Author Topic: CB550 F2 - indicators... not working...  (Read 3481 times)
Offline auro
    • photostream
« on: April 26, 2012, 02:38:41 AM »
hi guys -
just got myself a CB550 F2 (http://forums.sohc4.net/index.php?topic=105865.0), which works quite nicely and well, except for the turning indicators...
the front and tail lights work (not the parking light) as well as the brake signal.
i looked at the FAQ but couldn't find some kind of guidance on what to check.
if you could give me some tips on where to start/what to check first, it'd be highly appreciated
grazie, thanks, merci!
CB350F (1975)
Offline Mighty550
  • 76 CB550F
Re: CB550 F2 - indicators... not working...
« Reply #1 on: April 26, 2012, 04:58:25 AM »
My theory on diagnosing any problems is "whats the easiest thing to fix?" and I try that first.  Check your fuses (under the side cover on the left) first and make sure its still good.
After that, check your bulbs, although if none of them are working, i find it hard to believe that all 4 are burned out.
If that doesnt fix it, start tracing wires.  Start at the signal and follow the wires, making sure all the connectors are snug and not corroded. There is a wiring diagram on here somewhere that will make it easier for you to follow the wires.
If that still doesnt fix it, check your flasher relay (under the same side cover I think), if thats gone bad, it may not allow any current to your signals, but i could be wrong about that.
If none of these things help, then you are past my limited knowledge.  Hope this helps!
Offline CafeDawg
  • Not All Those Who Wander Are Lost!
  • Gone to the Dogs
« Reply #2 on: April 26, 2012, 06:27:36 AM »
+1 Mighty's on the order of operations.  From their I'd suggest downloading the 550 manual if you haven't already.  I just got my 550 so not sure it's the same as my 750 but if you check the troubleshooting section for flashers in the 750 manual it suggests running a test wire between the female ends where the flasher relay plugs in ( find a parts fiche in manual or someplace like bikebandit which shows a schematic of your bike).  If when you run the test wire the lights light up its your flasher relay if they don't you've got a connectivety issue.  Then it's time to break out the meter and find the source.  So it's bulbs, fuses, relay, and then digging in.  Also if you need fuses and they aren't the easiest to find their isa guy on eBay (isn't their always) who sells combo packs specifically for your model CB.  Hope that helps.
Respect
CD
Respect & Understanding. U get what U give!
1976 CB550 basket case cafe rebuild
http://forums.sohc4.net/index.php?topic=106235.0
1978 CB750F evolving, daily rider
http://forums.sohc4.net/index.php?topic=89745.0
Offline auro
    • photostream
« Reply #3 on: April 26, 2012, 06:44:47 AM »
wonderful guys - exactly the input i needed to get started.
i'll spend some time on this in the coming week, and i'll keep you posted on news!
just to confirm:
1) the flasher relay is the one circled in red... right?
2) i have two fuses missing from the support, but i took it'd be fine as they are... spare ones... right?
bye
CB350F (1975)
Offline LesterPiglet
  • 1977 CB550F2
« Reply #4 on: April 26, 2012, 10:24:24 AM »
Those are just spare fuse carriers, they are not connected. Yes that is the flasher unit.
  • 1977 CB550F2
« Reply #5 on: April 26, 2012, 05:47:22 PM »
The small black rectangle is the clutch safety switch.
« Last Edit: April 26, 2012, 05:51:55 PM by LesterPiglet »
Offline auro
    • photostream
« Reply #6 on: May 02, 2012, 11:08:26 AM »
brief update: couldn't find exactly the fuses needed in local shops, so have replaced the ones there with 8A, 10A and 15A (instead of 5, 7, 15) and... I have the indicators back!
that's already good news, it means there's no other problem somewhere... and i'll fit the correct ones soon!
thx again for the tips guys
CB350F (1975)
Offline auro
    • photostream
« Reply #7 on: May 24, 2012, 04:10:27 AM »
brief update #2: even after the fuse replacement the indicators were weak in brightness, so i changed the winker relais. all is sorted now
me happy  ;)
CB350F (1975)
Offline samIam
  • 72 Honda CB500 Four
« Reply #8 on: May 24, 2012, 06:42:31 AM »
The winker relay is the flasher you have circled, right?
Offline auro
    • photostream
« Reply #9 on: May 24, 2012, 06:47:41 AM »
it's the one in the red circle
CB350F (1975)
  • 1977 CB550F2
« Reply #10 on: May 24, 2012, 02:27:38 PM »
I've just noticed. Why are there holes drilled in your frame?
Offline auro
    • photostream
« Reply #11 on: May 25, 2012, 04:47:09 AM »
what a question! to let it breathe
 :P
 ;D
CB350F (1975)
