50 would give me that last lil bump of pressure to make things work even better.
I did not mean for my post to appear as a recommendation,but as a question. So, you had shifting troubles in conjunction with the thicker oils?
Offline CrankyOldGuy
  • Wish I was a
Re: oil thickness
« Reply #20 on: August 03, 2012, 04:33:05 PM »
Here I sit munching away on cheezies, I have no popcorn on hand.
On page 178 of the Honda service manual (obtained from this site) for my CB750K1 it states "Add approximately 3.0 qts. (2.9 lit.) of good grade oil of MS, DG or DM, SAE 10W-40 or 20W-50 ... ".  The local Honda dealer used 20W50 and I have always used 20W50.  Riding season up here is from mid-March to mid-Dec depending on the year the temperatures vary from about 10F to almost 100F.  I never had an issue with the 20W50.  Even had her out one year in early February when we had no snow.  The temperature at night was probably near 0F.  I hate to think what the wind chill factor was traveling at 70+ mph.  The coldest I have ever been considering we were wearing snowmobile suits.  It took almost 2 hours in a hot shower at the local university to warm up.
Maybe I have been lucky.
My $0.02.
Harry O.
750 K1 Original Owner
Re: oil thickness
« Reply #21 on: August 03, 2012, 10:01:28 PM »
Certainly things have been tried.  I might dispute actual testing, as that implies some measurement was, taken.  The worst part of that is that there have been many test cases of one, with conditions and treatment uncontrolled for all the different aspects of varied operation.
Is "that it has survived individual treatment so far" an endorsement of the basic robust design of the engine or that of the oil choice that was made?
I expect many do not understand the basic principles of scientific objective testing.  Which is likely why oil threads generally evolve into popular opinion polls. I don't expect that to change.  But, it might be an interesting change to challenge the opinions from time to time, just to have people think about them.
Re: oil thickness
« Reply #22 on: August 03, 2012, 10:43:08 PM »
I've read about the "clutch mod" adding more holes for improved flow through the clutch bits.  I've wondered if this was in response to the thicker oil choice he also recommends.  Some times a change causes a ripple effect for other changes needed to adapt.  I'll admit I don't know a lot about the 750 internals.  I trust that Honda did, as they has to pay for field repairs if things weren't working as they should.  I know they had some other clutch changes.  Don't know if those were more or bigger holes for oil to flow through them, or exactly why they made the changes, other than "clutch basket rattle.
I'd like to know why clutch plates wouldn't have more viscous coupling when disengaged while using a thicker oil.  Would a thicker oil also require stiffer clutch springs, to make the clutch grab better upon launch?
When I was using the Cb550 daily for commuting in our winters, the routine was to suit up, start up, and drive off immediately (no stationary warm up, at all).  The thicker oil made the bike jump when going from neutral to first, and more pressure (more wear implied) was needed on the shifter to change though gears for the first few minutes of the ride.  This went away if I waited through a warm up period before driving, or when I went back to 10w-40 and skipped the stationary warm up.  It got even better when, on a lark, I tried Honda's HP4 10W-40 without moly.  It's a semi synthetic.
My end conclusion after 20 years experience with oil experimentation, was that 10w-40 was really well suited to the engine, trans and clutch combination, and the synthetic portion of the oil choice had superior high temperature film strength for those time when the engine experience higher temps.  We do get several weeks where the temps linger near 100F, and stop lights tend to ruin the airflow over the engine cooling fins.
Be aware that it is no skin off my nose for people to choose any oil they wish to use.    But, when the question is openly asked, I feel the Honda recommendation is valid, and my experience seems to support their recommendations on my 14 test cases of one (so far).
Offline cabrala
  • Super Duper
Re: oil thickness
« Reply #23 on: August 03, 2012, 10:57:25 PM »
Touché Lloyd, touché...
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
Re: oil thickness
« Reply #24 on: August 03, 2012, 11:17:11 PM »
Yes, I see that.
The Cb500/550 Shop manual has an equivalent passage.  But recall that this manual was once created for the CB500, and the routine maintenance section was not revised with later supplements for the Cb550.
I've never seen an owner's manual for the Cb750 K1.  What does it say?
I have owner's manuals for 77 Cb750 F, several  Honda Cb550 owner's manuals, and a 72 Cb500 Owner's manual.  They all state that all weather operation calls for 10W-40.  Only the 72 CB500 manual has an extra reference mentioning 20w-50 and stipulates temps above 59F.
Could the 20w-50 reference in the CB750 Shop manual be vestigial as in the Cb500-550 manual?  Why didn't newer publications of Honda's owner's manuals include the 20w-50 oil allowance/recommendation?
Maybe so.   ;D
Or, maybe your machine (and a lot of others) is robust enough to allow for the treatment given it so far.
Certainly Honda's machines have received more and varied abuse beyond what Honda engineers expected or predicted.
While I don't want to belittle your experience.  Won't you admit your reference points are to very uncontrolled conditions?  And, you have no "control group" or "test case" with which to compare?
Is the only qualification criteria for 20w-50, "it still runs"?  I can then claim 10w-40 is just as successful then, as mine still run, too!   ;D
Truly, I genuinely hope you continue to be lucky, and ride onward.
