Author Topic: Center Stand vs Side Stand  (Read 27168 times)
Offline lone*X
Re: Center Stand vs Side Stand
« Reply #100 on: June 27, 2012, 11:59:17 AM »
PC is definitely more durable than paint but I doubt it would make a lot of difference on the pads of the CS.  Just look at the surface damage done to the steel by the concrete surfaces.  PC is not harder than the steel.  It would abrade just like the paint would, maybe just a little slower.  Now to PC the CS is a good idea for long term appearance sake, it just wouldn't hold up on the bottom of the pads.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline 74750k4
« Reply #101 on: September 23, 2012, 06:38:26 PM »
Anyone install the spring on the 750 Center Stand lately???  Yeah???  How?
« Reply #102 on: September 23, 2012, 06:42:48 PM »
Yeah. I struggled, then it came to me. Piece of cake. Not necessary but hlps if you shove a shim in between each spring coil, like a dime, or slivers of flashing. This will extend the length of the spring.
Then put the hook and spring on. Then feed in the pivot pin, I prefer from the left. As you feed it in, lever the stand up into position. Still a struggle but it works.
Offline fmctm1sw
« Reply #103 on: September 24, 2012, 07:00:18 AM »
+1 on putting something between the coils.  I put a cheap Home Depot spring inside the centerstand spring.  Worked great.
Edit:  Oh and side stand for me unless I'm...
1]  Checking the oil
2]  Tightening the chain
3]  Doing other maintenance
4]  Saving space in the garage
« Last Edit: September 24, 2012, 07:01:57 AM by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline liPPy
  • 1978 cb750k
« Reply #104 on: September 24, 2012, 07:13:56 AM »
I fannied about for an hour bending a spring on a vice & slotting coins between the coils without success. I could never get the spring long enough and trying to balance the coins on either side of the spring to keep the whole straight was not easy.
I eventually went to Autozone, bought a brake spring installer like this and had the job done in about 90 seconds: http://www.amazon.com/JEGS-Performance-Products-Spring-Installer/dp/B007VR6ZUO
« Reply #105 on: September 24, 2012, 06:50:11 PM »
Centerstand?  nope, I keep it on the tool shelf.  It gets put on when the tools come out.  Why are you guys doing all this parking anyway?...I just keep riding ;D
Offline trueblue
« Reply #106 on: September 25, 2012, 12:41:07 AM »
I hook the spring up before I install the pivot tube, it slips straight in ;)
1979 CB650Z
Offline faux fiddy
  • bike in a box
« Reply #107 on: September 25, 2012, 01:02:05 AM »
I didn't read but the first couple pages so if this is redundant It's because of that.
Center stand is more stable. Center stand takes up less room to park, in or outside.
And if you ever had a tank with pin holes in it, they   develop way  more often where the water settles on the low (kickstand) side.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline Deltarider
« Reply #108 on: September 25, 2012, 05:31:57 AM »
Geee, this is an interesting thread.
Now, not to guide it into the mother of all debates, but didn't Honda built the heads so that at least some oil remains near the camshaft when parked on the CS to reduce cold start wear? I remember having read that the 350 Four head was designed that way.
« Last Edit: September 25, 2012, 05:33:36 AM by Deltarider »
CB500K2-ED Excel black
Offline fmctm1sw
« Reply #109 on: September 25, 2012, 06:00:00 AM »
Yes sir.  Last picture in this post:  http://forums.sohc4.net/index.php?topic=55856.msg601603#msg601603  It's a 400f head but the 350 is the same way.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline mono
  • Definitely no
« Reply #110 on: September 25, 2012, 07:37:16 AM »
i removed my center stand when i went with a right-side 4-1 exhaust.  kinda had to, since the center stand stop was connected to the left side exhaust.  works fine that way, and when it's going to be parked for a while i just burn off the fuel in the carbs.
in the winter i am going to drain/rinse my tank and store it inside.  last winter i put a bunch of silica packets in it, sealed it in a big plastic bag, and kept it in the basement to avoid temp fluctuations causing condensation.
« Reply #111 on: September 25, 2012, 08:33:08 AM »
Most 4-1s provide a centerstand stop bracket. They usually get lost when the pipe changes hands.  A simple "L" shaped bracket hanging from a rear footpeg mount, often on the right side with the pipe.
Offline mono
  • Definitely no
« Reply #112 on: September 25, 2012, 04:21:05 PM »
i bought a new MAC 4-1, all it came with was a hanger bracket  :'(  it's OK though because i'm not heavy enough to get it to rock back on the center by myself....  yeah yeah i'm a wuss... lol
« Reply #113 on: September 25, 2012, 04:49:05 PM »
Curious. I'd a thunk the MAC would've had the CS stop.
AS to raising it on the CS, its all technique, several threads on the issue. Very little strength or weight involved.
Offline HonderCB
« Reply #114 on: September 25, 2012, 04:56:16 PM »
true.  a PO of my bike must have not liked the CS because my tank developed many pin holes on the kick stand side at the bottom, nothing a caswell kit couldnt fix
77' CB750F
81' CB650C - SOLD
Offline JimS63
« Reply #115 on: September 25, 2012, 09:45:37 PM »
I use the SS most of time during the summer months, and the CS during the rainy season or when I know it will be parked for a while.
1977 Honda CB750a Hondamatic
