Author Topic: Anyone made their own top triple tree without a milling machine?  (Read 23777 times)
Re: Anyone made their own top triple tree without a milling machine?
« Reply #50 on: July 22, 2012, 01:57:05 PM »
 Yes, but not doing so results in a shorter front end.
 If the only reason you run a GL fork is cost.. guess you are stuck with stock..
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #51 on: July 23, 2012, 06:57:51 AM »
so Frank, any chance you're in the market to make a nice gl triple tree??   ;D
« Reply #52 on: July 23, 2012, 07:29:31 AM »
 Maybe, a lowcost option is avalable, if  I supplied the plate with the 3 holes in it, then the buyer could finish it.. any way they wanted..
Offline Syscrush
  • Sold. :(
« Reply #53 on: July 23, 2012, 07:40:29 AM »
While we're talking about fabricating triples of different designs, I have to throw this out there...
The sheetmetal triples made at Eurospares:
Jig
Blanks ready for bending & welding
A pair of bent blanks and one triple welded up.
On the bike.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #54 on: July 23, 2012, 02:08:10 PM »
Syscrush
I've never seen these sheet metal triples before and looking at them now raises the question of the benefit of this type of construction vs billet aluminum. IMO, it can’t be based on esthetics, and I would be surprised if fab costs are less. Interesting though.
Offline Syscrush
  • Sold. :(
« Reply #55 on: July 23, 2012, 02:15:54 PM »
Syscrush
The stated goal was lightness - it was used on a Laverda race bike at some point.  BTW, that's not Instagram or Hipstamatic faux patina on those scanned pics. ;)
I find this technique intriguing, and have never seen it anywhere else.
Offline voxonda
« Reply #56 on: July 23, 2012, 02:41:30 PM »
This technique was used by the all conquering MV Agusta's of yester year. Though made not from ordinary steel, but a high grade one.
Offline Syscrush
  • Sold. :(
« Reply #57 on: July 23, 2012, 04:08:09 PM »
According to this page, the 2 triples plus the aluminum stem & nut saved over a pound vs. the stock Marzocchi cast aluminum pieces.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #58 on: July 23, 2012, 05:30:25 PM »
Wow, that's significant!
Offline Syscrush
  • Sold. :(
« Reply #59 on: July 23, 2012, 06:06:53 PM »
I'm exploring a project that will require custom triples, and I can't stop thinking about having them made from tube & laser-cut flat stock in a kind of skeleton design something like this:
I know, it's a horrible drawing, but you get the idea.  3 pieces of tubing welded to 2 pieces of strong flat stock.  The main problem I see with this design is that it's not very strong in skew, but if you didn't care about weight, it seems to me that you could have something strong enough for street duty, and with a very distinctive look.
« Reply #60 on: July 23, 2012, 11:33:01 PM »
 The problem with fabricated trees is warpage, should be OK with rigid fixtures or stress relieving, or Honing after welding.. Kosman I think did an aero version, the sheetmetal part may have been airfoil tubing, but they were horizontal to the ground, not at right angles to the fork legs...
Offline wannabridin
  • -Garrett
« Reply #61 on: July 24, 2012, 05:52:01 AM »
rob, check your PM's.  i sent you a question about some triples for my GL1000 front end swap, hoping you can help out!
Offline Syscrush
  • Sold. :(
« Reply #62 on: July 24, 2012, 06:24:04 AM »
In addition to the distinctive look of fabricated trees, another potential benefit vs. milled trees is that you could make the sleeve that holds the forks much longer without using/wasting so much material.  You might want to do that for looks, stiffness, or to facilitate using shorter modern forks on a vintage bike.
Offline Blitzburgh207
« Reply #63 on: January 13, 2013, 08:20:58 PM »
I'm interested as well
1978 CB750 K8
Offline J.Webster Designs
  • www.JWebsterDesigns.com
« Reply #64 on: January 13, 2013, 09:01:36 PM »
Not sure if you guys ever got this rolling or not... I am still willing and able to produce these for you.
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
« Reply #65 on: January 13, 2013, 09:21:23 PM »
I picked up a 70 OSSA trials chassis, it has Betors, with fabricated trees..which are tweaked. First example I can recall on a production bike..
« Reply #66 on: January 13, 2013, 11:35:47 PM »
What do you have in mind.?
Offline Syscrush
  • Sold. :(
« Reply #67 on: January 14, 2013, 03:58:23 PM »
Can you post some pics? It would be awesome to see that!
