Author Topic: 12 attempts in and no luck wiring 550 Please HELP  (Read 7869 times)
Re: 12 attempts in and no luck wiring 550 Please HELP
« Reply #25 on: August 30, 2012, 06:33:27 PM »
So I have tried and tried, I've resourced every simple wiring diagram I could find.  At this point Im just trying to get the running electrics going, I figure I can deal with lights after it is running.  The bike was running perfect before I took this wiring harness off, Im trying to go basic from scratch but for some reason I can't get spark.  This is what I just put together, if you can help point me in the right direction Id really appreciate it.
I can't make out your labels on the ignition switch. What is the terminal where the battery + connects? Is this a generic switch from a car parts store?
Offline cprice9
« Reply #26 on: August 30, 2012, 06:49:30 PM »
as far as I know it is the stock one and it has a red, a black, a brown, and a brown/white coming out of it, the red is what is connected to the battery +
My build, 1974 cb550:  http://forums.sohc4.net/index.php?topic=112007.0
-to sleep late, have fun, get wild, drink whisky, and drive fast on empty streets with nothing in mind except falling in love and not getting arrested . . . Res ipsa loquitur. Let the good times roll.
« Reply #27 on: August 30, 2012, 06:56:52 PM »
With the switch turned on, you should read 12 Volts or more at the black wire on the switch. Meter black lead on ground, red meter lead on switch black wire. (Or just jumper the battery + to the coil black wires and check for spark)
Offline luap
  • LAWL
« Reply #28 on: August 30, 2012, 07:53:06 PM »
if you arnt going to hook up the y/r an blk wire it wont run. eliminate the starter silenoid run the red  wire coming off your key switch back to battery + an the r/w coming off the rectifier also to battery +
thats for kickstart only
another thing since you took it all apart did you hook the blue an yellow wires coming off the ignition to the correct coils blue to 1/4 coils an yellow to 2/3
is your battery good
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
« Reply #29 on: August 30, 2012, 08:05:20 PM »
Your drawing clearly shows the ign switch divided into 3 sections. That reminds me of automotive switches I've seen, with 3 raised ribs on the back. Please post a picture of the back of your switch.
« Last Edit: August 30, 2012, 08:07:33 PM by scottly »
Offline cprice9
« Reply #30 on: August 30, 2012, 09:32:29 PM »
« Reply #31 on: August 30, 2012, 09:37:49 PM »
Thanks. That does look like a stock switch.
Offline Round Dice
« Reply #32 on: August 31, 2012, 10:43:30 AM »
To test your battery at any point:
Touch your volt meter leads to the battery posts (red to red, blk to blk)
With the key in the off position you should read about 12v (10-14), even when your battery is dead.
With the key in the on position you should read 10-12 volts if your battery is good.  If you read less than 10 volts your battery is dying or dead.  Charge it and try it again.  Depending on the history of your battery it may or may not hold a charge.  Then you can decide if you need a new battery.
so why when I turn the key to red, which should be ignition (?) do I only get 2-4?
Where were you measuring this 2-4 volts?
New to forums, not motorcycles.
Offline stereosilence
  • 1975 CB550K
« Reply #33 on: August 31, 2012, 07:23:39 PM »
What about the cutoff switches? On mine, I have to be in Neutral and have the kill switch in the right position.
I PM'd you. I live nearby I believe. I can at least show you how to use the meter  :)
Offline cprice9
« Reply #34 on: September 04, 2012, 02:05:59 PM »
So,
after wrestling this bear for a couple of weeks I have my first taste of victory.  I decided to tell the electric start system to go to hell and just run it kick.  Im young enough to not care, never had a kick only, and these bikes aren't like trying to kick an old pan so screw it.
I pulled the solenoid and ran the r/w from rectifier and the red from the keyswitch right to the + on the battery… I got it to fire(ish)
Im gonna run lights and convert my throttle cables to fit but I will hopefully be back in business this evening…  If not I will be back.
In the meantime, is anyone else running kick only, if so what does your wiring look like?
Offline Round Dice
« Reply #35 on: September 04, 2012, 03:13:46 PM »
my kick only is just a removal of the solenoid.  The starter motor lead is removed or stashed, and the hot lead from the battery is cut off so it doesn't ground out and blow a fuse or fry a wire.
