Author Topic: Magpie's 1964/1965 Benly 150 Twin Project  (Read 63449 times)
Offline Magpie
Re: Magpie's 1964/1965 Benly 150 Twin Project
« Reply #250 on: March 04, 2016, 07:21:00 PM »
Long time between posts however I have become reinvigorated and working at the paint prep. Lots of prep necessary as the previous owner brushed on some paint that's a bugger to get off.
Offline grcamna2
« Reply #251 on: March 04, 2016, 09:07:42 PM »
Alright , you're doing/finishing this Nice restoration project. I look forward to the paint work you're doing  8)
Those 2 engines sitting on the bench side by side sure look Nice.
« Last Edit: March 12, 2016, 06:24:46 AM by grcamna2 »
75' CB400F/'bunch o' parts'
Offline Magpie
« Reply #252 on: March 11, 2016, 12:51:05 PM »
More and had to build up the area under the fuel petcock. Lots of pitting there. Cliff.
Offline grcamna2
« Reply #253 on: March 11, 2016, 07:23:42 PM »
I forgot but wondered why you have two engines? Do you have another frame ?
Offline Magpie
« Reply #254 on: March 11, 2016, 08:26:23 PM »
Yes. I started with a beat to death red CA95 that a woman gave me . It is a mess. I found a parts bike that was better than my project bike and it was complete so I switched projects.  I'll do this one and then perhaps do the red one up too. I have a pair of CB750 K1's so a pair of CA95'S would look good with them. I will need a lot of difficult to find parts for the red one. Cliff.
Offline CBJoe
« Reply #255 on: March 11, 2016, 08:30:55 PM »
Pardon the possible silly question...but what did you build it up with?  Solder?  Those engines are eye candy!
Cheers, Joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline Magpie
« Reply #256 on: March 11, 2016, 08:37:54 PM »
I'm trying JB Weld. It has worked well in other applications so I will use it and report the results back here. I did use silver solder to plug a small hole beside the fuel tap. Clif
Offline CBJoe
« Reply #257 on: March 11, 2016, 08:59:55 PM »
I used JB Weld on my '80 CB650 that was weeping around the petcock base and it lasted from 2002 - 2015 when I sold it...and at that time it was still holding with no indication of issue.
'65 CB77
'66 CM91 (C90'ish)
Offline Magpie
« Reply #258 on: March 11, 2016, 09:03:19 PM »
It's a good product. I was a bit ham fisted taking the fuel tap off a 750 fuel tap and used JB there too and it worked well. Cliff.
« Reply #259 on: March 11, 2016, 09:55:11 PM »
Want to buy my 65 Magpie. I also have gathered a lot of parts to rebuild her. Need to inventory it all to refresh failing braincells. I have been out of work for quite a while and medical issues have kept me out. Needing to thin the proj backlog and recoup money.
David
Offline Magpie
« Reply #260 on: March 12, 2016, 11:42:37 AM »
Hi David! Thanks for the offer but I have too many things on the go right now and we live a long ways apart. I live in Victoria, BC at the southern tip of Vancouver island. I think the shipping costs would be a killer for a full bike. However you could send me a list of extra parts you have to chalayko@shaw.ca just in case. I am going to need a set of handlebars and a chain guard at the very least for the other one I have.
Cliff.
Offline krusty
« Reply #261 on: March 12, 2016, 11:56:38 AM »
I bought this recently for one of mine.
http://www.ebay.com.au/itm/150762349695
Looks the goods, but have yet to fit it.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline Magpie
« Reply #262 on: March 12, 2016, 05:36:44 PM »
Nice! He has a ton of stuff on his site.
Offline Magpie
« Reply #263 on: March 12, 2016, 05:40:10 PM »
Today was gas tank day. The black one I wanted to use leaked at the fuel tap so I used some JB Weld to smooth the area around the tap but it still leaked so I will have to work on that some more. The tank that came with the red bike I originally was going to restore was tucked away under the work bench. I pulled it out to have a look - it didn't leak and was the cleanest inside. So, off with the paint! I will use this one and keep puttering with the black tank. Forward ho!
« Reply #264 on: March 12, 2016, 08:43:35 PM »
The tanks and petcocks are tough...
no go on handlebars here...mine are pitted and need replaced.
I need to start digging through everything to see what I have. Don't even know how to sell the bike and parts to recoup some of the funds... good at sinking money into them and stockpiling parts for the rebuild before I set forward with the work.
Thanks...will send you a bit...
I do have a chromed fender that was an aftermarket nos item...was going to rebuild it more like a cb95.
It is a fairly basic fender.
Offline Magpie
« Reply #265 on: March 13, 2016, 06:35:28 PM »
Off with the paint! Sill a bit of fussing with it. Cliff.
« Reply #266 on: March 13, 2016, 09:03:47 PM »
You make it look too easy cliff.
Offline Magpie
« Reply #267 on: March 13, 2016, 09:23:14 PM »
Thank you for that! The pictures don't reflect the hours between the times they were taken.
« Reply #268 on: March 13, 2016, 09:59:21 PM »
if there were not a little red paint sticking to acrevise in the one shot I would swear you were pulling our legs with a NOS tank you found somewhere. It is hard work stripping the early paint...they must have baked it on as they are nothing like the 70 s bike paints and none of the normal modern paints.
Offline Magpie
« Reply #269 on: April 02, 2016, 09:16:21 AM »
Baby steps:
Offline Magpie
« Reply #270 on: April 10, 2016, 10:54:20 AM »
Ready. I think. Off to the painter to check. And start my painting lessons.
« Reply #271 on: April 10, 2016, 10:24:53 PM »
Looks fabulous, please share more from paint while progressing through that process.
What color will they be?
Offline Magpie
« Reply #272 on: April 11, 2016, 08:46:45 AM »
The bike was black when I got it so I think I should stay with black. However they do look so nice in red too. Cliff.
Offline Powderman
« Reply #273 on: April 11, 2016, 10:04:36 PM »
Nows the time to change to the color you like. Nothing on it is black now, clean slate, no one would know otherwise. :D
Offline Magpie
« Reply #274 on: April 13, 2016, 01:40:51 PM »
You're right and I do like red. The tank was red so there's a good reason to go for it. Cliff.
« Last Edit: April 13, 2016, 03:20:43 PM by Magpie »