Its really not that big a change since you could've kicked it all along.
Offline phil71
« Reply #36 on: September 06, 2012, 08:51:44 AM »
"I don't understand how this goes together". Another bobber is born!
Offline Lostboy Steve
« Reply #37 on: September 06, 2012, 10:31:40 AM »
So I relocated the grounds to the base of coil bracket, at this point Im not even worried about my start button I just want to get it to turn over.  The r/y and black coming off solenoid are still not connected to anything.  The multimeter is giving my 2 volts when key is on red dot, and 14 when key is switched up one more position.  At this point I think I might be draining my battery so Im going to pick up a charger and, though I work on computers for a living I don't think Im working my meter the right way so Im going to study up on that.
In the meantime, here is a pic of where Im at.  Electrical aside Im waiting on a new tail light, rear springs from a GL1000, getting a rear cowl and seat fabricated, stripping my tank down to metal, cleaning carbs, new seals, new chain and sprockets, exhaust, sync, and GO GO GO!!!
That thing looks sweet. What tires / sizes?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline cprice9
« Reply #38 on: September 06, 2012, 10:57:35 AM »
Thanks, they are the ever popular Firestone Champion Deluxe 18-450 rear and 19-400 front  here is an updated pic…
Electrical thankfully solved, however Im not running electric start, Im also not gutting wiring ever again without some type of plan.  Time wasted enjoying yourself isn't time wasted at all.
Offline lucky
« Reply #39 on: September 06, 2012, 04:51:44 PM »
IF you bought a workshop manual it shows exactly where each and every wire goes.
All you need is a pencil to follow the black line on the drawing.
Offline phil71
« Reply #40 on: September 06, 2012, 05:57:17 PM »
early on, he said the orig harness was mostly missing.. he was definitely gonna need more than a pencil.
Offline cprice9
« Reply #41 on: September 06, 2012, 06:09:53 PM »
yeah picked up a manual same day I got the bike, the diagrams though account for everything being wired according to factory spec and I didn't want the majority of that stuff, so I had to start from scratch.  Electrical on these old bikes isn't something to just figure out if you don't have any background in electronics, so it took some doing, but I went on a late evening cruise tonight (around my backyard).
Offline luap
  • LAWL
« Reply #42 on: September 10, 2012, 09:18:24 PM »
cprice9. Ill bump it for you think you will get more replies here. an Rereading some post the new questions have been answered
www.cb-town.com
Offline cprice9
« Reply #43 on: September 11, 2012, 05:05:27 AM »
Here is the latest as per luau's suggestion...
So I've got a new taillight that Im wanting to run, but Im unable to get running and brake going together, so let me start there.
First off it is a dual filament bulb so it is capable, at this point I've got these wires to run but can't figure the right combo.
BLK from keyswitch and BR from keyswitch
BLK from pigtail rear brake switch and GR/Y from pigtail rear brake switch
There is also 2 connection points on the front brake pressure switch that I'd like to run as well
BLK from taillight and GR from taillight (also running a ground to frame)
Heart of the matter is that Im not getting running light, any suggestions?
Lastly, what is the BR/W line coming off the keyswitch for?
Thanks for any insights folks
Offline apehanger 550
« Reply #44 on: September 11, 2012, 06:45:09 AM »
 BR/W goes from the keyswitch to the gauge lights
Offline cprice9
« Reply #45 on: September 11, 2012, 07:49:42 AM »
ah nice, they were the first thing off the beast.
  • 1975 CB550K
« Reply #46 on: September 11, 2012, 11:34:00 AM »
Is your headlight on? On mine there is a headlight switch to turn on the headlight and running light (and then another selector for Hi/Lo beams).
Offline luap
  • LAWL
« Reply #47 on: September 11, 2012, 03:29:11 PM »
on the three position switch 0,1,2 - 0 would be blk(power) 1 would be white low 2- blue hi
Br wire doesnt get used
BLK from taillight and GR from taillight (also running a ground to frame). a 3 wire light one to blk (running) other to brake switch (brake light) 3rd ground, If your running 2 different wires off the lightto ground  I dont think its going to work.
www.cb-town.com
